Old Nov 05, 2012, 01:02 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
All out.... I got an orange.... but good excuse to get another (red & black) next time around!
uptime4downtime is offline Find More Posts by uptime4downtime
Old Nov 05, 2012, 11:06 PM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
An Sbach V1 ended up in the back of my car today - and Groove, she's still in good nick (thanks 2DD)
Stiffy and Sbach in the same stable now
BJ
BJ64 is offline Find More Posts by BJ64
Old Nov 06, 2012, 12:22 AM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Forgot to mention that the maiden went very well. She flies great - very stable,knife edges surprisingly well for a round fuse plane and snappier than my flat sided full fuse EPP planes. She's definitely a keeper. I uploaded a couple videos of maiden day (skipped the maiden flight video, though - too boring watching someone trim out their plane).
More mixed flying with my Skywing/Wattaplane 48in EPP Edge 540 (5 min 7 sec)
Skywing/Wattaplane 48" EPP Edge 540 - Slow Flight (5 min 20 sec)
Jboy90277 is offline Find More Posts by Jboy90277
Old Nov 06, 2012, 02:27 AM
Two Dogs Dave is offline
Find More Posts by Two Dogs Dave
No Boundaries
Two Dogs Dave's Avatar
Australia, VIC, Forest Hill
Joined Aug 2010
Nearly finished mine.
Anyone got any ideas on the landing gear bolt situation?
Jboy, your plane looks great!
Two Dogs Dave is offline Find More Posts by Two Dogs Dave
Old Nov 06, 2012, 02:33 AM
feda is offline
Find More Posts by feda
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Originally Posted by Two Dogs Dave View Post
Another build pic
As with the Skywing's, the stab goes in with a bead of scotch on the outside quite well
Nac gave me this tip saying that if you ever want to sell the plane you can remove the stab more easily to make the plane more compact for postage
Not that ill ever be selling this plane!
Hi Dave,
You don't even need to use that much glue for the stab IMHO. I put much less glue and drove the it inside the joint with a toothpick so that it became invisible.
Cheers,
Max
feda is offline Find More Posts by feda
Old Nov 06, 2012, 03:17 AM
No Boundaries
Joined Aug 2010
No worries, thanks for the tip Max
I should be enjoying the flying qualities of this plane within the next 24 hrs providing the weather permits!
Old Nov 06, 2012, 04:02 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I just got to the point of putting the gear on last night and the nut would only thread on the axle as far as the nyloc portion. I finally gave up on it and used an old pair of axle's from a 3DHS edge I had in my parts bin. I was lucky I had them, nice thing is they weigh next to nothing compared to the heavy ones that came in the kit.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Nov 06, 2012, 04:17 AM
No Boundaries
Joined Aug 2010
Hey jetintguy,
I just put the landing gear on too and was pondering weather to PU glue in the carbon gear and strengthen the surrounding area. Could make things ugly during repair after a crash though. Not that I plan to crash,..
I think ill fly it first and see how the nylon bolts stand up
Old Nov 06, 2012, 04:34 AM
Burke, VA
Joined Sep 2009
Hey jetintguy,
I just automatically PU'd the gear plate and surrounding frame area, although in stock form it looks pretty strong. I like the idea of the nylon mounting bolts, I use this on a couple of my bigger 5 and 6 foot size balsa's and it really works to minimize damage in a rough landing/crash. If these tend to break too easy I'm going to replace them with a #10 size set of nylon bolts from the hardware store. I feel this size will be stronger without being too strong if necessary. As far as the axle's if I make it to the hobby shop this weekend I'll probably look for some Dubro's to replace the defective ones that came in the kit, or if the 3DHS substitutes hold up ok I'll just leave them in.
Old Nov 06, 2012, 05:16 AM
No Boundaries
Joined Aug 2010
Mines ready! Thanks too for your input re the gear bolts and PU Jetintguy
Old Nov 06, 2012, 04:30 PM
3d Kiwi
New Zealand
Joined Dec 2007
Where do you guys place your battery for correct CG? I'm concerned about getting either too heavy or too light motor. I'd like to use 2200 probably, and not have to push it right against a wing spar or up the front for example. thanks Rick
Old Nov 06, 2012, 04:45 PM
Joined Dec 2011
I show my battery placement in my build post along with my setup. It's not close to the wing spar with the ESC at the forward end of the motor box and an Omega 130g motor. No spinner, though.
Old Nov 06, 2012, 04:49 PM
3d Kiwi
New Zealand
Joined Dec 2007
Thank you very much. Appreciate that. Nice tips in your log
Old Nov 06, 2012, 07:43 PM
No Boundaries
Joined Aug 2010
-Well this plane fly's as I expected. Absolutely fantastic!
I fly with linear expo on the rudder and I found I had to input a little more stick to hold KE than my Skywings but geez this plane rocks! I absolutely put it through the wringer this morning and it passed all tests!
You guys are going to love it
I hope to get some flight Vid of a coming session soon
Old Nov 06, 2012, 07:51 PM
3d Kiwi
New Zealand
Joined Dec 2007
Hey, nice going. What did you use for your motor btw? I can't decide between the Helingi, or the bog standard blue 1000KV. The amp draw on the Helingi is nicer, with a bit more power.
Build Log Skywing, Winner's Model, Hokusei, 3DHS 48"-55" EPP Build & Repair Tips groovejet 3D Foamies 459 Apr 30, 2016 11:31 AM
New Product SkyWing 39-in EPP Edge-540 feda 3D Foamies 120 Jan 22, 2014 06:01 PM
Discussion SkyWing 48-in Extra 300L Under Development feda 3D Foamies 229 Nov 04, 2012 01:55 AM
Sold 3DHS 48" Orange Edge 540 LPU in CT newheliguy81 Aircraft - Electric - Airplanes (FS/W) 2 Aug 19, 2012 07:57 AM
