Old Sep 29, 2012, 04:39 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Originally Posted by capntroy View Post
Really liking the engineering Pat! That shaft boss in the skeg is nicely done...
Shaft boss? I thought, ah f, now what do I do? Thanks for 'splainin' my faux pas.
woodybob is offline Find More Posts by woodybob
Old Oct 21, 2012, 11:31 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
It’s been awhile… this thread was off the grid.
I had some final shafts made for the Astro Flight belt drive. Basically, ¼” reduced to 3/16”. ¼” thru the plastic bearing block, then 3/16” for the uni. The brass tube between the belt drive and motor represents the uni for alignment purposes. It’s a tight fit but I think it will work OK. Need to make motor mounts now.
I opened up the deck area where the motor cover goes for as much access as possible. I also cut a hole over the rudder-post for access once the deck is glued to the hull. Made a hinged toolbox that gets screwed to the deck to cover that hole. I made the roof to the pilothouse removable for now, to make it easier to paint and get the windows glued in later.
Old Oct 21, 2012, 05:23 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I like the toolbox cover Pat, very clever.
Who's doin' your machine work?
Kmot is online now Find More Posts by Kmot
Old Oct 21, 2012, 08:03 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Pat
Realy looking good!! I think the roof looks great. Charlie
CaptCB is offline Find More Posts by CaptCB
Old Oct 21, 2012, 09:23 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Zolie, a buddy's neighbor.
Old Oct 21, 2012, 09:47 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Coming along nicely! Definitely digging the extra touches so far...
capntroy is offline Find More Posts by capntroy
Old Oct 24, 2012, 01:58 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Thanks boys.
I got the motor mount blocks made from a chunk of Ash. It was a little hairy inserting the brass inserts because my test piece wanted to split. I drilled oversize holes, just enough so the threads of the insert would still cut into the blocks. I put a nut & washer on the 4/40 hex screw so once the insert has seated, I could get the screw out without backing out the insert. ZAP them with some thin CA and they ain’t goin’ nowhere. The only fiddling left to do is shaping the foot of each mount to the hull.
The plain clam shell mount is from MPI. Part # ACC315.
Old Oct 24, 2012, 04:54 PM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Not a UCLA fan woodybob?
Old Oct 30, 2012, 11:37 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Got a little more done over the weekend. Stuffing tube glued in place, motor mounts glued to the hull. I carved some of the skeg down for the rudder support. 2/56” brass inserts are used to screw the brass support to the hull. I discovered that the SS 1/8” rod going thru the rudder is removable. Not sure why, but at a loss on how to glue it back into the rudder. Surprised that no cross bar was put on the 1/8” rod prior to molding the part.
Old Oct 30, 2012, 02:41 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
Sand the part of the rod that would be inside the rudder with some 100 grit or less sand paper. Use a small file for the shaft hole inside the rudder. You don't need to remove a lot of material just roughen up the surfaces.
Mix up a very small batch of 1 hour or longer epoxy. Put a little epoxy into one end of the rudder shaft hole, say the top. Wipe some on the rudder shaft, the part that will be inside the rudder. Slowly insert shaft into rudder, some epoxy should emerge from the bottom of the rudder when the shaft is pushed through.
Clean up the bottom of the rudder and exposed parts of rudder shaft. (Q Tips?)
Then put it aside and wait.
Apismelifera is offline Find More Posts by Apismelifera
Old Oct 30, 2012, 05:58 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Sounds good to me...thanks.
Old Oct 30, 2012, 06:50 PM
capntroy is offline
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Or I could just send you a new one Pat, the polymer should have adhered to the shaft better than that...
Old Oct 30, 2012, 07:15 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Thanks Troy, I'll see if some epoxy will work.
I scuffed up the shaft with a file, scrapped out the hole a bit on the resin rudder, and filled it with epoxy.
Hopefully that shaft will never rotate again inside the rudder.
Old Nov 11, 2012, 05:44 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Humm…
I got the servo placed, need to make final adjustments once I dig up a receiver and check travel. Got the drive done, made a jam nut for the prop from a brass nut, using Octura steel & moly-nylon thrust washers to help it keep it spinning smoothly. Found an old AF 208D ESC in a drawer, which should work nicely. Going to swap out the Zero Loss with Sermos for continuity. Once I dig up that receiver and get a motor battery, I’ll be able make some final component placement decisions in the DTF. (kitchen sink)
Old Nov 11, 2012, 07:38 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Clean, very clean!
Aerominded is offline Find More Posts by Aerominded
Build Log 1/24 scale Truckable Tow Boat keith S Scale Boats 79 Feb 05, 2016 01:14 PM
New Product 1/24 Truckable Towboat hull in fiberglass CaptCB Scale Boats 475 May 01, 2015 12:21 AM
Build Log 1/32 Truckable Tug JOHN SCALE BOAT Scale Boats 35 Oct 20, 2012 07:31 PM
Discussion 1/20 vs 1/24 fittings for 1/24 elco 80 PT boat? (mainly guns) Reckless Scale Boats 15 Apr 14, 2012 01:46 AM
Question 1/24 Truckable Towboat hull in fiberglass CaptCB Micro and Sub-Micro Boats 3 Apr 01, 2012 12:11 AM
