Old Feb 03, 2013, 05:08 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
I had the tube laying around, if I had 10X10mm carbon I probably would have used it.
Originally Posted by mdrm View Post
Hi Crazy1,
why did you use tubular tubing instead of "the usual (10x10mm)" square carbon tubing - my guess is that they would be stiffer and just as light.
crazy1pilot is offline Find More Posts by crazy1pilot
Old Feb 05, 2013, 07:10 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Great build and nice idears here guys, thanks.
I have see this cool tool for build a tri
http://lloydhassell.brinkster.net/rc...alculator.html
Maybe it exist for a QuadH?
eyesonsky is offline Find More Posts by eyesonsky
Old Feb 08, 2013, 04:15 AM
sergebezborodov is offline
Find More Posts by sergebezborodov
Serge Bezborodov
Ukraine
Joined Aug 2012
If anybody known calc algo, i can create it.
It will looks good with my http://rc-calc.com
sergebezborodov is offline Find More Posts by sergebezborodov
Old Feb 08, 2013, 05:58 PM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
Quad etc calculator here http://www.ecalc.ch/xcoptercalc_e.htm?ecalc but i havent seen a frame sizeing version like the tricopter link above.
BrownOut is offline Find More Posts by BrownOut
Old Feb 16, 2013, 04:53 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Nice design HTML page.
That is same calculations than http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
Old Feb 17, 2013, 01:51 AM
Serge Bezborodov
Ukraine
Joined Aug 2012
i was inspired by ecalc, calc algo is very similar, but I've been tried to do more user friendly interface and features.
Old Feb 18, 2013, 05:41 PM
sparrow1717 is offline
Find More Posts by sparrow1717
WOOOOsssSSSShhHH !!
sparrow1717's Avatar
Long Island , NY
Joined May 2003
Baby H
Just finished airframe tonight......a baby H-Quad based on the 1811s so popular now.
240 mm span
170 mm MTM
Weight so far: 140 grams
Simple basswood and pine body with nylon bolts holding two aluminum cross arms. It seems very stiff over all and is easy to replace arms.
Will be adding Plush 10a's , FLIP Wii and 2S 800/1000 mah pack.
I hope 2S will be enough. I plan on being under 260gram AUW in the end.
** I'm not sure if I'm liking the zip ties for motor mounts....
Spar
sparrow1717 is offline Find More Posts by sparrow1717
Old Feb 18, 2013, 06:07 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Spar
260 on 2s should be ok, if not you can use 6x3's for pros ( if not already ).
Balance the props and you need more for motor mount to lock the motors in place or else the will work themselves right off the arm, trust me.
brontide is offline Find More Posts by brontide
Old Feb 18, 2013, 07:00 PM
WOOOOsssSSSShhHH !!
Long Island , NY
Joined May 2003
I'll grab some 6x3 next order
I'll try to build up the base of the motor mounts for more bite for zips.
It's a pain in the *ss to balance these 5in props.
Spar
Old Feb 18, 2013, 07:06 PM
brontide is offline
Joined Sep 2012
Just don't use 6x3's if you plan on 3s, I don't know if it can handle it. The gemfan's are easier to balance than the HK 5x3's I used at first.
Old Feb 18, 2013, 07:14 PM
WOOOOsssSSSShhHH !!
Long Island , NY
Joined May 2003
The props are from gothelirc. I haven't even tried to balance the 5x3x3s yet !
I'm using a magnetic type balancer and a regular pivot type balance and I can't seem to get a good solid balance.
Old Feb 19, 2013, 06:28 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Just checked out your calc again ... and it looks like your motor selection method addresses the biggest beef I had with ecalc. With so many motors being knock-offs of some original, I've found it hard to find the motor I'd like to model (cause I didn't know who made it originally). So I think I'm going to be using yours as my default from now on.
Thanks for that.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Feb 19, 2013, 06:36 AM
Serge Bezborodov
Ukraine
Joined Aug 2012
Andrew, thank for response!
I'm planing to present it to all forum, currently I need fix translate errors (english is not my native lang).
Old Feb 19, 2013, 03:12 PM
BrownOut is offline
uk
Joined Feb 2009
Much better with all the motor choices including the dt750's.
What does it mean when it says 'For good maneuverability you need Throttle of less than 80%' ?
I obviously understand the words but i dont know if it means its got too much power after 80% or something else. It seems to say not enough power to hover or the above.
It would be good to be able to do time calcs at 50% power or even 75%. Also maybe a search feature on the motors so you dont have to scroll through the entire list each time which im finding painful to do on my phone.
Old Feb 20, 2013, 05:04 PM
danielpetrescu is offline
Find More Posts by danielpetrescu
Tulcea Romania
Joined Mar 2010
Folding, waterproof H quad update
Nice one, some news about your build?
Well here are some updates... slowly but surely. I have to buy the electronics now...
See more explanations at the page above.
http://www.rcgroups.com/forums/showt...2#post24197709
And some pictures
danielpetrescu is offline Find More Posts by danielpetrescu
Discussion Steven Wang as our newest member of our GWS USA LLC. GWS4CEO GWS (Grand Wing Servo) 14 Jun 06, 2006 08:15 PM
E-Fli-owa check out our big event at our website! Goneflyin Electric Plane Talk 6 Sep 20, 2002 04:59 PM
E-Fli-owa check out our big event at our website! Goneflyin Parkflyers 1 Sep 19, 2002 08:42 AM
