Old Sep 11, 2012, 02:37 AM
gizzo is offline
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
Oh yeah . It's obvious once you said it. Silly me.
gizzo is offline Find More Posts by gizzo
Old Sep 11, 2012, 05:07 AM
Hamburglar is offline
Find More Posts by Hamburglar
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
A vac formed clear canopy has crossed my mind. I reckon they look great when they are done right.
I started the canopy mould layup. 2x coats of resin+talc. Then pressed some light glass and flocks on while it was still sticky. I'll finish it later in the week.
Hamburglar is offline Find More Posts by Hamburglar
Old Sep 11, 2012, 10:47 AM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
I'm interested to see what you do for the hatch. Are you going to glue a part from the mold into the main fuse mold to create the step?
The reason I ask is I need to deal with the hatch on the Typhoon pretty soon here. I normally make a mold of the area like you've done. Then I make a part from the mold and retrofit that to the plug. I really hate having to hack into the plug like that but haven't come up with a better way yet. Always looking to learn something new.
slopeiron is offline Find More Posts by slopeiron
Old Sep 11, 2012, 04:12 PM
Hamburglar's Avatar
Joined Jul 2008
Yeah that's the plan. I tried it last year with a nose cone and it worked a treat. The edges came out really clean.
Old Sep 11, 2012, 05:13 PM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
Looks nice. What did you use to bond it into the mold? Resin/Goop? My main concern with doing it that way is that the part could possibly stick and maybe pull it out of the mold. But maybe that is not as much of a problem as I think. The other thing is for a hatch like the Typhoon, where the fuse is fairly smooth on top, it might be a little tricky to locate the pieces in the two mold halves so that they line up perfectly in the finished fuse. But if I thought I could make it work, I might give it a try this time around. Like I said, I really don't like having to hack up the plug. Also, if anything ever happens to the hatch mold, I don't have the original plug to make a new one.
Old Sep 11, 2012, 06:26 PM
Hamburglar's Avatar
Joined Jul 2008
I stuck them on with thin double sided tape. Once PVA is applied, and dry, they are stuck down pretty good and don't move during the layup. But they do come out each time a part is pulled.
The plan is to lay up a canopy, trim it to the shape I want, then place it into the moulds and scribe round the edge of the part. In the canopy mould it will give me a trim line. And in the fuse mould it allows me to locate the inserts.
The nose nose was real easy as it was sort of self-locating, only fits itno the mould in one spot. But that other recess on top of the fuse (for a pop-up brake) was harder. I ended up cutting a small circle out of vinyl and sticking it on the plug before laying up the moulds. It creates a really small bump, just large enough to locate the inserts by feel.
Sorry if the explanation is crap. Brain is a bit fried at the moment. Not enough sleep.
Old Sep 12, 2012, 12:47 AM
SethPenery is offline
Find More Posts by SethPenery
SethPenery's Avatar
Eldorado CA
Joined May 2010
I'm really stoked to see you getting this project goin dude, really gonna be a sweet lookin sled. Looks killer so far. I'm gonna be needing one here in the U.S to brag about, Mabey we can work something out if u start a batch?
Peace
SethPenery is offline Find More Posts by SethPenery
Old Sep 12, 2012, 01:03 AM
Hamburglar's Avatar
Joined Jul 2008
Yeah for sure. It would be cool to have one flying on the other side of the planet.
Are you a dad yet??
Old Sep 12, 2012, 03:53 AM
Hamburglar's Avatar
Joined Jul 2008
Just finished laying up the rest of the canopy mould
Old Sep 12, 2012, 11:45 AM
SethPenery's Avatar
Eldorado CA
Joined May 2010
Originally Posted by Hamburglar View Post
Definitely post some pics once you've got one done!
Span on this one will be ~46-48". Fuse is 900mm long, 50mm wide. I'm purposely leaving off the fillets just in case I want to do a quasi-PSS TWF one day
Are you a dad yet??
Sweet! I'm almost a daddy, the little woman went to the doctors and they said to be expecting labor mid next week...... anxiety is starting to kick in
Old Sep 12, 2012, 06:01 PM
Hamburglar's Avatar
Joined Jul 2008
Awesome! Hope everything goes smoothly for you guys.
Old Sep 12, 2012, 10:34 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
I wonder if his timing was better than yours Jordan
steve wenban is offline Find More Posts by steve wenban
Old Sep 15, 2012, 09:47 PM
Hamburglar's Avatar
Joined Jul 2008
I popped off the canopy mould and it came out ok. I'm on babysitting duty for the next couple of weeks so I won't get a chance to lay up fuse moulds until october.
Old Sep 19, 2012, 02:02 AM
Hamburglar's Avatar
Joined Jul 2008
Yawn.... not much happening here. Itching to get these fuse moulds done. I got a canopy pulled from the mould and trimmed to the shape I want.
Old Oct 03, 2012, 01:47 AM
Hamburglar's Avatar
Joined Jul 2008
I got some more done on this thing.
The plug is in the parting board and I've put down gelcoat, light glass, and flocks. I have more glass and coremat on the way. Hopefully it's here before the weekend so I can finish this half of the mould. And this afternoon I cut some airfoil templates and wing cores. Slowly making progress.
Discussion New 101mm composite L39 ARF for $150? mandoman Electric Ducted Fan Jet Talk 7 Jun 22, 2012 02:44 PM
Sold Fat Shark base goggles, low use. $190 shipped Blucross FPV Equipment (FS/W) 12 Jun 03, 2012 06:08 PM
Discussion fat shark predator lipo gives a low voltage warning on charger genrlst Batteries and Chargers 3 May 23, 2012 01:18 PM
Question high kV or low kV for plane with fat fuse? paulatgis Power Systems 5 Sep 14, 2010 09:40 PM
Fat Free Taco - Low Carb Taco? Tram Sport Planes 161 Aug 18, 2004 03:16 PM
