Old Sep 08, 2012, 01:01 PM
Nin3rsAllDay is offline
Find More Posts by Nin3rsAllDay
Nin3rsAllDay's Avatar
United States, NV, Las Vegas
Joined Jun 2012
fuel proofing LEDs
does anyone know a way to fuelproof LED strips? I have three small sections of LEDs that I need to fuelproof, but I don't want to go buy a whole role of clear monokote just for a little piece.
Nin3rsAllDay is offline Find More Posts by Nin3rsAllDay
Old Oct 08, 2012, 08:40 PM
Timtreo is offline
Find More Posts by Timtreo
Click my name for night blades
Timtreo's Avatar
United States, PA, Warminster
Joined Nov 2011
A 2 part spray clear coat, need a respirator to use it. If you don't have a spray gun you might be able to bring it to an auto body place and they might spray it real quick for you the next time they do some clear coat work. You can also get a 2 part spray in a can, but it's pretty expensive and it's only good for less than 24 hours after you mix it. Good luck! Tim
Timtreo is offline Find More Posts by Timtreo
Old Oct 08, 2012, 10:16 PM
Joined Jun 2012
I did a test run with some lusterkote and that seems to be working so far.
Old Oct 08, 2012, 10:55 PM
Timtreo is offline
Timtreo's Avatar
Joined Nov 2011
I hear that stuff only works up to certain nitro percentage but you might ok with whatever fuel you are using.
Old Oct 16, 2012, 02:45 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
How about using CorrosionX? That is the stuff us float flyers (and coastal flyers) spray on our electronics and rx's to prevent water damage. I would imagine it is fuel proof, but cannot confirm...
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Oct 16, 2012, 02:50 PM
Joined Jun 2012
I'm still testing the lusterkote as it is supposed to be fuelproof for up to 15% nitro which is what I use. If that ends up failing I will probably look into the corrosion X or may just breakdown and get some clear monokote.
Question Best fuel proof spray paint livin on edge540 Scale Fuel Planes 13 Apr 23, 2015 11:44 PM
Discussion Best fuel tank system (proof) The search for the best performing tank setups schusterjo Fuel Plane Talk 414 Aug 29, 2012 12:19 PM
Help! Fuel proof pearl white cowl drdemarcodc Painting and Finishing Tips 2 Jul 17, 2012 10:01 AM
Discussion How do you keep fuel proofing out of the engine mount Blind Nuts? Tom.in.Maryland Beginner Training Area (Fuel) 6 May 18, 2012 05:10 PM
Discussion Fuel Proofing Tom.in.Maryland Beginner Training Area (Fuel) 7 May 18, 2012 09:39 AM
