United States, MA, Waltham
Joined Dec 2001
No need for anything high tech there. Anything small enough to fit that is not tiny will work. You might try HS-81. Or even standard servos, if they fit. Advantage of standard servos is that they're cheap and the gears are harder to break. If your Oly is coming in especially heavy, then maybe you can use the HS-81's or something like them. I suspect HS-55's are too small, except possibly for the spoilers, but the HS-81's are probably more than you need, especially for the elevator. My 650 had ancient Kraft servos that were wearing out.
I learned to fly with an Oly 650. Not bad for the size. |
Latest blog entry: pics from Winthrop, MA indoor flying...
Joined Dec 2001
Remember that this type of glider is designed for a 2 ounce receiver, 4 ounce battery pack, and 2 ounce servos. So you don't have to get the very smallest servo that will do the job.
Australia, VIC, Yarra Glen
Joined Sep 2012
Wow....would have liked to see the inverted fly-by to landing!
![]() Thanks for the post Craig - I have noted digital servos and one of the recommendations was a Spektrum A3030, however, it is a micro and I believe I'll follow Lincoln's advice regarding needing the weight up-front. Spektrum have another standard digital servo which would compare with the Hitec 81's (A6060) so I'll investigate a little further... cheers and thanks again, GB |
Joined Dec 2001
I suspect that, if you're worried about reliability and durability, a standard servo from a reputable manufacturer is hard to beat. Bigger gears are harder to break. And this is just an Olympic 650 we're talking about here.
If you have two different servos, put the tougher/stronger one on the rudder, or the more precise one on the elevator. |
| Thread Tools | |
| Sold Servo lot and servo reversers 13 servos Towerpro Hitec $60 shipped for all! | planebldr | Aircraft - General - Radio Equipment (FS/W) | 1 | Aug 25, 2012 01:06 PM |
| Discussion Blade 450 w sticking servo.. (Can I replace stock servo w tail servo)? | h8tow8 | Electric Heli Talk | 6 | Jul 31, 2012 07:43 PM |
| Sold Servos, servos, and more servos! | bobzilla | Garage Sale/Large Lot Ads | 0 | Jul 06, 2012 07:35 PM |
| Sold JR 321 mini high speed servos & 341 servos | bvmflier | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 04, 2012 01:52 PM |
| Sold Servos Servos Servos | squirrel40 | Aircraft - General - Radio Equipment (FS/W) | 0 | Feb 26, 2012 12:27 PM |
