Old Sep 08, 2012, 06:51 AM
Saman R is offline
Find More Posts by Saman R
Joined Sep 2012
Help!
setup 6s trex 450 pro v2
hi friends... im trying To upgrade my Trex 450 pro v2 from 3 cell to 6 cell Motor and battery ... i want to replace the 3 cell dualsky battery and align motor with Turnigy 6 cell , 1300 mah battery And Scorpion HKII-2221-2010kv motor ...
But I have a problem ... My 450 conopy is very small and 6 cell battery will not fit into it ... im live in Iran... in Iran i cant find a appropriate conopy but i can buy from hobbyking.com ... can i use this conopy for Trex 450 pro v2 and 6s setup ?
http://www.hobbyking.com/hobbyking/s..._Trex_450.html
Saman R is offline Find More Posts by Saman R
Old Sep 08, 2012, 01:02 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
skip, duplicate post
finguz is offline Find More Posts by finguz
Old Sep 08, 2012, 01:05 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
no thats a regular 450 canopy, it won't work on your pro, you need one that says 450 pro. You could always fly without a canopy.
Take a look at this recent forum below, I think a couple guys have modded their canopy to accept the bigger battery. Also it is a discussion about switching to 6s, might interest you as well.
In my opinion you should just stay with 3s. Just get a 2200mah batt instead of that 1300mah you have. What kind of flight times do you get with that batt? 3minutes?
Here's the link:
http://www.rcgroups.com/forums/showthread.php?t=1603107
Old Sep 09, 2012, 12:05 PM
Saman R is offline
Joined Sep 2012
thanks finguz ...
Old Sep 10, 2012, 12:05 AM
marioa111 is offline
Find More Posts by marioa111
marioa111's Avatar
United States, CA, Rialto
Joined May 2007
I am using the Gens Ace 1200mah 35c 6s they fit under the canopy. they are smaller than the 2200 3s.
Gens Ace 6s 1200mah 35c Align 450 pro Mavrikk Blades (4 min 19 sec)
marioa111 is offline Find More Posts by marioa111
Old Sep 10, 2012, 05:39 AM
Saman R is offline
Joined Sep 2012
http://www.youtube.com/watch?v=0DCaqhk_jbQ
wow... very best fly ... please help me ... Which of this canopies in hobbyking.com can use for trex 450 pro v2 with 6s setup ? If I couldn't find the scorpion motors in iran , can i get higher power with 4s setup and align motor than current 3s ??
Old Sep 11, 2012, 01:38 AM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
I have been running stretched 6s helis for years and recently 12s versions with dual 1300s. HK sells two battery sizes in the 1300ma range. One is longer and thinner and should work. The other is the traditional "fat" and short 1300, of which I can fit two of under my canopy's. You will have to relocate your canopy pin holes or canopy pins to do what I am doing. But the longer battery usually fits in the pro with few mods. And lots of guys are doing it. Once you fly with a proper 6s setup there is no going back. The performance changes are seat of the pants miles better with cooler electronics to boot. Not to mention I have packs with well over 350 cycles and a few with more still performing well.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Sep 11, 2012, 03:19 AM
marioa111's Avatar
Joined May 2007
I have cut down my frames to make it easy for the lipos to fit for 4s. now that I have the gens ace 1200 mah they are the same size as the 2200 mah 3s so they would fit under the stock 450 pro canopy with out the mod. I don't see why can't use the stock 450 pro v2 canopy. it should fit fine. maybe I can load some pics soon.
if you are going with the 4s setup I was using the scorpion 2221-10 motor with a 12t on the stock pro gears. the motor is around 3000kv I think hobbyking would carry a motor that can run 4s keep it around 3000kv. if you go 6s try 1700kv
Im using the 450mx 1700kv align motor in the video and loving it, I hope this helps. if you have any more question pm me anytime
Old Sep 11, 2012, 04:25 AM
Saman R is offline
Joined Sep 2012
veeeeeeeeerrrrrrrrrrrrrrrry thank you my friends ... Unfortunately i cant speak english very good ... and i cant understand some of your purpose ( can you speak persian ?? !!) ... please upload your trex 450 4 cell setup pics for me ...
Old Sep 11, 2012, 10:31 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
If your Prov2 has the BL450MX 1700kv, you don't need the scorpion as the 450MX 1700kv is rated up to 6s. The HK-2221-1630 is a better 6s motor. Remember to use the correct pinion and an esc that can handle 6s. One of the best, small and light esc to use is the YGE60A esc.
As for battery, the nano-tech 1300mAh batteries, running in series, are good batteries and they fit perfectly under the stock Prov2 canopy. If you don't want to use "y" cable to run the batteries in series or to connect the batteries, permanently to run in series, the current 6s battery from Pulse also can be used.
This pulse 6s battery http://helidirect.com/plu35-13506-pu...es-p-27129.hdx
chopper62 is offline Find More Posts by chopper62
Old Sep 18, 2012, 09:43 AM
jnmardister is offline
Find More Posts by jnmardister
rc aircraft crasher
jnmardister's Avatar
United States, MI, Lansing
Joined Sep 2012
im not ready to get into 3D yet but have wondered what the benifits of higher cell batteries are. obviously more performance but in what way?
jnmardister is offline Find More Posts by jnmardister
Old Oct 20, 2012, 01:16 AM
mrmarc is offline
Find More Posts by mrmarc
Not da momma!
mrmarc's Avatar
Joined Jul 2012
With a 6S setup, the current draw is approximately halved, so there is more headroom for the motor. This translates to less bogging of the motor. Because of the lower current draw, the electronics are also cooler. 40A vs 20A is rather considerable.
mrmarc is offline Find More Posts by mrmarc
Old Oct 21, 2012, 01:04 PM
persian heli is offline
Find More Posts by persian heli
persian heli's Avatar
Joined Oct 2012
Hi saman,
my name is Dariush and I can speak persian,I'm hier
persian heli is offline Find More Posts by persian heli
Wanted WTT trex 450 pro v2 FBL for trex 250 FBL smoothb10 Aircraft - Electric - Helis (FS/W) 1 Jul 13, 2012 09:31 PM
Discussion Trex 450 Pro V2 6S 16T pinion! jetblue2135 Mini Helis 0 Jun 19, 2012 11:47 PM
Sold Align Trex 450 Pro V2 FBL for sale 6s setup Raydee Aircraft - Electric - Helis (FS/W) 1 Jun 17, 2012 06:03 PM
For Sale 450 v2 with 6s cell setup bnf jenna Aircraft - Electric - Helis (FS/W) 3 Apr 26, 2012 06:55 PM
For Sale 450 v2 with 6s cell setup bnf or trade for a brushless mcpx or airplane carbonz jenna Aircraft - Electric - Helis (FS/W) 0 Apr 25, 2012 04:38 PM
