This thread is privately moderated by quitcherbitchen, who may elect to delete unwanted replies.
Old Sep 09, 2012, 05:45 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Cañada Flintridge
Joined Jul 2011
Build Log
New Super Cub Flap
Finally got around to a different Fowler design. Used big Robart pin hinges to simulate an external hinge. Very conventional actually, but this is now Fowler number 4 for me. This should be very fun. If they end up as robust as my number 1 design I will incorporate them into future designs as these were ten times easier to install.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Sep 09, 2012, 05:47 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
reminds me of funcub hinges.
copperbricks is offline Find More Posts by copperbricks
Old Sep 09, 2012, 05:49 PM
Joined Jul 2011
Maybe I should have bought those. I'll check it out. These were pretty easy and only $3.00
Old Sep 09, 2012, 05:56 PM
Joined Aug 2011
It's basically the same thing, except the hinges have a flat attachment point, like a control horn.
Old Sep 09, 2012, 05:57 PM
Joined Jul 2011
Cool, Do they work good or are they fragil
Old Sep 09, 2012, 06:01 PM
Joined Aug 2011
They work really well. Slow the plane down to a crawl when they're at 85 degrees. You do need strong servos though, they take a lot of force if you use a lot of throttle with them down. Mine are slightly green from the grass the prop chops up.
Old Sep 13, 2012, 06:18 PM
mgivens is offline
Find More Posts by mgivens
mgivens's Avatar
United States, WA, Seattle
Joined Jan 2007
The multiplex funcub hinges are great...BUT...im pretty sure you cant buy them by themsleves, you have to buy a big parts package with a bunch of junk you wont need for $26! I looked for a while but couldnt find them by themselves anywhere.
you could add a little triangle piece of ply to reinforce your robart idea!
-Michael
mgivens is offline Find More Posts by mgivens
Old Sep 13, 2012, 08:25 PM
Joined Jul 2011
I noticed the Multiplex ones were really expensive. These Robarts seem pretty strong and for $3.00 I can't complain. One of my $3.00 servos failed on the bench though. I haven't even flown this yet so I guess on the ground is better then the air.
Old Sep 14, 2012, 04:04 PM
Joined Jul 2011
One thing I learn with these flaps is that analog servos will act all stuttered once you slow them down using the computer radio. I slowed the flaps to deploy and retract in 1.2 seconds and they move very stuttered because of the analog signal. Copperbricks is right that you need a strong servo. My cheap HK servos work, but I am worried that they may not be up to the task. Also, if there is any slop in the linkage there is a possibility for flutter. I might have to redesign the control horn. I might put some MG5065 digital ones in if these fail. Slowed movement should be smoother too. I charged my batteries for tomorrow so I tell everyone how it goes.
Old Apr 14, 2013, 01:55 PM
Wdjones777 is offline
Find More Posts by Wdjones777
Joined Mar 2013
Robart hindge
I really like the fowler type flaps you made... You said you used BIG Robart hinges ... When ordering they don't specify big? Do you remember which ones you bought..? Now that you've used this set up would you do anything differently.. And did your HK analog servos hold up?
Wdjones777 is offline Find More Posts by Wdjones777
Old Apr 14, 2013, 07:58 PM
Joined Jul 2011
I used Robart 310 hinges though I have bought Hobby King large and they look the same. just line them up and glue them in and dremel off the excess that stick out the top of the flap and wing. The cheap HK servos are fine. There is virtually no load on the servos and they are very easy to make, I actually wouldn't change anything. Just make sure your servos aren't reversed or you invert the hinge line. I haven't encountered flutter either.
Old Apr 18, 2013, 09:20 PM
Joined Mar 2013
Thank you
Just completed the flaps and ailerons today.. I did what you suggested.. It will be a few days before I can cut the servos in ... What were your dimensions on the ailerons / flaps..? I used 9" x 1 3/4 ailerons and 8 x 1 3/4 flaps .. Great idea..
Old Apr 19, 2013, 12:23 AM
Joined Jul 2011
I think my flaps were 10" x 1 7/8" and the ailerons were 9" x 1 7/8". I still have a decent roll rate if I use a lot of rudder. Both my Super Cubs have Leading Edge slats, but I think to really get a decent slow STOL you need Crow setting in your radio and I am going to next experiment with a full symmetrical horizontal stab. Some really thick cord to keep the air attached.
Poll Adding Flaps & Ailerons to Hobbyzone Super Cub DeepBlueGray Foamies (Kits) 2 Jun 25, 2014 08:15 AM
Sold New Battery (Lipo) + Charger from New Hobbyzone Super Cub SoCalSteve72 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 26, 2012 02:50 AM
Discussion New Super AVA 4 flaps Jebera Electric Competition Soaring-F5J/ALES/e-Soaring 19 Jun 08, 2012 10:40 AM
Discussion HobbyZone Super Cub 5 minute flap modification wattman Beginner Training Area (Aircraft-Electric) 0 Oct 24, 2009 05:51 PM
Discussion Hobby Zone Super Cub w/ flaps realtimerecon Electric Plane Talk 3 Jun 18, 2008 03:29 PM
