Old Sep 09, 2012, 01:19 PM
Broken Wings is offline
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
Question
I never built a wing like this before...
I'm building a B&M Models Kloud King. I've just about completed the fuse and tail sections and now I've come to the wing construction.
The instructions say I can build the wing in two ways. After read through the instructions I assume that I can build the center section along with the spars "sticking up in the air" at the correct dihedral and then lay the spar down on the plans and attach the ribs/etc.
Normally I would build both panels and attach them in the center.
Is my assumption correct? I've never built a wing like this before.
Thanks in advance.
Broken Wings is offline Find More Posts by Broken Wings
Old Sep 09, 2012, 02:38 PM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
It does sound strange, but I read those instructions the same way. Sounds fun
owlsabie is online now Find More Posts by owlsabie
Old Sep 09, 2012, 02:58 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Yep, perfectly good way of building a wing; assemble the spar or spars first to the correct dihedral angle, then build the wings a section at a time. Example below, has only one bottom spar pre-assembled over the front view of the wing first, but the principle is the same, the centre section is assembled first onto the pre-farbricated spar, then left panel, then right panel. Means that you get really good, precise joints on the main spar and that the dihedral has to be right.
Sundancer is online now Find More Posts by Sundancer
Old Sep 09, 2012, 04:29 PM
Joined Jan 2006
Perfect, Thank You Very Much.
All I've got left is the wing and she'll be ready for sanding/covering.
Discussion The (BAT-WING) like a bat out of HELL.Scratch built. crispy1074 Scratchbuilt EDFs 4 Aug 29, 2012 02:58 PM
Discussion Intellectual idiots - never before this clearly Gooroo Life, The Universe, and Politics 48 Apr 27, 2012 05:33 PM
Video Dirt Doggin' - You've never seen RC like this before CaliDave Car Talk 8 Jan 15, 2012 09:04 AM
Discussion You have never seen anything like this before. austinelse Batteries and Chargers 231 Aug 03, 2010 02:24 PM
Cool If you really like aircraft designs that never got built, check this out! Thomas B Scale Kit/Scratch Built 1 Aug 28, 2007 10:49 PM
