Old Jan 14, 2013, 04:52 PM
JaredReabow is offline
Find More Posts by JaredReabow
United Kingdom, Abingdon
Joined Dec 2012
The gps must be a solid dim red.
It must never flash
Watch this video for help on setting it up.
http://youtu.be/gzu2iv0nhvo
JaredReabow is offline Find More Posts by JaredReabow
Old Jan 18, 2013, 03:23 PM
richi555 is offline
Find More Posts by richi555
Slovakia, Žilina Region, Trstená
Joined Nov 2010
Hi.
Is possible control pitch of the camera when is servo connected with stabilization?
richi555 is offline Find More Posts by richi555
Old Jan 18, 2013, 03:27 PM
Joined Dec 2012
no sorry, you will need to write your own code for that
Old Jan 19, 2013, 12:35 AM
majik01 is offline
Find More Posts by majik01
Joined May 2010
Originally Posted by richi555 View Post
Hi.
If you are talking about MWC 2.1, that capability is already included in the code - just not enough documentation available to understand how it should be set up.
TGY9x ER9x Cam Stab Programming w/ Tilt Control on Hex+ and HK MWC Pro FC (4 min 36 sec)
majik01 is offline Find More Posts by majik01
Old Feb 05, 2013, 12:30 PM
oshb5 is offline
Find More Posts by oshb5
Joined Jan 2013
Can I ask is this the latest and best version of this board. Only iv been looking around the net and saw a Multi Wii Crius All In One PRO Flight Controller V1.0 and just wondere which was the better board?
Regs Os..
oshb5 is offline Find More Posts by oshb5
Old Feb 15, 2013, 03:05 AM
This Is Mud is offline
Find More Posts by This Is Mud
Guernsey, St Peter Port
Joined Sep 2012
Multiwii GUI (2.1) values twitch/creep
Hello all.
I recently moved from a Crius AIOP to this HK board. Successfully setup GPS and had it flying but it seemed a little twitchy compared to the Crius.
I just hooked up board to GUI and noticed throttle, yaw, pitch, etc. values were twitching up and down. I've never seen this before. It does it with GPS on/off and Tx on/off. I have calbrated acc and mag.
Here's a short video I made this morning. Does anyone have any suggestions?
MultiWii GUI values twitch (0 min 24 sec)
Many thanks.
Lenny
This Is Mud is offline Find More Posts by This Is Mud
Old Feb 21, 2013, 03:55 PM
Phytone is online now
Find More Posts by Phytone
United Kingdom, Stoke-on-Trent
Joined Jun 2012
Decided to try multiwii after having 3 KK2 boards (which worked well). Read the first post, got the board and then decided to instead load a code from the web.
Not sure why i deviated, but after scratching my head for an hour trying to get GPS to work, thought I'd better follow the original post
And after following, word for word, the GPS works
The whole arduino seemed daunting, but makes sense and is quite straightforward. Now to mount in my quad and try to tune the board before I tinker with the GPS.
Thanks for all the great info.
Phytone is online now Find More Posts by Phytone
Old Feb 23, 2013, 10:24 AM
Shorty is offline
Find More Posts by Shorty
United Kingdom, England, Blackpool
Joined Sep 2002
Hi,
Just ordered my HK Multiwii pro.
Has anyone used arduplaneNG on it?
Cheers,
Nick.
Shorty is offline Find More Posts by Shorty
Old Mar 03, 2013, 11:43 PM
gjalbert is offline
Find More Posts by gjalbert
gjalbert's Avatar
Tualatin, OR
Joined Oct 2009
Yep, in the form of MegapiratesNG. There is a great thread on it:
http://www.rcgroups.com/forums/showthread.php?t=1752719
gjalbert is offline Find More Posts by gjalbert
Old Mar 25, 2013, 02:21 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Better in Blue!
I have the FC in Blue now and at a new price get it with Ubox for less $65.
Shipped from the USA. HK price matched with a better GPS.
witespy is offline Find More Posts by witespy
Old Mar 30, 2013, 10:32 AM
mbe575s is offline
Find More Posts by mbe575s
Joined Feb 2011
connection guide Please Help
I need to know how to connect my UBEC, rx, and esc! How do I do this? I have the multiwii Pro with GPS from HobbyKing. I built a quad x.
mbe575s is offline Find More Posts by mbe575s
Old Mar 30, 2013, 10:51 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
It depends on what equipment you are connecting. Swithing BEC or linear BEC, what kind of BEC in the ESCs (if any), etc.
Fred
flarssen is online now Find More Posts by flarssen
Old Mar 30, 2013, 10:59 AM
Joined Dec 2012
its much simpler than fred says
Firstly if the ESC's have a ubec built in, usually called ubec then you do not need to connnect the extra ubec.
if they do not then this is what you do.
Find the wire diagram on hobbking files section to connect the ESC's to the board and the RX to the board.
The ubec can be plugged into the RX if it has a spare port or the main board.
and for programming, i have a full series of videos on how to program the board on youtube.
there are links on the hobbyking file section for those.
Old Apr 18, 2013, 08:47 AM
Rongwayz is offline
Find More Posts by Rongwayz
Joined Feb 2013
Having same problem not being able to connect to board . No flashing lights or anything. Just receive error message "avrdude: stk500v2_ReceiveMessage(): timeout". Checked all my settings and everything seems to be ok. Super frustrated. Any ideas?
Rongwayz is offline Find More Posts by Rongwayz
Old Apr 18, 2013, 10:58 AM
Joined Dec 2012
try a different cable, or you board may be broken
Discussion MultiWii on HK MultiWii Mega Board WITH MTK 3329 GPS TheFernMan Multirotor Electronics 2422 May 25, 2016 12:12 PM
Discussion HobbyKing MultiWii SE V2.0 Flight Controller Erknie Multirotor Electronics 109 Aug 18, 2014 05:01 AM
Discussion Has anyone tried the new HobbyKing MultiWii SE V2.0 Flight Controller w/FTDI rernewe Multirotor Electronics 2 Jun 09, 2014 10:07 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 04:28 AM
