Old Sep 07, 2012, 06:40 PM
JBG7676 is offline
Find More Posts by JBG7676
United States, PA, Southampton
Joined Aug 2012
Help!
OS 70 Surpass Four Stroke doesn't sound right.
Hey Guys,
I have a four stroke the was in the box awhile. It runs basically well but it has this intermittent knock. It almost sounds like something is loose or broken and I don't beieve it's getting full power. Any ideas? Thanks.
James
JBG7676 is offline Find More Posts by JBG7676
Old Sep 07, 2012, 08:23 PM
seair is offline
Find More Posts by seair
Joined May 2009
I thought the same regarding my .72. Came to find out the knocking was the clunk in the fuel tank.(thank goodness). Regarding reaching full power, mine doesn't ever sound like "full power". But it seems to have it when flying. You may want to try different props. The surest way is to use a tachometer.
If the specs in your manual are anything like mine, don't expect what it reads.
seair is offline Find More Posts by seair
Old Sep 08, 2012, 08:18 AM
JBG7676 is offline
Joined Aug 2012
Thanks for responding. It's not the clunk. The engine makes the sound when it is on the bench.
Anyone have any experience sending engines back to OS Repair Service?
Old Sep 08, 2012, 08:42 AM
whitewolf is offline
Find More Posts by whitewolf
Dana, Indiana
Joined Jan 2007
What fuel, prop and rpm?
whitewolf is offline Find More Posts by whitewolf
Old Sep 08, 2012, 03:38 PM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
Hobby Services has always done a good job on my engines.
Bruce
landeck is offline Find More Posts by landeck
Old Sep 09, 2012, 04:47 AM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Do you mean you can hear the noise when hand
cranking on the work bench,or when running on a test stand?
If you hear it when it's not running,it's most likely the wrist pin or rod bearing.
If it's when running,try going a little richer and see if it gets quieter.Too lean,or too large a prop can cause a noise like preignition.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Sep 09, 2012, 05:37 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Plug?
TimBle is offline Find More Posts by TimBle
Old Sep 09, 2012, 07:46 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
My experience coincides with Earl. Open the needle a little, and see if the noise goes away.
TomCrump is offline Find More Posts by TomCrump
Old Sep 09, 2012, 09:40 AM
JBG7676 is offline
Joined Aug 2012
I had a 12X7 prop, Fuel was wildcat 15%, but then I used S&W 20% which ran better I think it was the YS blend, i put a new plug in. I did not note the tach. It makes the noise running not by turning prop by hand. I did make it as rich a possible it did not change.
Thanks for the input, I just sent it to Hobby Services because I'm in the middle of moving and just want it fixed. I'll keep you posted incase anyone else has the same issue. Thanks for everything guys!
Old Sep 09, 2012, 01:37 PM
FlyingBrick50 is offline
Find More Posts by FlyingBrick50
AMA 959374
United States, SC, Myrtle Beach
Joined Apr 2011
Knock
Rod knock, piston slap, all kinds of things can cause it to knock, curious what it was. Let us know will you.
FlyingBrick50 is offline Find More Posts by FlyingBrick50
Old Sep 09, 2012, 05:46 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
Running too lean can cause this.
706jim is offline Find More Posts by 706jim
Old Sep 10, 2012, 04:11 PM
Gary Cee is offline
Find More Posts by Gary Cee
Nitromethane and Castor Oil
Gary Cee's Avatar
Joined Apr 2010
It is worthwhile to try grasping the prop while the engine is warm, rocking the prop to check for excessive bearing clearance .
Gary Cee is offline Find More Posts by Gary Cee
Old Sep 11, 2012, 06:17 AM
JBG7676 is offline
Joined Aug 2012
Will do, engine will be at Hobby services Wednesday
Old Sep 21, 2012, 06:27 AM
JBG7676 is offline
Joined Aug 2012
Hey Guys,
Hobby Services received my engine on the 12th and had it dissassemled the same day. They found front and rear bearings to be rough/rusted and valves needed adjustment. The bearings are back ordered so I will not get it back for about two weeks. So far parts and labor $95.00. Ill let you posted on progress and results.
Old Sep 21, 2012, 10:59 AM
shooboy is offline
Find More Posts by shooboy
United States, NY, Spencerport
Joined Aug 2011
$95 ? Ouch......
shooboy is offline Find More Posts by shooboy
Sold OS 70 Surpass Dunedinflyer Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 16, 2012 04:58 PM
For Sale OS Max 70 Surpass Four Stroke Grumpy Monkey Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 08, 2012 07:05 PM
Sold New OS Max 70 Surpass Four Stroke Mounted But Never Run LCS Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 06, 2012 09:34 PM
Sold OS Max 70 Surpass Four Stroke with 8 Flights LCS Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 06, 2012 08:07 PM
Sold OS FS 48 Surpass fourstroke engine hobbylink1 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 23, 2009 12:38 PM
