Old Jan 16, 2013, 02:58 PM
Oboingo1 is offline
Find More Posts by Oboingo1
Tailwinds
Oboingo1's Avatar
United States, WI, Milwaukee
Joined Nov 2012
Wow!
Thanks a million! That directed me to some great information. Found some good Spektrum info. after I did some searching about the receivers.
This plane is so awesome looking! Plus it looks like it flies so nice..
I wish this came out in a Micro size as well.
Thanks for the replies, big help.
Oboingo1 is offline Find More Posts by Oboingo1
Old Jan 16, 2013, 03:20 PM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
I loved the looks of this plane, and at the price, I had to have one. It does fly about good as it looks too. Felt really nose heavy to me on the ground, but after it takes off, it's nice and smooth and just does it's thing. A great little plane!
JForbes is offline Find More Posts by JForbes
Old Jan 16, 2013, 03:23 PM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
I like it too! It's on my short list, but I just got an Escapade 61, so it may be a while.
Norm62 is offline Find More Posts by Norm62
Old Jan 16, 2013, 07:05 PM
meanangel is offline
Find More Posts by meanangel
meanangel's Avatar
Joined Mar 2012
Time for some nite flying
I LOVE MY LITTLE BUTCH
meanangel is offline Find More Posts by meanangel
Old Jan 17, 2013, 08:03 AM
Oboingo1 is offline
Tailwinds
Oboingo1's Avatar
Joined Nov 2012
I am certified INSANE! I tell you -INSANE, but one lucky insane guy!
Late last night with 5 Monocoupe's left in stock @ HK, I figured it was now or never. Filled the cart, and placed the order. Man, am I glad I did it, because they are totally sold out this morning...
Proud new owner of a Monocoupe! Yippeee....It's the simple things in life.. ha ha..
Not sure when I will give it the maiden flight, but I am stoked! Will get it assembled and probably just stare at it for a few days..
A bit more flight hrs. on the trainer, and I will be ready to roll!
Wish me luck!
Old Jan 17, 2013, 08:35 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
That is the most enthusiastic post I have ever read on RC Groups. Congratulations on being the proud parent of the Monocoupe
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Jan 17, 2013, 09:24 AM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
You'll love it. Even if it sits for months, you won't be an less excited. Mine is hanging on a wall in my house where I see it almost every day. It's just a great bird to look at and it is a joy to fly!
Old Jan 17, 2013, 10:37 AM
RedTwilight is offline
Find More Posts by RedTwilight
Cobra Driver
RedTwilight's Avatar
United States, NC, Hurdle Mills
Joined Dec 2005
I too saw that they where in stock in the USA warehouse yesterday and pull the trigger and purchased one! So hopefully soon I'll be another proud owner! Maybe this will motivate me to build the true 1/4 scale that I've had plans for over 3 years now.
And now after reading the history lesson in the 1st post, seems this plane used to be just a few miles down the road from me.
RedTwilight is offline Find More Posts by RedTwilight
Old Jan 19, 2013, 08:00 AM
dgomes is offline
Find More Posts by dgomes
Joined Dec 2010
Originally Posted by Banjofrog View Post
Build notes: Trim or make the holes bigger in the cockpit plastic for the wing screws, so they find where they need to go easier, also with the tail wheel assy ream the plastic support (rear of fuse) a smidgen as it will make it easier to install the rudder and reduce binding, with the tail wheel holding collar tighten and loosen before install just to make sure it will do up with out too much effort. These are very very minor and easy to do. I will add more if I find any but it is a dead simple build.
Hello everyone,
It seems that the screws that hold the front part of the main wing in place are too short. Before putting the wing in place, when I try the screws, only about 2mm are left to screw on the fuselage.
I actually tried to find longer screws like the originals, but it seems like that, at that diameter, the supplied ones are the longest manufactured.
Did anybody experience this?
Did anyone had issues with the screws not being able to hold the wing in place?
Any suggested alternative/fixes?
Thanks in advance for any help/suggestions.
Regards,
dg
dgomes is offline Find More Posts by dgomes
Old Jan 21, 2013, 04:01 PM
GTrain is offline
Find More Posts by GTrain
Getting good at foam repair
GTrain's Avatar
Australia, QLD, Surfers Paradise
Joined Aug 2012
Hi All,
I stand corrected on all of my previous comments. My LB has been nose heavy all along, using nanotech 2200s. I was compensating with up elevator and that was giving me too much climb rate under power.
Rookie mistake! Showing that I've only been flying for 6mths. I discovered it when the battery slipped backwards out of position, I thought LB was way out of trim! Corrected the elevator trim and she flew hands off like an absolute dream - cornered fantastically and looped like on rails
So next question - where has everyone found CoG? I'm in the process of gradually shifting backwards until I find that sweet spot.
GP
GTrain is offline Find More Posts by GTrain
Old Jan 22, 2013, 12:01 PM
LNLP is offline
Find More Posts by LNLP
LNLP
Oak Harbor, Washington 98277
Joined Jan 2005
Best Battery For Durafly Monocoupe
Fellows, just finished my " Little Butch" and what a charmer.
Which batteries would be best fit for this Monocoupe? I
believe the power connector is an XT-60?
appreciate your help, LNLP
LNLP is offline Find More Posts by LNLP
Old Jan 22, 2013, 12:58 PM
Markbinim is offline
Find More Posts by Markbinim
United Kingdom, England, Leighton Buzzard
Joined Apr 2012
i use nano tech 2200mah lipos and they are fine.and yes its an xt60.
Markbinim is offline Find More Posts by Markbinim
Old Jan 22, 2013, 01:54 PM
LNLP is offline
LNLP
Joined Jan 2005
Monocoupe Batteries
Thanks Markbinim for your quick reply. Have ordered 3 of the
Nano-Tech 3S 2200 Mah 25-50C Lipos.
best, LNLP
Old Jan 23, 2013, 11:08 AM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
I have some Turnigy 2200mah 3s packs and have been happy with them as well.
Old Jan 24, 2013, 07:10 AM
Cobra Driver
Joined Dec 2005
According to the post, my "Little Butch" will be waiting for me when I get home from work!
