Old Sep 08, 2012, 07:17 PM
CraigVMN is offline
Find More Posts by CraigVMN
CraigVMN's Avatar
Joined Apr 2012
Question
How do I make my quad snap roll/flip?
Iíve watched a lot of videos on here where you experienced pilots pull off flips/rolls that just ďsnapĒ right over. Whenever I attempt to do the same, I have to be at a high altitude, because my quad wants to do a large loop around. I have a DJI clone frame (450) with a 2200mah battery, 1000kv motors & 9x4.7 props. Iím using a DX6i for TX duty. Are there certain settings on the TX I need to use to get those snap rolls & flips?
CraigVMN is offline Find More Posts by CraigVMN
Old Sep 08, 2012, 07:21 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Most of the settings that need to be changed for fast flips/roll's are in the FC, what FC are you using?
shultz is offline Find More Posts by shultz
Old Sep 08, 2012, 07:22 PM
Techcoder is offline
Find More Posts by Techcoder
Carbon Flyer
Techcoder's Avatar
United States, FL, Fort Myers
Joined Oct 2010
You might mention the Flight Controller being used and what mode.
Techcoder is offline Find More Posts by Techcoder
Old Sep 08, 2012, 10:48 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
you might want to use a little higher KV motors with small props.
1200KV with 8X4.5 will give a faster response to throttle changes.
for a very short/tight flip you want to go full throttle during the first and last 90 degrees (roughly) of the flip.
dutchcommando is offline Find More Posts by dutchcommando
Old Sep 09, 2012, 05:03 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I used to be very careful about which of my quads I tried to roll, using just the more powerful ones with 1200kv and 1400kv motors. But as I became more confident, I discovered that I was able to roll all my quads, as long as I set up the multiwii right. Even my 450mm 1000kv 2212 with 8045 rolls and flips.
@Craig on your multiwii, you need to set these parameters:
RC rate: 1.6
Pitch & roll rate: 0.4
Yaw rate: 0.4
RC Expo: 0.7
Disclaimer: this will make your quad very, very responsive, don't do it unless you are really good at handling your quad with its current settings.
TS00 is offline Find More Posts by TS00
Old Sep 09, 2012, 07:59 AM
CraigVMN is offline
CraigVMN's Avatar
Joined Apr 2012
Yeah, I forgot about that - It's a quadrino zoom rev. 1e, using the 2.1 multiwii interface.
Old Sep 09, 2012, 08:02 AM
CraigVMN is offline
CraigVMN's Avatar
Joined Apr 2012
RC rate: 1.6
Yaw rate: 0.4
RC Expo: 0.7
Thanks TS, are those settings under "P"?
Old Sep 09, 2012, 10:57 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
No, they are not P settings, they are separate values altogether.
The ones I've hilighted in green:
Old Sep 09, 2012, 11:39 AM
CraigVMN is offline
CraigVMN's Avatar
Joined Apr 2012
Got it, then I "write" it to the board, yes?
Old Sep 09, 2012, 11:42 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Git it, then I "write" it to the board, yes?
Yup.
Question How do I stop my Yak 54 from rolling to the right when I do a loop? trevorcgross Beginner Training Area (Fuel) 16 Sep 17, 2012 01:37 AM
Question Can a Tricopter Do Flips and Rolls Like a Quad Can? Dave8888 Multirotor Talk 17 Jul 25, 2012 08:20 PM
Discussion How to do a snap roll Space Bat 3D Flying 2 Mar 24, 2012 04:10 AM
Video FY-X4 Quad flips/rolls Blue Flyer Electric Heli Talk 0 Feb 27, 2012 12:01 PM
Discussion How do I do a snap roll? Mattvr1ck Electric Plane Talk 36 Apr 08, 2010 07:03 AM
