Old Sep 08, 2012, 02:59 PM
relorre is offline
Find More Posts by relorre
Joined Sep 2012
Hitec Optic 6 Sport 2.4ghz issue
I am newer to flying and just bought a new Tower Hobbies P51. Anyway, I bought the P51 along with a new Hitec Optic 6 Sport 2.4 ghz. I got it all set up last night and then I noticed a couple of problems. For some reason, the motor does not start running until the throttle is thrown halfway. Also, all of the other servos max out before any of the control sticks are maxed out. So I have a dead stick until half throttle, and then dead control sticks after about halfway through their full range. Any ideas? Thanks!
relorre is offline Find More Posts by relorre
Old Sep 08, 2012, 03:08 PM
relorre is offline
Joined Sep 2012
Also, I am aware that there is a safety on the motor/esc where you have to "arm" it before it will work. This is not the problem.
Old Sep 08, 2012, 04:24 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Did you reduce Ch3 trim to 60<80% or even minimum, alternatively adjusted EPA almost to maximum?
Do this prior to set up of any new ESC for each model as an Optic 6 Sport is similar to all othert computerised Tx, refer:
. EPA, ATV, Dual & Triple Rates, Expo Differences & Caution + ESC / BEC Set Up
Further information is available under:
. Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Sep 08, 2012, 05:13 PM
relorre is offline
Joined Sep 2012
Alan T.
I have tried that with no luck. I could not find anything in the links you gave me that helped. Thanks for the help. Really hoping to figure this out.
Old Sep 08, 2012, 06:20 PM
A.T. is offline
Joined Aug 2002
1. In case original ID-Setup was not accurate, please reset transceiver ID:
AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure for
........Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver.
If problem still exists, open another model memory, reset that to clear any possible residual info
as per manual page 24, copy attached.
1. Reduce throttle trim to mimimum but do not extend any EPA, reprogram the model and reset ESC.
2. Check that all servo throws are then normal, if so adjust EPA to ensure no servo are being driven to far or to short.
If above fails, email direct to:
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada. (- Closed Weekends)
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Hitec USA Support Forum Sticky:
AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Old Sep 10, 2012, 07:01 PM
relorre is offline
Joined Sep 2012
I called Hitec today and they think I got a defective Tx that was not calibrated correctly when it was made. Got a new one coming before I even have to send back the defective one. Best customer service I have had in a long time! Let's hope the next one works.
Discussion Decision, hitec Optic 6, Optic 6 sport, dx6i OR?? MikeontheBike Radios 38 Sep 21, 2012 10:42 PM
Sold Hitec Optic 6 Sport 2.4ghz TX DuaneV Aircraft - General - Radio Equipment (FS/W) 2 Jul 23, 2012 08:58 PM
Discussion buddy lead with 2 hitec optic sport 2.4ghz radio help RyThEm Beginner Training Area (Aircraft-Electric) 6 Apr 30, 2012 06:05 AM
Discussion Upgrades for Optic 6 Sport and Optic 6 Sport 2.4GHz now available online. A.T. Radios 0 Dec 28, 2010 09:56 PM
Discussion 6-Channel 2.4GHz Hitec Optic 6 Sport fernanduu Mexico 4 Sep 03, 2010 03:01 PM
