Old Sep 25, 2012, 01:39 AM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Originally Posted by P Scott View Post
Im interested how the 2 boards compare (HK MultiWii Pro vs ATOP). I was looking for an OSD with RTH, stablizer until i I stumbled upon the AIOP thread and now this HK flight controller . I fly mostly fixed wing so would be interested in ArduPlane. Will it work with this HK board?
Neither board is widely used but they are both cheaper than APM2. Any differences between the ATOP and the HK? The HK board will likely sell better due to $$
Not necessarily, Great to see HK shaking things up on the competition front but there is some doubt about the barometer on the HK board whereas baro is high resolution on the AIOP. AIOP runs MPNG and Multiwii whereas HK does not support MPNG as yet.
helidex is offline Find More Posts by helidex
Old Sep 26, 2012, 01:10 AM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
I've been playing with ArduplaneNG on the HK board, but I'm pretty new to this stuff and can't figure out where I'm going wrong. I've got yaw and the baro working, but can't get GPS to show my home position in APM Planner or the other sensors working.
The board goes really well with MultiWii 2.1, but I bought it for waypoint flight. Anyone else trying to use Arduplane or Arducopter?
lobstermash is offline Find More Posts by lobstermash
Old Sep 26, 2012, 01:20 AM
helidex is offline
Joined Jun 2011
At present the board supports only Multiwii.
Old Sep 26, 2012, 01:32 AM
Joined Jul 2012
At present. It'd be pretty easy for someone with the right know-how to vary the Arduplane/Arducopter scripts to work with it though. I'm going to keep playing - I'm learning a lot by playing with it.
Old Sep 27, 2012, 04:44 AM
Joined Jul 2012
Alrighty... I think the official thread has gone firmly down the MultiWii path, which works well but I bought this for waypoint nav, so I'll try here.
The sensors on this board (aside from the GPS) are the same as the AllInOne IMU and the BlackVortex. ArduplaneNG allows this board to be selected, but comes up with this error: 'GYRO_ADDR was not declared in this scope'. *fixed* Anyone have any ideas? If MegaPirateNG works with BlackVortex, would I be able to pinch anything from those files to fix this?
EDIT: I'm having fun getting the all sensors working at once. Using APNG2x R5 I can get the GPS and accelerometers working, but playing with APNG 2.4 (which seems less specialised for the Crius AIO Pro) I can get everything working but the GPS. With the APNG 2.4 scripts it also won't connect to APM Planner.
Old Oct 01, 2012, 12:03 PM
P Scott is online now
Find More Posts by P Scott
Canada, ON, Ottawa
Joined Jun 2011
Did you get it working? Im debating to get the Crius AIOP or the HK "flight controller".
P Scott is online now Find More Posts by P Scott
Old Oct 02, 2012, 05:44 AM
Joined Jul 2012
Nope. Haven't had time to play any more either. Hobbyking haven't been too quick about getting more in stock, which I think needs to happen so more than just a hack (me) is trying to get it going with APNG.
For now get the Crius, but I reckon this is a much better board and will whip the Crius when MPNG and APNG are ported properly.
Old Oct 02, 2012, 08:32 PM
majik01 is offline
Find More Posts by majik01
Joined May 2010
Keep at it. There are folks who follow the "leader" to see what happens and use the lessons learned. Aka - guinea pig. I have both AIO Pro and the HK Mega but despite the initial hiccups I am getting to like this board - the potential for adding more ports and using servo type connectors is a BIG plus. With MWC 2.1, this board can do anything the AIO can and with the option for adding more IC2 and Serial connectors looks like a very good candidate for MPNG. I do not understand why HK has not re-stocked this board already given so many are asking when stocks will arrive.
majik01 is offline Find More Posts by majik01
Old Oct 03, 2012, 04:54 AM
Joined Jul 2012
Yeah, I'm 100% certain it doesn't need any more/different sensors or anything to work with APNG and MPNG, just a competent programmer!
Old Oct 03, 2012, 12:51 PM
Stratagem is offline
Find More Posts by Stratagem
Joined Sep 2012
I'll be picking one up when they're restocked. For now, I'm configuring CodeLite for AVR projects and getting comfortable with avr-gcc and AVR Libc. Java is nice but it's a pig for development (this coming from an Eclipse and Android emulator user).
I'm still hacking make files in a Linux VM as I strive to build a usable, updated Canadian compiler...because, well, I'm Canadian . I have a few Atmel 328Ps here but no 2560s. I was going to order the Arduino 2560 Mega from HK but it's a rev 1, not 3, board. Ah well, we'll see.
Keep at it.
Stratagem is offline Find More Posts by Stratagem
Old Oct 05, 2012, 07:33 AM
PierHenri62 is offline
Find More Posts by PierHenri62
Joined May 2010
In GPS section, enable NMEA.
Have fun, that is a very good board.
PierHenri62 is offline Find More Posts by PierHenri62
Old Oct 09, 2012, 08:54 AM
batusaix is offline
Find More Posts by batusaix
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Got my board. I couldn't pass it up.
So how do i make this work?
batusaix is offline Find More Posts by batusaix
Old Oct 09, 2012, 09:02 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
how to get it to work in general?
There's some files under the Files Tab in the HobbyKing Product page... you can start there.
You gonna need to download the MultiWii software. It includes the actual code and the interface to change the setting.
Another alternate GUI is mw-wingui. It seems to be a better interface for changing setting.
I don't know what version comes with the board, but you'll need the Arduino software to upload the MultiWii code (or MegaPirateNG code) to the board if its not on the latest 2.1. After that, its the MultiWii interface to change setting....
Good Luck!
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 10, 2012, 01:12 AM
Joined Jul 2012
I'm still trying to figure out how to get ArduplaneNG to work. I don't fly multirotors and Multiwii is too limiting...
Old Oct 10, 2012, 09:19 AM
batusaix is offline
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Good Luck!
TheFernMan,
Thank you for this reply.
Yes, how to make it work in general. It's not exactly copy paste type deal.
I know I can understand these things, just needs a bit of warming up.
So the arduino software then...
Discussion MultiWii on HK MultiWii Mega Board WITH MTK 3329 GPS TheFernMan Multirotor Electronics 2422 May 25, 2016 12:12 PM
Discussion HobbyKing MultiWii SE V2.0 Flight Controller Erknie Multirotor Electronics 109 Aug 18, 2014 05:01 AM
Discussion Has anyone tried the new HobbyKing MultiWii SE V2.0 Flight Controller w/FTDI rernewe Multirotor Electronics 2 Jun 09, 2014 10:07 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 04:28 AM
