Old Dec 24, 2012, 12:51 AM
Earl E Adobtr is offline
Find More Posts by Earl E Adobtr
USA, CA, Mountain View
Joined Dec 2008
This was an accidental discovery. My own theory is that the prop wash points slightly away from the body of the copter. The cleaner the prop wash the smoother she flies.
Earl E Adobtr is offline Find More Posts by Earl E Adobtr
Old Dec 25, 2012, 05:50 AM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
Originally Posted by Earl E Adobtr View Post
Good frame weight. I may need to switch to alu for next H. If you can find a way to cant the arms up 3 degrees it will fly even better. I don't run with KK so not sure how that might affect programing tho.
I may try that on the next one. But i need to make a supply run
wilem is offline Find More Posts by wilem
Old Dec 29, 2012, 08:55 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Happy to see all of these H-Quad
it is winter here... so I need a mini for indoor
160mm motor to motor / 240mm diagonal
67g pine wood frame
FC: openpilot CC3D and case fixed with double-sided tape and damped with Sorbothane piece.
Motors: Turnigy 2211 Brushless Indoor Motor 2300kv
Props: 5x3 GemFan
ESCs: Himodel 10A
LiPo: 3S or 2S 950 mAh
Receiver: Spektrum AR500
AUW: 270g
eyesonsky is offline Find More Posts by eyesonsky
Old Jan 08, 2013, 08:00 AM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Hehe it flies
For now I have 5x3 GemFan props, if I put some GWS 3 Blade 5x3 that will change how the flight?
Mini QuadH keychain FPV 1 (3 min 24 sec)
Old Jan 08, 2013, 11:39 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Hehe it flies
http://www.youtube.com/watch?v=U71zm86K_IY
What's the flight time on that AUW?
3 blades should produce more lift, more turbulence, and may or may not be more efficient.
brontide is offline Find More Posts by brontide
Old Jan 08, 2013, 12:55 PM
Breezemont is offline
Find More Posts by Breezemont
Joined Feb 2009
And more amp draw for the same diameter.
Breezemont is offline Find More Posts by Breezemont
Old Jan 09, 2013, 10:52 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
posted this in the other thread.
Working on a foldable H Quad some aluminium and a CD holder,, more to come this weekend.
Crazy1
crazy1pilot is offline Find More Posts by crazy1pilot
Old Jan 09, 2013, 11:15 PM
Joined Dec 2008
Hehe it flies
I had to pull out a metric ruler to get an idea of how small that thing really is. Love the fence and slide shots. The swan didn't care and the dog, barely. Looks like mission accomplished. Great build.
Old Jan 12, 2013, 04:46 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Crazy1
Nice one guy. Why you prefer aluminium than G10 or wood?
Flight time is about 10mn but I do only 5mn FPV for safety.
With this mini quad its fun to play with slide and other kindergartens.
Also wildlife and birds in particular are less afraid.
Old Jan 14, 2013, 11:43 PM
Joined Sep 2009
Update:
here are the latest pics of my H quad frame. now just waiting for electronics.
Crazy1
Old Jan 15, 2013, 05:25 PM
pdemon is offline
Find More Posts by pdemon
The simplest, the better!
pdemon's Avatar
Italy, Europe
Joined Apr 2002
Hi all
the v.2 version of the Fold-A-Copter is almost ready!
Here you can see the new center plates, lighter and slightly larger but still very compact: what you see tipps the scale at 184grams... not bad IMO
I'll keep you updated...
Cheers
Pierluigi
pdemon is offline Find More Posts by pdemon
Old Jan 15, 2013, 06:29 PM
NYbySky is offline
Find More Posts by NYbySky
United States, NY, New York
Joined Feb 2012
Hey eyeonsky what battery do you use for your fpv battery and what type would you reccomend.
NYbySky is offline Find More Posts by NYbySky
Old Jan 18, 2013, 10:33 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
My setup work for about 10mn
Props: 5x3 GemFan
ESCs: Himodel 10A
AUW: 270g
Old Feb 03, 2013, 12:26 AM
Joined Sep 2009
After completing my beautiful aluminum folding H quad, it did turn out to heavy :/ (pic one)
So I decided to make another one but out of carbon fiber rod that I had laying around (pic two)
The main objectives were to carry a GoPro and be able to run off of a 3s 5000 as I have four of them. The aluminum quad did get off of the ground but the frame had some torque issues and it look about 90% throttle to hover, not good. The new carbon fiber frame cut 1pound off of the design which is huge and now hovers at about 30-50% throttle, much better. The carbon frame does fold up I just don't have a pic of that yet.
Sorry for the crappy pictures, I'll try and get better ones soon
Crazy1
Old Feb 03, 2013, 04:27 PM
cyklopz is offline
Find More Posts by cyklopz
Registered crasher
cyklopz's Avatar
Germany
Joined Mar 2012
Crazy1
Hi Crazy1,
why did you use tubular tubing instead of "the usual (10x10mm)" square carbon tubing - my guess is that they would be stiffer and just as light.
cyklopz is offline Find More Posts by cyklopz
Discussion Steven Wang as our newest member of our GWS USA LLC. GWS4CEO GWS (Grand Wing Servo) 14 Jun 06, 2006 08:15 PM
E-Fli-owa check out our big event at our website! Goneflyin Electric Plane Talk 6 Sep 20, 2002 04:59 PM
E-Fli-owa check out our big event at our website! Goneflyin Parkflyers 1 Sep 19, 2002 08:42 AM
