Old Dec 21, 2012, 01:52 AM
mixjsj is offline
Find More Posts by mixjsj
Joined Aug 2011
asdf
mixjsj is offline Find More Posts by mixjsj
Old Jan 24, 2013, 06:33 PM
mixjsj is offline
Joined Aug 2011
Hi there. My friend helped me to cut all the stuff. I start to assembly.
I resized this 95%. yes I've tried adjust offset, however there are so may parts so I would have made mistakes. so I decided resize and get it. So I need fan to be down to 80mm and hovering fan to ~5 inch. I need help guys. gimme some great information to make 2~3 lb from 5 inch prop or fan with very light weight!~
Total weight gonna 4~5 lb(I hope). thanks asdf
Old Jan 24, 2013, 07:56 PM
mixjsj is offline
Joined Aug 2011
5.25X4.75E apc prop with 3000kv 4s gonna make 1kg thrust?
in static status which one makes better thrust EDF vs Prop?
Old Jan 25, 2013, 04:52 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
For the same diameter - EDF in theory. Nothing wrong with getting a 6" prop and trimming it to fit the duct.
Odysis is offline Find More Posts by Odysis
Old Jan 29, 2013, 11:38 PM
mixjsj is offline
Joined Aug 2011
<iframe width="560" height="315" src="
IMG 05891 (1 min 24 sec)
" frameborder="0" allowfullscreen></iframe>
Hi guys by advise of Odysis I used my prop as a plan. I trimmed end of each blade and balanced. thanks.
Old Jan 30, 2013, 11:33 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
For the 80mm fan, JetFan makes an 80mm one which would be a good, light-weight solution.
alexandermh is offline Find More Posts by alexandermh
Old Jan 31, 2013, 06:27 PM
mixjsj is offline
Joined Aug 2011
Hi recent pics. thanks
Old Feb 03, 2013, 06:47 AM
mixjsj is offline
Joined Aug 2011
Some tips about self made duct: 1 props are not ridgid. It will bend when they make thrust by law of action reaction. 2 duct opening should be clear of any things interfere with air flow just open it. 3. Intake diameter vs exhaust dia should be 1:1 it means barrel shape is good. 4. Make your shoured perfect circle as possible and last thing is -i think you know- shoured and prop must be close as possible. It makes your ducted fan more efficient
Old Feb 13, 2013, 06:38 PM
tripn4days is offline
Find More Posts by tripn4days
All Thumbs
Joined Jun 2012
<--- Still just awestruck by this build!
tripn4days is offline Find More Posts by tripn4days
Old Sep 15, 2013, 04:25 AM
Joel_Vlashof is offline
Find More Posts by Joel_Vlashof
Joined Nov 2012
F35
Indeed nice cad work!!! i am a big fan already. i was starting also to draw this plane in cad but it is a hell of a job, can we share drawings p
Joel_Vlashof is offline Find More Posts by Joel_Vlashof
Old Sep 16, 2013, 08:06 PM
mixjsj is offline
Joined Aug 2011
Hi~~
hmm It's pretty rough one and if you use low quality ply (Like me) you can find it very fragile!!
wait I'll put this thing soon~~ I'm at my work place
Old Sep 18, 2013, 08:24 AM
mixjsj is offline
Joined Aug 2011
Oh.. I just trained aerodynamics of F35 my self today with F22 70mmEDF
what I just feel again today is: inefficiency of ducted fan. I just flame out my 4000kv motor in 3 minutes and my F 22 landed on top of very big tree
it is very late night but it still on that tree with switch "on" still respond to my transmitter what the horrible experience !!!!!
well, I just changed my plan not to use ducted fan instead I'll gonna use 6~7inch APC prop with duct! this is my mold for intake.
Old Sep 18, 2013, 07:48 PM
mixjsj is offline
Joined Aug 2011
Can anyone tell me which motor is best for this prop ??
Old Sep 18, 2013, 08:18 PM
mixjsj is offline
Joined Aug 2011
I've just found this composition will be great.
Lockheed also used turbo fan engine for making hover thrust.
So I'll mimic that one.
Old Sep 23, 2013, 12:13 AM
mixjsj is offline
Joined Aug 2011
very rough works make such a nice parts~
it is made by just layering of fiber and epoxy.
I ordered some bagging matterial and I just completed CAD work of F35 upper
parts mold I'll gonna print out that mold this week, and you can see beautiful shape soon~~
by the way, F22 test story:------------------------------------------------------------------------
I've just pulled out F22 foam EDF (hobby K**g) from very high tree. It was worst mission ever undertaken in my life.. I borrowed ladder from my building office. I and wife got to mountain where my F22 and Tree is. (what you should know: ladder is pretty heavy man!! ) with ladder,with pole which was made by my hanger, I finally got out my f22!!
it's flying is just very easy to stall and maintain it's status. I think it is for thrust vectoring right? absolutly need aileron-> elevator mix when it stall it's wing aileron became useless. primary cause of sitting on tree is aileron failure. I think it's because square shape of wing... please reply any informative comment!! thanks
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 01:41 AM
Discussion Foamie f35 to go composite. DYORD Composites Fabrication 1 Jun 17, 2012 11:56 AM
Discussion Convered Dynamax Fan CoolerByTheLake Electric Ducted Fan Jet Talk 0 May 28, 2012 07:49 PM
Sold Cox Tailwind 40 convered to EP with Floats $400 LPU be69ar Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2012 11:01 AM
Discussion F35 successful Hovering sergiot78 VTOLs 37 Oct 09, 2011 12:42 AM
