Sep 07, 2012, 01:55 PM
United States, WA, Seattle
Align 600 EFL PRO Airframe with DFC Head $475
Lightly used Align TREX 600 EFL Pro Flybarless with the latest Align DFC head upgrade. $475 plus shipping
This is the Airframe only with new Mavrick Blades. There are no electronics included.
Pictures are not of actual heli airframe but are of the exact model and look the same as the heli I am selling. The heli is currently partially disassembled and packed and ready to ship.
Description below:
TREX 600EFL Pro
Features of the T-REX 600EFL PRO :
1. New aerodynamically efficient low drag flybarless head assembly,with detachable blade grip pitch arm for ease of maintenance.
2. The frame utilizes 2mm carbon fiber plates of the highest spec. Patented composite material construction technique cleverly utilize frame space that improved overall rigidity, and also created a minimalistic beauty.
3. Innovative sliding battery tray rails imbedded into the 3K side frames, with patented spring loaded latching mechanism, allowing for quick battery access as well as battery protection.
4. Top mounted motor base bringing the motor’s center of gravity closer to rotating disc, improving 3D agility.
5. Uses 600 class 12S high voltage brushless motor providing generous torque and power output, yet consumes lower average current to prolong the life of batteries.
6. The most optimal motor pinion ratio and tail gear ratio to achieve the most efficient power output and flight characteristic.
7. Heatsink embedded into motor mount for effective cooling of motor.
8. Motor mount consists of third bearing block to provide motor shaft support, effectively reduce torque induced shifts, and minimize gear striping issue.
9. Utilize direct link CCPM swashplate control system to enable direct and fast control response. Specially designed anodized CNC servo horns are not only visually pleasing, but are extremely rigid.
10. Utilizes highest spec CNC modue-1 helical main gear, with highest load tolerance and lowest noise.
11. Ergonomically designed H-shaped electronic mount to provide flexible organization or equipment, and minimize wire clutter.
12. Brand new CNC machined metal tail gear box, with thicker side plates to increase rigidity. The more streamlined design also allows for simpler disassembly.
13. High quality 5mm carbon rod and CNC metal tail scissor control arms are used in rudder control system to improve rudder lockingand control effectiveness.
14. Additional radial bearing is added to the one way bearing block to ensure smooth rotation, and eliminate jammed one way bearing.
15. Tail pitch mechanism equipped with high precision bearing.
16. High speed thrust bearings in tail blade grips.
17. New lightened landing gear assembly with lower center of gravity.
18. High quality painted fiberglass canopy with 4-point quick release mounts.
Users must have a certain concept of security to operate the R/C helicopters.
Be sure to read and comply with related safety notes of instruction manual before flying.
Specification (T-REX 600EFL) :
● Length : 1160mm
● Height : 353mm
● Width : 210mm
● Main Blade Length : 600mm
● Main Rotor Diameter : 1347mm
● Tail Rotor Diameter : 260mm
● Motor Drive Gear :13T
● Main Drive Gear :112T
● Autorotation Tail Drive Gear : 131T
● Tail Drive Gear : 34T
● Drive Gear Ratio : 1:8.61:3.85
● Weight (With Motor) : 2290g
Included Accessories :
● T-REX 600EFL PRO Kits Set X 1
● Aluminum Tail Boom X 1
● 600 3G Carbon fiber blades X 1
Radio transmitter and electronic equipment required for assembly:
●Transmitter(7-channel or more, helicopter system)
●Receiver (7-channel or more)
●6S Li-Po 2600 ~ 4600mAh X 2 (3300mAh suggestion)
ESC
Cyclic Servos
Rudder Servo
Brushless Motor
Flybarless Gyro
●Dial Pitch Gauge
