Old Sep 09, 2012, 04:59 AM
mixjsj is offline
Find More Posts by mixjsj
Joined Aug 2011
Making hovering & conversion F35
asdf
mixjsj is offline Find More Posts by mixjsj
Old Sep 09, 2012, 05:39 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
http://www.rcgroups.com/forums/showthread.php?t=1711658
space 1 is offline Find More Posts by space 1
Old Sep 10, 2012, 01:00 PM
mixjsj is offline
Joined Aug 2011
asdf
Old Sep 10, 2012, 05:15 PM
bamiller is offline
Find More Posts by bamiller
bamiller's Avatar
United States, CO, Castle Rock
Joined Dec 2009
I've always wondered how the F35 maintains its stability on the vertical take off. Any thoughts how this is controlled?
bamiller is offline Find More Posts by bamiller
Old Sep 10, 2012, 09:43 PM
mixjsj is offline
Joined Aug 2011
asdf
Old Sep 10, 2012, 09:44 PM
mixjsj is offline
Joined Aug 2011
asdf]
Old Sep 10, 2012, 10:18 PM
mixjsj is offline
Joined Aug 2011
F 35 RC design (0 min 19 sec)
Old Sep 11, 2012, 11:41 PM
raipe is offline
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
Originally Posted by mixjsj View Post
and if some one wanna get this model by google sketchup version come and get it.
http://sketchup.google.com/3dwarehou...cc&prevstart=0
Hi Mixjsj!
First of all nice and ambitious project, just keep whittling at it Second of all, that is mighty generous of you to offer the modell for others. I know it has taken many hours to build and to get it to this point. It has revealed to me just lately how good a tool the su is. My short CAD experience is with the Inventor and the like so I am kinda awed by what can be done with a relatively cheaper software.
Will be watchin
raipe
raipe is offline Find More Posts by raipe
Old Sep 12, 2012, 09:36 PM
mixjsj is offline
Joined Aug 2011
asdf
Old Sep 13, 2012, 06:25 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
It looks like you have already started to figure it out, but you will need a better than 1:1 thrust to weight ratio. Also how have you addressed roll control during the hover? On the Harrier this is done via small jet outlets at the tips of the wings. Of course that requires ducting to the wing tips plus a control system for those. I'm not sure how roll is controlled on the F-35, but probably a similar system. Yaw and pitch are also controlled in the same manor in the Harrier.
SteveC68 is offline Find More Posts by SteveC68
Old Sep 18, 2012, 11:09 PM
raipe is offline
raipe's Avatar
Finland
Joined Oct 2008
Just a thought, would work in a bigger model better because of the added weight but anyway. How about putting in an air tank, put airlines all the way to the wingtips and point them down. A separate valves to drive each wing via gyro and voila you have the same function as the real deal. To take the idea further, you could do some fancy programming and have them work also with the aileron stick when the jet nozzle is pointed down and to disable them in level flight.
raipe
Old Sep 23, 2012, 09:56 AM
mixjsj is offline
Joined Aug 2011
asdf
Old Sep 24, 2012, 09:16 AM
mixjsj is offline
Joined Aug 2011
asdf
Old Sep 24, 2012, 12:23 PM
raipe is offline
raipe's Avatar
Finland
Joined Oct 2008
I thought just same as you thought it is realy good Idea but is has limit from air tank capacity. how do you think about that? I decided to using compressed air from duct. If the duct is powerful enough then sacrifice for roll control nozzle is not so significant and I tested it works.
Hi Mixjsj,
You are right about the limited air quantity. In a bigger model you could use bigger tanks and shutting off the system when in level flight might help too. Your idea sounds fascinating too. You can always shut the bleed air chanels from the ducts too for level flight and get a cleaner flow for that purpose. Quote me not, I'm no expert Yet this is the place where they are so I think you'll get this sorted
raipe
Old Sep 24, 2012, 05:31 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
plan for plug almost complete
Are you going to glass the plug, and pull a fuse from it?
Also in first post you said on WS, "wing span 110mm ". I am guessing that is not right? What is total length, width?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 01:41 AM
Discussion Foamie f35 to go composite. DYORD Composites Fabrication 1 Jun 17, 2012 11:56 AM
Discussion Convered Dynamax Fan CoolerByTheLake Electric Ducted Fan Jet Talk 0 May 28, 2012 07:49 PM
Sold Cox Tailwind 40 convered to EP with Floats $400 LPU be69ar Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2012 11:01 AM
Discussion F35 successful Hovering sergiot78 VTOLs 37 Oct 09, 2011 12:42 AM
