This thread is privately moderated by Dani123, who may elect to delete unwanted replies.
Old Sep 08, 2012, 01:01 PM
Dani123 is offline
Find More Posts by Dani123
Dani123's Avatar
Israel
Joined Jan 2005
Build Log
Voltage Regulator 2s to 5v
This is a mini build (solder) log of my voltage regulator for DLG use.
After reading various threads on the subject and collecting many advices, I decided to make my own voltage regulator.
Why? Well, there are couple of reasons for that...
First, up until now I've flown my gliders on 4 NiMh 400mAh cells. Those provide sufficient time for 2 analog and 2 digital servos, but when I went for 4 digitals (2xJR285 2xDS09) my max flying time went down.
Second, trying something new is always welcome.
And finally, I've been always confident in my soldering skills, I always solder my own packs, switch jacks and the wiring in the pod, with no issues.
So, here we go.
I've found this regulator for the job: KA278RA05C. This is a low dropout voltage regulator. It is important if you run the pack to the limit. This regulator is rated up to 2A, so no issues here for overload. The unit has 4 legs as it can deliver adjustable voltage along with a constant 5v - which I'm interested in.
One 0.1uf capacitor is soldered across input terminals and another slightly larger 22uf is placed on the outputs.
The whole assembly is shown in the pictures, "standard" dead bug installation, with my connectors of choice. Female JST for the input and servo connector for the output.
I used my standard lightweight leads (white). These are very light and high quality, these come from wired strain gages... And, I have tons of them so I use them wherever I can.
The whole thing resulted in 4.8gr ready for use. Next, I have to wait for my LiPo to arrive and will install it in my SG instead of the NiMh pack.
Next, I should try to make it on a PCB to make it neater. Maybe I should prewire the SJ to the regulator for the next one.
Dani
Dani123 is offline Find More Posts by Dani123
Old Sep 08, 2012, 05:13 PM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
How come you use a capacitor across some of the wires?
zanek is offline Find More Posts by zanek
Old Sep 08, 2012, 10:44 PM
Dani123 is offline
Dani123's Avatar
Israel
Joined Jan 2005
Hey zanek
There are two actually. They help to smooth out the voltage and are recommended in the data sheet of the regulator.
Dani
Old Sep 08, 2012, 10:54 PM
zanek is offline
Agressive driver
Joined Jun 2011
Okay
New Product Introducing 5v Gyro/Tail Servo Voltage Regulator - Helicopters perfectregulat Product Announcements 1 Jun 04, 2008 02:53 PM
Discussion Where to get voltage regulator 5v davef27 Aerial Photography 17 Aug 08, 2007 03:17 PM
Discussion Simple 5V/5A regulator with voltage monitor Rad Racer Power Systems 4 Apr 23, 2007 12:33 PM
7.2-7.5V Voltage regulator Bleriot Power Systems 4 Dec 13, 2001 12:22 AM
