This is why I don't service engines even though I considered it at one point. $95 is a fair price if can't do it yourself. The 45-60 minutes estimated is fair, but there is overhead. So the $60/hr shop rate, plus parts, plus shipping is expected. You simply won't bill 8 hours a shift consistently (we see those can't get the wrist pin or sleeve out threads here). Shipping anything is $9-$12 today if you haven't check rates in the last 5-6 years. If you haven't run your own business or been directly involved in operating one, it's hard to understand the costs involved. That makes the price look high.
Greg |
Latest blog entry: A tiny diesel engine AE 0.1CC
United States, PA, Southampton
Joined Aug 2012
Hey Guys,
I received engine, will run this weekend. Parts $45, Labor $40, Shipping $10. I will run and let you know if the original "knocking" issue was fixed. They replaced the bearings and adjusted the valves. I'm currently in the process of moving from an apartment to a house so from my perspective it was worth the 95 bucks.This was not a pre-ignition knock, something was not right. Your not going to believe this but I'm actually a certified A&P mechanic, I don't do that kind of work anymore tho. My entire life is in a box right now, LOL! |
Something made those bearings go bad..I'd think that if they cleaned the engine thoroughly,replaced the crank and cam bearings,AND the piston ring,that would reach the $45 parts total.$40 for labor is a very fair price,and we expect the shipping to be $10.-Not a bad deal,considering.
I'd like a hint if they recommended any procedures for future protection. I'm a retired small engine mechanic,and the dealer does most of my work.I just don't want to,anymore. |
Latest blog entry: Model Builder
http://www3.towerhobbies.com/cgi-bin...&I=LXBPK0&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXCD24&P=ML Yes, these can be purchased for 1/4 the price or less, but not at Tower Hobbies as OS OEM parts. Greg |
What is it mounted to?
Greg |
Joined Feb 2008
Did the repair tech test this engine before service to verify the exact problem and diagnos a repair strategy? I would be concerned if the repairs were even necessary in the first place. I would ask to see the parts that were replaced so I could assess them personally. I don't like to send my stuff into the shop without being able to inspect the work performed and all parts replaced. The repair shops generally don't like to be scrutinized as they work either. Why is that? That's not always the case but my experience throughmany years has put me on guard, .. there are too many underqualified, ... unqualified help in the repair industry. I won't say that there is no qualified techs out there, ... but I want to know the doctor and see their work first-hand.
I work on machines regularly, and when the work is done ... it's right. That doesn't mean something else won't go wrong, .... it doesn't mean I know everything either. If I get a call back on any repair it is never for the same reason as before usnless there is a factory defective part or a valid reason. I also make sure there is an actual problem to be repaired in the first place .... and that the problem(s) is/are solved when the ticket is closed. If it is not possible to isolate a problem or series of compound issues, ... I will note that information on the repair ticket then forward any pertinent information to the customer as a courtesy. If that engine needed a set of bearings and they caused the knock descridbed by the customer ... then the repair was obviously necessary and their rates, (even though I think they may be higher than I would want to pay), ... would be justified. If the engine were tested and needed bearings, gaskets, etc ... then Ok "They did the job, I don't have to deal with the headache, I got what I wanted, heres your money, Thanks for the service." If the engine didn't need the job in the first place, .. the shop shouls have called the customer to verify their intentions. If they did not test this engine or assess the repair properly ... What are we expected to pay for .... an un-necessary repair with the same problem we started with? Minus $95.00 . I think you deserve some documentation as to what is performed and a thorough report each and every time any service / repair is made. A qualified tech can determine it there is excessive wear on any given part if they are inspecting the equipment properly. I know the shop is in business to make a profit and that's fine. Maybe not too much at one time though? I know that any business has overhead. There will be shipping charges and payroll, ... ect. There are also a lot of tax deductions for licensed businesses to offset their overhead. I would expect there to be more value for the dollar in this specific repair? The problem is not solved and the customer has paid for a premium service imho? I'm not complaining .... just feel there is something out of balance. |
Just so we all know the facts...
Did you describe THE problem to be fixed? If so the tech should have enough to go on to make a successful repair. If it were me and it needed the bearings and the valves adjusted I would have done that also, but the PROBLEM described takes priority. Do you know if the engine was run after the repair? If not it should have been to confirm a successful repair was made!! IMO a phone call to the service center should be made to express your concern, or to find out what might be causing the problem. |
| Thread Tools | |
| Sold OS 70 Surpass | Dunedinflyer | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Jul 16, 2012 04:58 PM |
| For Sale OS Max 70 Surpass Four Stroke | Grumpy Monkey | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jul 08, 2012 07:05 PM |
| Sold New OS Max 70 Surpass Four Stroke Mounted But Never Run | LCS | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Jul 06, 2012 09:34 PM |
| Sold OS Max 70 Surpass Four Stroke with 8 Flights | LCS | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jul 06, 2012 08:07 PM |
| Sold OS FS 48 Surpass fourstroke engine | hobbylink1 | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jan 23, 2009 12:38 PM |
