Old Sep 06, 2012, 11:33 PM
benybee is offline
Find More Posts by benybee
Indonesia, Lampung, Sukarame
Joined Dec 2009
[UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module
HERE'S the link of the board.. from HK (click here)
it cost $65.26 and about $3 for shipping
there is some board identical to this:
ALL IN ONE PRO Flight Controller v1.0
and
I have so many question about this board too..
i'll update it later
benybee is offline Find More Posts by benybee
Old Sep 07, 2012, 04:10 AM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
I've ordered one. Hopefully it will work OK with arduplaneng. The GPS looks to be decent quality.
The same board is available on Goodluckbuy for $90 without the GPS module...
lobstermash is offline Find More Posts by lobstermash
Old Sep 07, 2012, 04:24 AM
benybee is offline
Joined Dec 2009
how about the io port?
is it the same with cirus AIOP
Old Sep 07, 2012, 05:03 AM
Joined Jul 2012
Don't know. I've never seen a Crius AIO in the flesh and it'll be a little over a week until I get this one.
Old Sep 07, 2012, 09:26 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
So this is just a multi-copter controller?
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Sep 07, 2012, 11:08 AM
benybee is offline
Joined Dec 2009
because this board is open, you can use this whatever you want to control
Old Sep 07, 2012, 03:45 PM
Joined Jul 2012
That's what it's been designed for. But yeah, can be anything with the right firmware. Unfortunately because it's been an expensive board before now, nobody's taken the time and effort to utilise all its potential functions.
Old Sep 14, 2012, 12:03 AM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Received the board today from HobbyKing .
After reading about all the broken Micro USB connectors on other FC like the Crius AIOP , I had a good look at the USB connector BEFORE connecting anything.
The micro USB connector is soldered to the board at the rear corners and also has 2 tabs half way down the sides.
Close inspection reveals that it does NOT have a lot of solder to hold it in place and YES it is likely to break off without some extra solder.
The side tabs do not appear to have been well soldered, my guess, surface mount automated soldering has not applied sufficient heat to get the solder flowing well around the tabs which are part of the larger metal connector shell, using a fine tipped soldering iron, care is required specially on the side near the pin headers, re soldered the metal tabs and also the rear corners of the connector, I don't think it will come off now.
Do keep in mind that is a very small connector and the cable can be used to apply sufficient leverage to rip it clean off the board, no amount of extra solder will prevent that, so be real careful not to apply sideways forces to the cable when plugged into the board.
The quality of the board, the soldering of all the other components, I can't fault it, all looks excellent.
Lots of information now in the files tab for the product at HobbyKing.
Some photos
The tabs I mentioned earlier, this photo of the unit as shipped
I connected the GPS to Serial 2, and the flashing LED on the GPS went steady fairly quickly.
The LEDs on the FC board itself are very bright.
I am running Windows 7 x64, when I first connected the FC, W7 reported it can't find a driver, then a short while later a link to the Silabs driver pops up, downloaded Silab drivers, unplugged the USB, plugged USB back in, a SIlabs window popped up and I installed the drivers, I then had to unplug and plug back in the USB one more time for W7 to see the FC correctly installed on a COM Port, all good so far.
Now have to learn about this gizmo and see if I can make it work.
jabram is offline Find More Posts by jabram
Old Sep 14, 2012, 11:46 AM
jabram is offline
Joined Jul 2012
Further progress, read the documentation on the HK product page "files" modified Mutliwii_2_1, for hexcopter and enabled the GPS which is connected to the supplied headers on Serial 2, compiled uploaded, GPS is working GUI works, GPS locks indoors under a metal roof!, all seems good so far on bench test, now to fit it to a frame. I did NOT have to modify anything on the GPS itself.
By the way, like many other Barometers the supplied BMP085 is sensitive to Light and any prop wash, so it does need to be shielded from both LIGHT and PROP wash.
EDIT:
Connected to Spektrum AR9020 Receiver using a single cable to the SRXL output, all working very easily so far, ready to connect some motors
Last edited by jabram; Sep 15, 2012 at 12:42 AM. Reason: added photos of connection to AR9020
Old Sep 14, 2012, 04:05 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The most important thing is the firmware and PC based telemetry software.
How does it compare to my APM 2?
RC Man is online now Find More Posts by RC Man
Old Sep 18, 2012, 12:20 PM
Bill Winston is offline
Find More Posts by Bill Winston
Joined Sep 2012
I got the MWC MEGA v1.0 in the mail a few days ago. Seemed to work out of the box, but GPS mode was not activated. I loaded MultiWii v2.1 into the board and finally got it to work. Question, Does anyone know what parameters to change in the default config.h file? I selected QUADX, enabled GPS according to the files on HK, and selected FFIMUv2 from the Combined IMU section. Works well with servos on the ESC ports (just to test directions), but haven't connected motors yet.
Bill Winston is offline Find More Posts by Bill Winston
Old Sep 19, 2012, 04:41 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
megapirate NG firmware please someone.......
Akcopter is offline Find More Posts by Akcopter
Old Sep 20, 2012, 12:41 PM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
I'm watching with interest - This board with GPS for the money seems like good value. I have the AIOP board plus GPS and I'm planning to run MPNG, in process of tuning and testing. Here is the link for the AIOP thread which may be helpful. Plenty of discussion and examples about editing config.h files etc for both Multiwii and MPNG - beware which is under discussion to avoid confusion.
The AIOP thread has moved quickly so some earlier fixes / discussions and are not relevant now
The issue with the weak mini USB socket has been raised many times. The best fix is to epoxy the socket to the board - taking care not to let the epoxy into the socket (like I did).
There is a blue tooth module here for AIOP / MultiWii and it can also be used with MPNG via Mission Planner.
helidex is offline Find More Posts by helidex
Old Sep 23, 2012, 07:36 AM
waladi is offline
Find More Posts by waladi
Learn to fly with thumb..
Indonesia, West Java, Depok
Joined Aug 2012
Hi Jabram,
We are really hopping that you could test the board with megapirate firmware, please keep sharing the result with us..
waladi is offline Find More Posts by waladi
Old Sep 23, 2012, 08:00 PM
P Scott is offline
Find More Posts by P Scott
Canada, ON, Ottawa
Joined Jun 2011
Im interested how the 2 boards compare (HK MultiWii Pro vs ATOP). I was looking for an OSD with RTH, stablizer until i I stumbled upon the AIOP thread and now this HK flight controller . I fly mostly fixed wing so would be interested in ArduPlane. Will it work with this HK board?
Neither board is widely used but they are both cheaper than APM2. Any differences between the ATOP and the HK? The HK board will likely sell better due to $$
P Scott is offline Find More Posts by P Scott
Discussion MultiWii on HK MultiWii Mega Board WITH MTK 3329 GPS TheFernMan Multirotor Electronics 2422 May 25, 2016 12:12 PM
Discussion HobbyKing MultiWii SE V2.0 Flight Controller Erknie Multirotor Electronics 109 Aug 18, 2014 05:01 AM
Discussion Has anyone tried the new HobbyKing MultiWii SE V2.0 Flight Controller w/FTDI rernewe Multirotor Electronics 2 Jun 09, 2014 10:07 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 04:28 AM
