Old Jan 29, 2013, 11:17 PM
Pismo is offline
Find More Posts by Pismo
Jim in San Diego
Pismo's Avatar
United States, CA, San Diego
Joined Nov 2002
I'm thinking Brian did.
Pismo is offline Find More Posts by Pismo
Old Jan 29, 2013, 11:20 PM
Pismo is offline
Jim in San Diego
Pismo's Avatar
Joined Nov 2002
That fuse looks a lot better than the wings we did with 6oz but then again, we didn't primer those. Seems like we end up doing so much to them while building that primer isn't worth the up front time. I see Brian's point on leaving off the primer on these types of builds.
Old Jan 29, 2013, 11:42 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Originally Posted by Hamburglar View Post
Ah bugger
Only one doesn't have a veil.... that had lots of pinholes. You could see them real easy through the paint. Did Dan grab that one?
Probably the one I grabbed
TFLG is offline Find More Posts by TFLG
Old Jan 30, 2013, 12:01 AM
Hamburglar is online now
Find More Posts by Hamburglar
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
Ah crap..... And on the topcoat too
In the pic you posted where you're installing the wing, I'm pretty sure I can see the weave of the light veil glass where the primer has been sanded back.
Hamburglar is online now Find More Posts by Hamburglar
Old Jan 30, 2013, 12:23 AM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
Don't have my Chaos fuse yet.....been under the weather this last week.....but I am feeling much better now.
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Jan 30, 2013, 01:32 AM
howsthewind is offline
Find More Posts by howsthewind
S.L.O.P.E.
howsthewind's Avatar
San Diego
Joined May 2005
Man that sucks Brian. Gonna take a little elbow grease to fix...
howsthewind is offline Find More Posts by howsthewind
Old Jan 30, 2013, 09:05 AM
tbogey is offline
Find More Posts by tbogey
United States, CA, Tustin
Joined Nov 2006
Originally Posted by TFLG View Post
Here's a few pics of the build so far. I too a couple showing how to install the wing into the fuse with the least amount of hacking. Basically you remove the trailing edge behind the linkages, then lay them flat in that cutout and then slide the wing through. Once through you have to straighten the nylon horns. I used a long copper tube with a slot in the end of it to straighten them. Once they are straight you thread the pushrods onto the clevices.
Other than that everything is pretty stock PSS build. As you can see mine is pretty well ready for paint. I have a few areas in that need a little attention with spot putty and primer. Right now it's exactly 2 lbs (32oz). With paint and gear I still expect to hit my 40oz target weight.
I love the "NO EPP" sticker on the band saw...a purist...
Not that I want to muddy your thread with NOOB questions, but here comes the mud..
How do you configure the internal elevator linkage? I have been looking for posts and pics regarding this to no avail. I know you need a wire that sits on the elevator saddle, but then you use a carbon push rod that is glued to the inside of the fuse or what ...im trying to do up my old model pony pss plane.
tbogey is offline Find More Posts by tbogey
Old Jan 30, 2013, 09:14 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
I use a carbon tube as the pushrod with a wire epoxied into each end of the tube. A clevice is installed on each end. The pushrod simply attaches to the servo and the other end to the elevator control horn. The pushrod is not attached to the fuse in any way.
Old Jan 30, 2013, 09:01 PM
Hamburglar's Avatar
Joined Jul 2008
I was just thinking............ Do you reckon mixing some topcoat with talc would work as a pinhole filler?
Old Jan 30, 2013, 09:12 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Well I got most of the goobers fixed tonight and shot some repair paint on it. Not too bad now. Just needs some panel lines and a few stickers to purdy her up a bit.
Old Jan 30, 2013, 09:23 PM
Hamburglar's Avatar
Joined Jul 2008
Sweet! The colour scheme looks fantastic
The primergate thing had me a bit pissed off last night. So I locked myself in the shed and laid up another fuse. No primer of course.
Old Jan 30, 2013, 11:33 PM
RAFster is offline
Find More Posts by RAFster
United States, TN, Blountville
Joined Oct 2002
Stickers to tart her up a bit...
Ever use the Icing style of bondo for filling the pinholes?
T stands for Tart
so FLG is the G for Goobers?
Tart Fixes Little Goobers?
Speaking of Goobers and Ompa Loompas...
you did wipe it down to ensure the QC's quality checkslist residue was removed before you started sanding?
She Just Beat It into submission
RAFster is offline Find More Posts by RAFster
Old Jan 31, 2013, 12:07 AM
67econoline is online now
Find More Posts by 67econoline
Nothing to see here...
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
Super Deluxe Paint Brian. Even with troubles...!!
You rock!!
Rubio
67econoline is online now Find More Posts by 67econoline
Old Jan 31, 2013, 08:16 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
I have like 14 varieties of Bondo to use. I have thin, thick, blue, gray, yellow, brown, catalyzed, non catalyzed...... And yes I did wipe off the baby pawprints
Old Jan 31, 2013, 09:04 AM
tbogey is offline
Joined Nov 2006
Nice color scheme, amazing job.
Discussion New 101mm composite L39 ARF for $150? mandoman Electric Ducted Fan Jet Talk 7 Jun 22, 2012 02:44 PM
Sold Fat Shark base goggles, low use. $190 shipped Blucross FPV Equipment (FS/W) 12 Jun 03, 2012 06:08 PM
Discussion fat shark predator lipo gives a low voltage warning on charger genrlst Batteries and Chargers 3 May 23, 2012 01:18 PM
Question high kV or low kV for plane with fat fuse? paulatgis Power Systems 5 Sep 14, 2010 09:40 PM
Fat Free Taco - Low Carb Taco? Tram Sport Planes 161 Aug 18, 2004 03:16 PM
