Old Dec 11, 2012, 04:50 PM
beach1 is online now
Find More Posts by beach1
E motor choice
I have the 2500 KV Hacker A20-6xl motor in an Ava Pro Flapped 4 and a 3.9 meter Maxa. On a 4 cell TP 1300'pack and a 16x10 prop....both models hit 200 meters in less than 17 seconds.....motor, battery pack, speed controller all run very cool and efficient. You can run this motor on 3 cell Lipo....just go up in prop diameter
beach1 is online now Find More Posts by beach1
Old Dec 12, 2012, 12:13 PM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
For all you Hacker lovers, I have a Hacker A20 6XL 10 pole 2500kv motor coupled to a Maxxon 4.4:1 gb that only has about 5 runs on it. $95 shipped to your door.
Two offers pending so consider the motor sold. Walt
IBWALT is offline Find More Posts by IBWALT
Old Dec 15, 2012, 11:09 PM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
Must one buy the motor and gearbox separately, or does someone sell the motor with the gear box installed?
John Walter is offline Find More Posts by John Walter
Old Dec 16, 2012, 12:44 AM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
John,
You can get with or without gearbox. For our purposes (smallish diameter to fit, enough kick to turn a big prop) the gearbox makes sense. https://www.aero-model.com/8_64/Moto...20-Series.html
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Dec 16, 2012, 08:55 AM
USA, IL, Naperville
Joined Feb 2003
Thanks for the link JT.
Old Dec 16, 2012, 12:05 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
This is a cheaper gearbox option:
http://www3.towerhobbies.com/cgi-bin...P?I=LXWVT4&P=8
It seems to survive up to 1000W:
http://www.rcgroups.com/forums/showthread.php?t=1686872
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Dec 16, 2012, 01:09 PM
Neil Howard is offline
Find More Posts by Neil Howard
Nelson,New Zealand
Joined Apr 2004
I have been trying to place an order with Reisenauer for close on 3 weeks but don't get any replies , can someone that has previously dealt with them tell me the easiest way to make reliable contact
Neil Howard is offline Find More Posts by Neil Howard
Old Dec 16, 2012, 08:45 PM
ScottTomasello is offline
Find More Posts by ScottTomasello
ScottTomasello's Avatar
Portola, CA
Joined Feb 2011
Check your junk inbox. All of their e-mails on my order went there.
ScottTomasello is offline Find More Posts by ScottTomasello
Old Dec 17, 2012, 11:02 PM
NorCal Hobbies is offline
Find More Posts by NorCal Hobbies
NorCal Hobbies's Avatar
Joined Feb 2007
Peggy pepper!
NorCal Hobbies is offline Find More Posts by NorCal Hobbies
Old Dec 26, 2012, 10:34 PM
Billymac is offline
Find More Posts by Billymac
In a little camper
Billymac's Avatar
United States, FL, Jacksonville
Joined Sep 2005
Just rec'd my motor... A month later... Thought it would never get here.
Looks like a nice set-up
Bill
Billymac is offline Find More Posts by Billymac
Old Mar 19, 2013, 10:05 AM
dharban is offline
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
I just completed the first test flights on my new Maxa system (should be applicable to Supra too) and have found a very nice combination.
I am using a Neu 1107-1.5Y with a P32 6.7:1 gearbox. Battery is a TP 4S 850 65C. Prop (right now) is an Aeronaut 14x9 mounted on a Vladimir hub. Weight of motor, gearbox and battery is 9.1 ounces. The plane (servos in tail) balances without any tailweight. Plane launched to 200 meters into about 10 mph wind 150 meters out in 17 seconds. 2300 vertical fpm. Input wattage was about 650. I like this motor because I can go to a 3S 1300 battery and a larger prop and probably get a little more efficiency without adding any weight. And based on the measured temperature rise in the motor, I suspect that I could go to 800 or more watts by going with a 4S 1300. Personally, though, the performance that I am getting with the current is exactly what I was seeking -- the ability to get to altitude into 15+ mph winds and 300 or so meters to windward. I will likely throttle back for launching into lighter winds. This is a very sweet setup.
It is the second iteration of my original setup which used a Neu 1105-2.5Y with a Maxon 4.4:1 gearbox and a TP 3S 850 65C Battery. Weight of motor, gearbox and battery was 6.8 ounces. This setup took about 25 seconds to get to 200 meters in no wind and 200 meters out. It did not give me any headroom when the wind came up. This setup ran at about 450 watts. The motor was fine with this, but the stock Maxon gearbox was a little beyond its stated limit.
Now I suspect that if someone was a real stickler for weight and wanted to get to 650 watts or so that perhaps the Neu 1105-4.5D with the P32 6.7:1 gearbox and a TP 4S-850 or TP 3S-1300, properly propped, would behave like my 1107 and would weigh only about 7.7 ounces. This, of course, pushes the motor farther beyond its stated limit -- but my tests on the 1105 at 600 watts showed about a 75 degree rise for a 30 second motor run. It should be just fine.
At any rate, the 1107 combo is the very best I have found since I started this. I have run the Neu 1110 in a Supra and, at least for me, it had more power than I could use effectively in ALES competition. The current combo is sweet and it does not really press any of its components too hard.
Happy Landings,
Don
dharban is offline Find More Posts by dharban
Old Mar 19, 2013, 03:09 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Don,
Nice to hear you've got a good setup.
I've got an 1107 2y w/4.4/1 Maxon in it now. Running an 850 4s and probably can prop up a bit from the 14x7 that's on there now. I'm also going to test the new 70c TP 4s in 850 and 1300. No test flights yet. See attached photo. That's outside my door about 10 minutes ago. At this
rate I might get it set up by the Polecat.
I've got a 1110/3900 w/6.7 p29 with an 18x10 in a new Pulsar Pro and fully expect that it will go up quite nicely.
Preston
jaizon is offline Find More Posts by jaizon
Old Jun 09, 2013, 07:21 PM
keithmoor is offline
Find More Posts by keithmoor
Australia, VIC, Croydon
Joined May 2011
Originally Posted by jaizon View Post
Don,
Preston
I have a similiar set up in a heavy 3m E Strega @ 2700g.---running a Neu 1107 2y with the Tower 4.3 GB
Motor is a pre 2008 3300kv which I had sitting around unused.
Currently running a 13 x 7 on 1800 mah 4s she runs quite fast once she gets going so I would like a bit more thrust ---undecided whether to go :-
4s 13 x10 58amps 728watts 4187g thrust or
3s 14 .5 X 13 59amps 584 watts 3900 g thrust
I am leaning towards the latter as I thought it might easier on the motor ?
My other Glider is my all round Sports/Thermal Machine :-
Xplorer 4m ST with Neu 1506 1.5 y 6.7gb on 4s with 17 x 10 prop
Regards Keith
keithmoor is offline Find More Posts by keithmoor
Old Jun 09, 2013, 07:47 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
Regards Keith
I ended up with a 15/8 carbon 850 70c 4S TP for my e-Supra SC (60 oz AUW) and consistently get to 200 meters in 15 seconds +/-. No problem.
My 4m Xplorer is not an ST. AUW around 89 oz. Same motor/gb but on 3s 2250 TP 70c with an 18.5x12 . Gets up in around 20 seconds. My windy plane.
Good luck.
Preston
Old Jul 10, 2013, 12:54 AM
Joined May 2011
Good luck.
Preston
I just tried an Aeronaut 14 x8 with my neu 1107 2y /4.3 Gb and 2200 mah 4s Turnigy Nanotech A spec ---Wattmeter shows 78amps and over 1000watts and e calc shows 76 amps and 1024 watts (at full charge)
What are your figures on that set up Regards Keith
Wanted E-Supra pro NorCal Hobbies Aircraft - Sailplanes (FS/W) 0 May 11, 2012 11:43 PM
Discussion Xplorer E motor choices scarab Electric Sailplanes 7 Feb 28, 2012 09:57 AM
Question Supra electric motor choice mty Electric Sailplanes 15 May 15, 2011 05:15 AM
Help! e-Supra Motor Recommendation Curtis Suter Electric Sailplanes 5 Dec 07, 2010 07:37 AM
Help! Suitable motor for a Supra style E-glider century_series Electric Sailplanes 13 Sep 20, 2010 05:15 PM
