Old Jan 21, 2013, 09:39 PM
howsthewind is offline
Find More Posts by howsthewind
S.L.O.P.E.
howsthewind's Avatar
San Diego
Joined May 2005
Jim- I told you we should've taken Brian's(TFBM- That Fricken Building Machine) fuse to slow him down!
Greg
howsthewind is offline Find More Posts by howsthewind
Old Jan 21, 2013, 09:43 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Greg
Your "mistake" was leaving me those aileron! Thank you btw. The power planer made short work of that 1/2" thickness.
TFLG is offline Find More Posts by TFLG
Old Jan 21, 2013, 09:46 PM
Pismo is offline
Find More Posts by Pismo
Jim in San Diego
Pismo's Avatar
United States, CA, San Diego
Joined Nov 2002
D'oh. Guess who didn't take your #1 building tip today?
Pismo is offline Find More Posts by Pismo
Old Jan 21, 2013, 09:58 PM
Hamburglar is offline
Find More Posts by Hamburglar
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
Awesome. Glad you guys like them. I'm real stoked that you are doing this build
What did you use to sheet the wings?
Hamburglar is offline Find More Posts by Hamburglar
Old Jan 21, 2013, 10:24 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
They look great Jordan, cant wait to see it in the air. Hopefully I will have it done for the Torrey fun fly (and hopefully there's wind). We have sheeted the wings with ply.
Old Jan 21, 2013, 10:30 PM
67econoline is offline
Find More Posts by 67econoline
Time...use it wisely
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
Thanks for the video . I do it different but not any more!!!
The Cave of Wonders...!!!
What a place
Rubio
Who is going to enjoy this...
67econoline is offline Find More Posts by 67econoline
Old Jan 22, 2013, 12:16 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
I took a shot at cutting the wing holes. I jigged up the fuse so the bottom of the fuse was slightly raised at the rear (about 1/8"). The bottom of the fuse is pretty flat but I like a little nose down attitude when flying. Using a flat block I drew a centerline on each side of the fuse 1 1/8" up off the table. Next i measured 15" back from the nose and made a mark on each side. This is where the leading edge on my wing is going to go. Next I used the airfoil template I used to cut the wings and I 3M-77'd it to the side of the fuse. Then using the back side of a broken exacto blade I scribed and scribed and scribed until I had the fuse cut (just like cutting a hatch). Repeat on other side..... DONE. Since you other builders don't have my airfoil template you can make your own using your wing root. Make the template from Formica if you have it.
Old Jan 22, 2013, 12:57 AM
Hamburglar's Avatar
Joined Jul 2008
Nice. Your nose is just a little bit longer than mine (by 3/4" or so). It'll probably look better too. More jet-like
FWIW these are the measurements I used.
Old Jan 22, 2013, 08:32 AM
Joined May 2011
Thank you for posting this Brian. I have never done this type of build it really interests me. I enjoy your fine work.
Thanks Jordan.
I missed that the first time.
Rubio
On the sideline
Old Jan 22, 2013, 05:40 PM
Hamburglar's Avatar
Joined Jul 2008
Popped another one out this morning. This one came out real good..... Be sure to buy lots of raffle tickets at the PSS fest!
Next one will be a heavy fuse for me to build
Old Jan 22, 2013, 05:51 PM
Pismo is offline
Jim in San Diego
Pismo's Avatar
Joined Nov 2002
Sweet! Cores are ready and waiting thanks to Brian!
Old Jan 22, 2013, 06:05 PM
Hamburglar's Avatar
Joined Jul 2008
Awesome. Thanks Brian!
Old Jan 22, 2013, 06:17 PM
Joined May 2011
Beautiful finish!!
Your work just gets better !!!
Rubio
Old Jan 22, 2013, 07:51 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Do you have the templates for the tail? If you have a CAD drawing of the thing send it to me (dxf, Ver.. the older the better) and I will make some plans.
Old Jan 22, 2013, 09:14 PM
Hamburglar's Avatar
Joined Jul 2008
Here are tail templates in pdf. They should come out the right size if printed without scaling. I don't have a proper cad drawing. The fuse was done in devfus (but maybe I can find a way to export it) and the wings and tails were pretty much TLAR.
Discussion New 101mm composite L39 ARF for $150? mandoman Electric Ducted Fan Jet Talk 7 Jun 22, 2012 03:44 PM
Sold Fat Shark base goggles, low use. $190 shipped Blucross FPV Equipment (FS/W) 12 Jun 03, 2012 07:08 PM
Discussion fat shark predator lipo gives a low voltage warning on charger genrlst Batteries and Chargers 3 May 23, 2012 02:18 PM
Question high kV or low kV for plane with fat fuse? paulatgis Power Systems 5 Sep 14, 2010 10:40 PM
Fat Free Taco - Low Carb Taco? Tram Sport Planes 161 Aug 18, 2004 04:16 PM
