Old Nov 23, 2012, 07:59 PM
Billymac is offline
Find More Posts by Billymac
In a little camper
Billymac's Avatar
United States, FL, Jacksonville
Joined Sep 2005
Hi
Have been watching this thread for a couple of weeks or so, and have a question that I know you can help with
Which version of the Supra do you have?? Older or the newer F5J version?
I have the newer F5J version and thought a Hacker B-40 w/ Gearbox would be fine. But it turns out to be way too nose heavy as it weighs around 6oz. The newer fuse has the servos in the nose on a shelf instead of the tail
What are my options?
All the best,
Bill
Billymac is offline Find More Posts by Billymac
Old Nov 23, 2012, 09:02 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
See post #12 of this thread. I almost got this combo and still may. 3.7 ounces.
jaizon is offline Find More Posts by jaizon
Old Nov 24, 2012, 07:23 AM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Originally Posted by Billymac View Post
Hi
All the best,
Bill
I too have the F5J fuse with servos (DS368 for stab, DS285 for rudder) on the deck. This leaves no place to put the battery other than behind the deck (under the wing) in order to minimize the weight in the tail to balance the plane. I ended up with about a 24 g slug in the tail. All up weight with a TP 1300 65C motor battery and Hyperion 850 LiFe flight pack battery is 68 oz. Not bad considering and the plane flies fine.
The batteries are mounted on a brass tongue that anchors to the rear edge of the deck, and must be inserted with the nosecone removed. Not a simple, quick change, but possible between ALES rounds.
If I were to do it again, I would get the conventional e-rudder and put the stab/rudder servos in the tail, the flight pack battery under the wing, allowing the motor battery to be quickly/easily changed by mounting it on the deck.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Nov 24, 2012, 06:21 PM
Billymac is offline
In a little camper
Billymac's Avatar
Joined Sep 2005
Did you guys order directly from Reisenauer or is there someone here in the US that carries that motor set-up?
I think that is the way to go.
Many thanks,
Bill
Old Nov 24, 2012, 06:43 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
I don't know of anyone in the U.S. Just as easy to order from Reisenaur which is what I'm going to do. Probably be here in about 10 days from when I order.
When I ordered my Supra I chose to go with the long nose fuse and not the newer one. Looks like it may have been the better choice.
Old Nov 24, 2012, 07:47 PM
Billymac is offline
In a little camper
Billymac's Avatar
Joined Sep 2005
I think your right on that mark.
A friend has the older version with a Hacker B-40 and it does just fine! Balance wise and flying. He let me fly it once and I was really impressed. So much that I had to order the fuse. I already have a Supra Pro.
I guess the Dragonfly Strong is going into the corner........Naaaaaah too good of a flyer
All the best
Bill
Old Dec 08, 2012, 08:30 PM
beach1 is offline
Find More Posts by beach1
E motor Choice
Here is a very good power setup for Maxa, Ava Pro Flapped, Aspire
Etc.....Hacker A6 20XL with 16x10 prop and TP 1300 4 cell pack. This gives you 200 meters in 16 to 17 seconds....what more do you want....
beach1 is offline Find More Posts by beach1
Old Dec 09, 2012, 11:11 AM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
How many watts at the motor for that set up?
Old Dec 10, 2012, 07:28 AM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
Just did my own number crunching on this A20 setup on propCalc. I come up with 325 watts at the motor. Hardly seems to be enough power to get a 60+ oz plane up to 200 meters in 17 seconds.
Old Dec 10, 2012, 09:05 AM
dharban is online now
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
God love 'em. If motor selection wasn't confusing enough, Hacker sells two different A20-6XL's -- a 10 pole motor rated at 2500 Kv and an 8 pole motor rated at 3500 Kv. This will result in a significant difference in the selection of optimal propeller and battery. Don't ask me how I know.
Thanks a lot, Hacker.
Happy Landings,
Don
dharban is online now Find More Posts by dharban
Old Dec 10, 2012, 10:35 AM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
Don't know which one I have (A20-6XL, 16-10, TP 3S 1300mah 65C), but I get 425 Watts static. For my 68 oz e-Supra that comes to 100 Watts/lb, and plenty enough to get to 200M in 20 seconds.
JT
Old Dec 10, 2012, 10:55 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
JT
Is that with a gearbox? Even a 2500KV motor would have difficulty swinging a 16x10 prop on 4S I think.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Dec 10, 2012, 11:47 AM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
Kevin
Yeah, 4:1 gearbox. Sorry for the confusion.
JT
Old Dec 10, 2012, 04:06 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Guys, that A20 motor for both the Supra and Tragi are just really nice setups, they do work. I am flying just as JT is on 3S and 16/10.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Dec 10, 2012, 07:36 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
That is really great info.
Wanted E-Supra pro NorCal Hobbies Aircraft - Sailplanes (FS/W) 0 May 11, 2012 11:43 PM
Discussion Xplorer E motor choices scarab Electric Sailplanes 7 Feb 28, 2012 09:57 AM
Question Supra electric motor choice mty Electric Sailplanes 15 May 15, 2011 05:15 AM
Help! e-Supra Motor Recommendation Curtis Suter Electric Sailplanes 5 Dec 07, 2010 07:37 AM
Help! Suitable motor for a Supra style E-glider century_series Electric Sailplanes 13 Sep 20, 2010 05:15 PM
