Old Sep 10, 2012, 01:27 PM
fogflyer is offline
Find More Posts by fogflyer
Northern California
Joined Sep 2002
Thanks guys, I going going to a guys house this evening to try and see if his TX with Anylink will connect. That should pretty much confirm the plane is DOA if it does not connect. Then I will contact Great Planes. I appreciate all the help!!!
fogflyer is offline Find More Posts by fogflyer
Old Sep 10, 2012, 03:05 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Good luck and let us know what happens.
eltreato is offline Find More Posts by eltreato
Old Sep 15, 2012, 11:51 PM
fogflyer is offline
Northern California
Joined Sep 2002
The plane is on its way back to Great Planes for a replacement.
They were very good about emailing me a paid return label for the plane.
Now just waiting for it to come back.
Old Sep 16, 2012, 01:50 AM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
Well I hope you get it sorted out quickly. I had mine out today for the first time in a while. Such a fun plane
Old Oct 08, 2012, 02:06 PM
fogflyer is offline
Northern California
Joined Sep 2002
Well, I got the replacement plane from Great Planes. Took over two weeks, which I thought was a little excessive for a DOA airplane, but the new one fired right up. Unfortunately, when I went to install the landing gear, I realized that one of the mounts had been glued in 90 degrees off from where it was supposed to be. No biggie as I was able to pop it off and reglue it without doing any damage, but I am not too impressed with GPs quality control so far.
Anyway, flew it four times yesterday and it flys great! :-)
Landing.... well that is another story
I was able to grease it on a couple of times, but usually it would bounce a foot in the air after touching down and then scape up a wingtip. It is definitely a challenge to land well!
I seem to have the best luck just going power off, what do you guys do?
Also, any suggestions on what to do to strengthen the underside of the wingtips so I don't scape them off with my landings? I was thinking of smearing a light coating of epoxy along the edges.
Also wanted to give a tip regarding the landing gear.
I have read a few complaints about how difficult it is to take the landing gear off.
Well, the trick is that you do not insert the landing gear all the way in. The manual says to insert the gear until the wire touches the little plastic tab.... DO NOT go OVER the tab and lock it in place. It seems like it is made to go over the tab and lock in, but it does work perfectly fine not locked in and then it pulls out very easily to store in the box.
Oh, one more thing...
My new replacement plane has a buzz, like a twitching servo, once you plug the battery in. I can't see any control surfaces twitching and it seems to fly fine, but I was a little worried about this. Anyone else have this noise?
Old Oct 09, 2012, 03:07 AM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
good to hear they sorted you out with a new plane. I land exclusively on grass and it has been hard on the fragile wings, but nothing a little ca and 5 minutes can't fix. As for landings about 15% power works best for me on the grass with a flare to bleed airspeed while keeping a reasonably flat glide slope. it always takes me lots of room to land unlike most prop driven micros. Happy flying.
Old Oct 09, 2012, 01:50 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
The noise is digital servos and try scotch tape under the tips.
DJ
D Johnson is offline Find More Posts by D Johnson
Old Oct 09, 2012, 02:16 PM
fogflyer is offline
Northern California
Joined Sep 2002
DJ
So the noise is normal and nothing to be concerned about?
Old Oct 09, 2012, 03:37 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
correct
Old Oct 10, 2012, 12:07 AM
fogflyer is offline
Northern California
Joined Sep 2002
correct
Great!
Thank you!
Sold F-16 and F-86 80mm edf airframes drats Aircraft - Electric - Jets (FS/W) 3 Jul 03, 2012 04:13 AM
Sold Freewing F-86 and Starmax F-35 Kenneth Henius Aircraft - Electric - Jets (FS/W) 9 Jul 02, 2012 01:16 AM
For Sale F-16 and F-86 80mm edfs drats Aircraft - Electric - Jets (FS/W) 3 Jun 28, 2012 11:24 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 01:00 PM
For Sale Freewing F-86 and Starmax F-35 Kenneth Henius Aircraft - Electric - Jets (FS/W) 3 Mar 02, 2012 11:59 AM
