Old Sep 07, 2012, 12:12 AM
GTrain is offline
Find More Posts by GTrain
Getting good at foam repair
GTrain's Avatar
Australia, QLD, Surfers Paradise
Joined Aug 2012
Question
HK Hummer EPP 3D 1000mm KIT
Soooo....
I just hit the buy button on this one from HK: https://www.hobbyking.com/hobbyking/...dproduct=26559
Threw in the following fitout;
- HobbyKing 20A BlueSeries Brushless ESC
- 4x HXT900 servos
- Turnigy 2213 20turn 1050kv 19A Outrunner with 10x4.7 GWS slowfly prop
- 3s 1000mah 20c lipos
Now - this is my first foray into a kit build AND ideally I want to learn the basics of 3D. Nothing special just harrier/torque roll/4pt turns/waterfalls/big snaps that I'm not game to do on my other planes.
Is this going to be OK or have I thrown away my $$$$ quicker than a night on the turps?
G
GTrain is offline Find More Posts by GTrain
Old Sep 07, 2012, 12:59 AM
Azryl is offline
Find More Posts by Azryl
Australia, VIC, Benalla
Joined Oct 2005
You bought a what appears to be a hacker clone, so it comes from a proven pedigree!
With that motor I would suggest an APC1038 propeller, which will give you a good hover at around 50% throttle. I use this combo on a heavier plane with zero problems.
Get the CoG right and you will have lots of fun doing 3D and bumping the ground, do not sorry this is normal when learning 3D and why we buy bouncy foam! lol
No worries, you bought what looks to be a good model, cheap price made from easy to repair foam! Enjoy your new plane, post a review is you are able.
Regards
Az
Azryl is offline Find More Posts by Azryl
Old Sep 07, 2012, 01:20 AM
GTrain is offline
GTrain's Avatar
Joined Aug 2012
Will do Az - thanks for the confirmation!
I expect to 'dirt nap' frequently that's why I wanted a cheap foam kit!
Review and photos to come in a few weeks when the box turns up
Old Sep 09, 2012, 10:45 PM
Azryl is offline
Joined Oct 2005
Awesome!
I hope HK can bring a variety of these cheaper foamies into the warehouses. International shipping is ok but some local warehouse stock would be most welcome
Enjoy your plane!
Az
Old Sep 09, 2012, 10:49 PM
Azryl is offline
Joined Oct 2005
Oh GTrain, you might need to reverse the shaft in the Turnigy motor if you wish to use the wobbly prop adapter. Not too difficult to do if you have a vice and some blocks of wood, drill a hole through the wood larger than the prop shaft diameter. Undo all the grub screws then try to see how stiff the shaft is in the bell.
Support the bell on your block of wood, drift the shaft down through your drilled hole. Leave enough shaft on the end to attach a 3mm wheel collar, this will prevent the shaft from pulling the bell further out along the motor.
Loctite the collar on the shaft + grubscrew. Had 100 flights like this so far with zero problems.
Az
Old Sep 09, 2012, 11:05 PM
GTrain is offline
GTrain's Avatar
Joined Aug 2012
Righto Az I'll give it a go.... order has printed, looks like I'm waiting for the JIT truck
Old Sep 11, 2012, 09:31 PM
F4J Denny is online now
Find More Posts by F4J Denny
F4J Denny's Avatar
Miami, Florida USA
Joined Aug 2007
Just ordered one yesterday with basicly the same set up. For the price and what you get I could not resist buying one.
F4J Denny is online now Find More Posts by F4J Denny
Old Sep 25, 2012, 06:54 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
About to order one, but stuck between choices with motor selection.
Not sure if 2213 posted above will be enough:
http://www.hobbyking.com/hobbyking/s...idproduct=5688
Im leaning towards these, Whaddaya think?:
http://www.hobbyking.com/hobbyking/s...dProduct=18969
http://www.hobbyking.com/hobbyking/s...dProduct=18968
Edit:
or even this, same as gold turnigy motors I believe:
http://www.rctimer.com/index.php?gOo...1&productname=
sammyc is offline Find More Posts by sammyc
Old Sep 26, 2012, 02:09 AM
Azryl is offline
Joined Oct 2005
The turnigy 2213 1050kv motor I use in many models, with a apc10x3.8 slow fly prop will give approx 1000grams thrust for 18amps. My epp 3D Extra hovers 50% throttle with good punch out using 1000mAh 25c lipo.
Again, read above for shaft reversal, so you can use the wobbly prop adapter. Remember to undo the small grub screws at the non-rotating end before drifting the shaft through, you will need a 3mm collet on the end of the shaft.
Az
Old Sep 26, 2012, 05:42 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Az
Ok then, oh well the other motor I have ordered should be good anyway, just a small amount heavier. And a couple of $ cheaper, and in stock lol.
One thing I noticed though, is hobbykings writeup on the motor, at top they say:
'Combined with a 10x6 E-prop this motor can push out over 1000g in thrust on a 3S1P configuration lipo.
Good for bigger foamies or parkflyers where about 150W is required.'
But then at bottom:
Performance Data
Voltage Current Prop Thrust
11.1V 8.6A 8040 538g
11.1V 13.7A 9050 810g
11.1V 16.7A 1060 650g
Old Sep 28, 2012, 12:54 AM
Azryl is offline
Joined Oct 2005
I just re-engined my brothers pitts special with the turnigy 2213/20 1050kv
apc9x6E prop is 16 amps 180watts for 830grams thrust when using 2200mAh 35c 11.1v lipo
We fly with a smaller lipo, I used the larger battery on my thrust stand to get the best real world figures I could.
Model weighs 690 grams ready to fly, it moves very nicely now
Az
Old Oct 24, 2012, 04:25 PM
sampsonabc is offline
Find More Posts by sampsonabc
United Kingdom, England, London
Joined Feb 2006
I just saw this on hobby king and impulse bought too. Looks like a good little plane for the price. Hopefully the quality is ok. Hows everyone getting on with this? Any maidens yet?
Heres the gear im gonna be using;
Turnigy D2836/8 1100KV
Hobbyking SS Series 25-30A ESC
ZIPPY Flightmax 1000mAh 3S1P 25C
Corona 928BB Servo 2.0kg/ 9g/ 0.13sec
It may be too much motor for this plane, Im going to try it with 9x4.7 slow fly prop so I'll let you know how it goes.
Will try to do a build and review when it all arrives.
Cheers
Sam
sampsonabc is offline Find More Posts by sampsonabc
Old Oct 24, 2012, 05:05 PM
GTrain is offline
GTrain's Avatar
Joined Aug 2012
Hey Sam,
Yeah the plane is great - be prepared to fiddle around a bit to find CoG and best battery placement for your flying style.
I find it flies, loops, snaps, rolls, harrier, hovers fine. I can get the odd inverted flat spin. That's about the limit of my skill.
Knife edge eludes me - may be battery placement or a bit of coupling needed.
I've gone through a heap of props, get spares. The plane can take a hit though, I'm just learning basic 3d stuff and this little foamie does impress when it harriers in for a gentle landing.
G
Old Oct 24, 2012, 08:21 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Cheers
Sam
Very close to what I have gone with, haven't put together yet though, I don't have the time ATM and batteries will e another week away.
Im not sure about the motor either, will definately fly well with it, but its probably overkill, and wasted weight. We'll see.
BTW, this model is very similar in construction to the little Reaktor which my mate has, it could be a good flyer but he needs to use a smaller battery I think and get the CG right back for some 3D action!
Old Oct 25, 2012, 02:50 PM
chops3 is offline
Find More Posts by chops3
New Zealand, Canterbury, Christchurch
Joined Aug 2011
order one as well with this do you think it will work 2210N 1000Kv Brushless Motor
http://www.hobbyking.com/hobbyking/s...idproduct=8621
thanks.
chops.
chops3 is offline Find More Posts by chops3
Discussion Techone / Hobbyking Angel EPP 3D kit question toppnotch 3D Foamies 4 Sep 05, 2012 11:33 AM
Discussion HK Yak 55 3D/EPP plane FPV hazchem88 FPV Aircraft 9 Jul 23, 2012 03:27 PM
Sold SOLD - Cemech Reflex EPP 3D Foam Plane Kit - $30.00 Shipped and Insured. GTMAXX Aircraft - Electric - Airplanes (FS/W) 3 Feb 28, 2012 05:13 PM
Sold NIB HK-450MT CCPM 3D Fully Alloy Kit (Align T-Rex Compat.) and NIP HK-401B Gyro. flyregfly Aircraft - Electric - Helis (FS/W) 2 Mar 13, 2010 11:20 AM
