Old Sep 09, 2012, 11:20 AM
reinking is offline
Find More Posts by reinking
Joined Jun 2005
A supersonic biplane....
A Supersonic Biplane that Whispers Where the Concorde Yelled
<http://www.txchnologist.com/2012/a-supersonic-biplane-that-whispers-where-the-concorde-yelled>
A .pdf file, "Adjoint based aerodynamic optimization of supersonic
biplane airfoils" is available here:
<http://aero-comlab.stanford.edu/Papers/AIAA-2011-1248-354.pdf>
reinking is offline Find More Posts by reinking
Old Sep 11, 2012, 02:44 AM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Someone needs to brush up on their biplane efficiency research.
Biplanes generate big amounts of drag when the wings are much less than one chord separated. And this one certainly qualifies on that front.
The shockwaves when supersonic MAY work with the biplane wings to lower the shock wave reaching the ground but I'm not sure with all the interference drag between the wings that it could carry big enough engines to reach the transonic speeds where the shockwaves could come into play.
Anyhow if it has promise I'm sure we'll see it at least get some research time.
BMatthews is online now Find More Posts by BMatthews
Old Sep 11, 2012, 07:34 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
You're thinking of subsonic. Things are quite different in supersonic. They are using shock interactions to reduce wave drag.
Busemann’s insight was that the supersonic shock wave coming off of one wing could cancel out that produced by another, Hu says. Simply stated, his biplane configuration consists of a pair of airfoils with flattened triangular cross-sections. Busemann positioned the wings so that the vertices of the angled surfaces of each airfoil pointed toward each other—one oriented upward, the other downwards—with the flat sides at the very top and bottom. The center vertices create the expansion (low-pressure) wave that occurs between the compression shock waves at the leading and trailing edges of the wings.
In Busemann’s biplane, the high-pressure shock waves are created internally and reflect symmetrically between the two wings. This process “fills” the expansion waves coming off of the vertices with pressurized air, leaving no external shock waves to propagate out to the surrounding environment.
Although the above quoted is apparently old news. The newer research used an optimization-based approach to reduce the transonic drag that limited the original Busemann design.
Montag DP is offline Find More Posts by Montag DP
Old Sep 11, 2012, 03:33 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
I still have my doubts about how well it'll perform during the run up from standing on the tarmac to transonic speeds where the shockwaves begin to take effect and alter how the air behaves.
Old Sep 11, 2012, 03:38 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Bruce, from first glance it looks like off-design Mach numbers was a major consideration of theirs.
DPATE is offline Find More Posts by DPATE
Discussion Another supersonic DS idea bjaffee Dynamic Soaring 2 Aug 16, 2012 11:14 PM
Link Supersonic Biplane Concept mexico Other Websites 0 Apr 12, 2012 09:13 AM
Discussion Supersonic biplane? dll932 Life, The Universe, and Politics 2 Mar 24, 2012 04:50 PM
Supersonic Turbine Jets! kushal_22 Electric Ducted Fan Jet Talk 5 Jun 29, 2003 08:27 PM
What if.... Bell X-1 (1st supersonic aircraft) sukhoi26mx Parkflyers 30 Jan 25, 2003 12:08 PM
