Old Sep 08, 2012, 02:51 PM
BP1011 is offline
Find More Posts by BP1011
Joined May 2010
Dodger EP 3 Channel Thermal Glider 1980mm (ARF)
New glider from HK
http://hobbyking.com/hobbycity/store...80mm_ARF_.html
Has anybody test the specific Glider ?
It reminds the Gentle Lady one. Any flight characteristics?
Will be suitable for F5J flight?
BP1011 is offline Find More Posts by BP1011
Old Sep 11, 2012, 06:04 AM
BP1011 is offline
Joined May 2010
Description:
Old Dec 13, 2012, 03:51 AM
Heliosphere is offline
Find More Posts by Heliosphere
Joined May 2011
I ordered one of these this week, hoping to learn how to catch thermals with it as it was cheapest powered plane I could find with a very low wing loading. Hoping the 900 g flying weight is accurate and it won't need too much nose weight to balance.
Will upload pictures when it arrives.
Heliosphere is offline Find More Posts by Heliosphere
Old Jan 10, 2013, 03:47 PM
S1MON is offline
Find More Posts by S1MON
Joined Nov 2010
Has anyone flown this glider yet? If yes could you please pass on your thoughts on it?
I have been thinking of going back to basics and building a Gentle Lady however I suspect this is based on the GL and is cheaper in ARF form than the GL kit!
S1MON is offline Find More Posts by S1MON
Old Jan 10, 2013, 06:09 PM
Joined May 2011
Hi S1mon, I'm edging slowly closer to flying mine. We did an unboxing video of it here:
Unboxing the Hobbyking Dodger EP Thermal Glider (3 min 33 sec)
Not sure when I'll actually be able to fly it as the motor I was hoping to use turned out to not be suitable, going to order one of these to use instead: http://www.hobbyking.com/hobbyking/s...er_1100kv.html
I was happily surprised at how light it is, about 480 g sans motor/battery/sans/electrics.
Old Jan 14, 2013, 02:31 PM
S1MON is offline
Joined Nov 2010
Originally Posted by Heliosphere View Post
Hi S1mon, I'm edging slowly closer to flying mine. We did an unboxing video of it here: http://www.youtube.com/watch?v=umr1htGvpZ8
On the strength of your video (watched and ordered before I saw this post) I ordered a Dodger... it does look good value for money. I was considering building it as a pure glider but I'll be interested to see how you go on with that motor. By the way, what ESC will you be using?
Looking forward to hear how you go on with it.
Simon
Old Feb 03, 2013, 10:20 AM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
I am supprised that there is not more interest in this model, I sure want one and am only waiting till it get to the USA wearhouse to order it.
Bob
oldfish is offline Find More Posts by oldfish
Old Apr 08, 2013, 12:54 PM
S1MON is offline
Joined Nov 2010
Well I wanted mine to be a pure glider so I've given it a new nose.
I will get it finished this week and will be looking forward to some light winds
Old Jun 13, 2013, 02:18 AM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
I'm thinking about buying one of these but there isn't much info on it in the forums.
How does it fly?
Did you get the 950 gram flying weight or is that optimistic?
Can the wing be set up as two piece?
Thanks for any info.
John Gallagher is offline Find More Posts by John Gallagher
Old Jun 13, 2013, 10:58 PM
Lindenwold, NJ, USA
Joined Dec 2000
I realized that with shipping, the Dodger is more expensive than a Tower Hobbies Vista. That's probably why it isn't popular.
Old Jun 14, 2013, 07:53 AM
Joined May 2011
Hi John, I've had a few of flights of my Dodger now. Only slope soaring, haven't tried thermalling yet. It flies quite nicely, very sedate. Just about flies itself once it's trimmed! It was a bit underpowered with an 1100kv motor with 8 x 4 prop, climbed significantly better with a 9 x 4.5.
I had to add about 95 g of nose weight to get mine to balance (probably because I've used quite a small motor). I think it came out at about 880 g all up with a 1.3 Ah 3s lipo.
Old Jun 14, 2013, 01:51 PM
Lindenwold, NJ, USA
Joined Dec 2000
Thanks for the info.
880g is pretty good. The ballast is understandable since the nose does look short. Too bad they didn't stretch the nose a little when they copied the basic design of the Gentle Lady.
I read the manual but couldn't find any reference to the airfoil. Is it a flat bottomed airfoil?
John
Old Oct 29, 2013, 12:45 PM
pysonya is offline
Find More Posts by pysonya
Arizona Aviator
pysonya's Avatar
Prescott AZ
Joined Dec 2004
Anyone got an update on building/flying the Dodger?
pysonya is offline Find More Posts by pysonya
Old Nov 18, 2013, 06:35 PM
oldfish is offline
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
Now that it has showed up in the USA I have order mine. If it flies half as good as the plane its modeled after its going to be a great glider
Bbo
Old Apr 01, 2014, 06:05 PM
Rampage is online now
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
Bump, I just saw this.
Is it as much an Electra clone as it looks? If so, I'm definitely interested. Learned to fly on one of those and I'd love one if it's as light as the Electra was.
Rampage is online now Find More Posts by Rampage
Sold NIB Omei 2000 EP Electric powered thermal glider. jbj620 Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2012 06:39 AM
For Sale Antique 3 Channel Pusher Airplane with ENYA 11CX Engine (ARF) $75 PICS!!! olivazane1 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 31, 2012 04:51 PM
Sold Kyosho Soarus II ARF EP Thermal Glider NIB gliders Aircraft - Electric - Airplanes (FS/W) 3 Feb 07, 2008 09:55 AM
Help! mouton 1600V Ep thermal glider dc33 Sailplane Talk 2 Jul 19, 2007 09:43 PM
Rave good 3-3.5 meter thermal glider Ryan Archer Thermal 13 Aug 30, 2005 04:47 PM
