here is a link to all the parts for the Monocoupe. The battery hatch is included with the fuselage.
http://www.hobbyking.com/hobbyking/s...idCategory=705 S. |
Latest blog entry: JR P-38 take 2.
http://rc-castle.com/shop/product_in...oducts_id=1356 Good luck LURCH |
Joined Oct 2012
Thanks again
My wife just sent me a message and told me that a box from HobbyKing just arrived at my house.... that's my Little Butch!!! I'm so excited to get home and check it out! I ordered some new 3s 20c 2200mah lipos yesterday that should be arriving this week as well. There could be a "Monocoupe Maiden" this weekend!
Any suggestions or things to look out for with the build or bad flight tendancies? |
United Kingdom, England, Leighton Buzzard
Joined Apr 2012
![]() im still loving mine.i would say take extra care if your flying in wind as it can catch the wing and throw old butch of course a bit,also on take off especially,if its windy make sure you keep him pointing right into the wind until hes up with a bit of airspeed as again the wind will catch the wing and push him around a fair bit.Apart from that nothing bad ive found so far. |
Well, It was home when I got there last night. Opened it up and it was in perfect shape. The little bit of build there was to complete was a breeze. I did use welders adhesive as opposed to the mystery white tube that came with it. I always just worry about that... not knowing the age of it... I dunno... Anywho, it looks great, and as soon as my lipos get here, I'll be able to finish off the linkages. i don't see the point of hooking them up before I can center my servo's... just to have to remove them and adjust. Lessons learned I guess..
One question I do have. Mine came with little springs and "nylon wire" that I'm supposed to tie off on the horizontal stab and then to the vertical stab and lower fuse. I cannot get any kind of knot to hold with that stuff. they all just pull right out. What did you guys do? I'm thinking I may try again with a dab of adhesive or CA (will ca melt that stuff or discolor it?) I'm interested to see if anyone else had this issue. Otherwise, it feels like a well built model and it looks great! |
Joined Apr 2012
Good luck with your maiden, for the tail guide wires I used 1mm wire trace crimps from a tackle store, if you look back I did post a photo. As with the wind LB can be tossed a bit but I have took off with a 10 knot tail wind a number of times but I don't make it a habit.
Shaun,
