Old Sep 07, 2012, 01:32 PM
Huck Norris is offline
Find More Posts by Huck Norris
Joined Apr 2011
HF sport Voltage
How many volts does the HF sport board need to run?
cheers
Huck
Huck Norris is offline Find More Posts by Huck Norris
Old Sep 07, 2012, 07:54 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
cheers
Huck
I think it's 7v-16v.
I know I've flown mine on both 3s and 4s batteries without problems. Well besides pilot error that is!
Paul
P.S. Just checked:
http://www.hoverflytech.com/sport-techspecs.html
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Sep 09, 2012, 09:44 PM
Joined Apr 2011
Well I just can't figure this out. I have set up about 5 different HFP setups with no issues. I put together a sport quad just for messing around and I can't seem to get it flying. When I plug it in all I get is the board cycling on and off. Resetting or something. I added more power the other to the board as the BEC's from the ESC is only around 5 or so. I bumped it to 9V to the board with the same results.
All ESC's have been calibrated. Newest firmware is on, Throttle end points have been indivitualy calibrated. This is a short video of the start up process.
HF Sport Troubleshoot (1 min 58 sec)
any thoughts.
cheers
Huck
Old Sep 10, 2012, 01:24 AM
aka Helidaho
Joined Jun 2010
Yikes, SCARY... motors spin without board enabled.
you've probably never had this mishap but I always calibrate the escs WITHOUT the props. One time the escs didn't go into calibrate mode and my quad shot to the ceiling and stuck there. I was VERY lucky I wasn't in the way.
It almost seems like a receiver problem though?
Sorry, not much help...
Paul
Old Sep 10, 2012, 06:23 PM
Joined Apr 2011
yeah strange behavior for sure. I have tried just plugging the power in and it still cycles like that. Taking the props off would definitely be a good idea. I will check the RX and so forth.
cheers
Old Sep 11, 2012, 07:14 AM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
There is no All At Once ESC calibration on the SPORT.
I just saw this thread sorry for the late response.
The SPORT is powered directly by the ESCs.
photronix is offline Find More Posts by photronix
Old Sep 11, 2012, 08:29 PM
Joined Apr 2011
I have calibrated the throttle individualy a few times. I will try once more.
Thanks Al.
Cheers
Old Sep 20, 2012, 08:40 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
I think he's referring to where in the video you start with the throttle at full. You should never do this on the Sport. Throttle should be at the low position when you plug it in.
You might consider trying to power the board with an external bec. It looks like the BEC in your ESCs is creating lots of noise that resets the board when your ESCs beep.
Thanks Al.
Cheers
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Oct 03, 2012, 02:38 PM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
the thing i like with my green HFP board , i can calibrate my esc because i have a external battery so i arm the board unplug the main battery , trottle to full position
replug the main battery heard the beep put the stick to lowest position and voila so i am sure i have my esc calibrate because sometime when i arm the board one of my esc did'nt spin the motor but i never be able to find my problem
maybe because i unplug board first or the main battery , when you say cycle the board is it the main battery first or the external battery for the board? thanks
windfou is offline Find More Posts by windfou
Sold TBS Discovery ARF HF Sport, F30A Flashed, KEDA 20-20 acuralegendz Aircraft - Electric - Multirotor (FS/W) 9 Aug 13, 2012 05:03 PM
