Old Nov 11, 2012, 10:54 PM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
If you take one, you will need to take another one for me, then you will probably have to take two more for Greg and Matin.........
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Nov 11, 2012, 11:01 PM
MATIN is offline
Find More Posts by MATIN
Just Toss It !!!
MATIN's Avatar
United States, CA, San Diego
Joined May 2004
If I had one I'd make into an L-39.....
Matin
slapping his leg and laughing like a mad man......
MATIN is offline Find More Posts by MATIN
Old Nov 11, 2012, 11:25 PM
Hamburglar is offline
Find More Posts by Hamburglar
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
Originally Posted by MATIN View Post
If I had one I'd make it into an L-39.....
Hamburglar is offline Find More Posts by Hamburglar
Old Nov 11, 2012, 11:49 PM
MATIN is offline
Just Toss It !!!
MATIN's Avatar
Joined May 2004
Just kidding!
All of the designers at Aero Vodochody together don't have half the talent in your pinky.
Now if you could just stop putting rouge on your daughter's cheeks......
Old Nov 12, 2012, 12:20 AM
Hamburglar's Avatar
Joined Jul 2008
Flattery works.... even if I know you're lying. You're back on the list
More molars on the way
Old Nov 12, 2012, 12:22 AM
MATIN is offline
Just Toss It !!!
MATIN's Avatar
Joined May 2004
So that's why she's reaching for the plane?......To chew on it?!!!
Old Nov 12, 2012, 01:34 AM
Hamburglar's Avatar
Joined Jul 2008
Just claiming her property. Apparently everything is hers now that she can walk
Old Nov 13, 2012, 09:14 PM
Hamburglar's Avatar
Joined Jul 2008
A diagram to show the dimensions for marking out the wing slot-
Block the fuse up on a flat bench so the bottom edge of the tail opening is 60mm off the bench.
Mark the wing slot at 30mm parallel to the bench.
Wing LE is 360mm from the nose.
Old Nov 14, 2012, 09:06 PM
Hamburglar's Avatar
Joined Jul 2008
Old Nov 14, 2012, 09:31 PM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Or Maxwell Smart sorta thing yeah I know it started with a K
steve wenban is online now Find More Posts by steve wenban
Old Nov 15, 2012, 01:30 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
That airfoil look very much like one of your modded ones! Or is it a stock Selig/Donovan one or something similar?
What camber does it have?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Nov 15, 2012, 02:45 AM
Hamburglar's Avatar
Joined Jul 2008
Hd45
Old Nov 15, 2012, 05:17 PM
Hamburglar's Avatar
Joined Jul 2008
I had some help popping #3 out of the moulds.
Old Nov 15, 2012, 05:18 PM
Joined Aug 2008
Hd45
Hd45
Have you increased the camber on the standard (1.4%) airfoil Jordan?
It looks like it in the profile posted above. Might be just optical illusion though.
The polars of the original look really good. Fast, good turning while retaining pretty acceptable inverted performance?
I like it.
Jim.
edit: I'm still learning to interpret airfoil polars! I want to book you in ahead for a short tutorial on the subject when next we meet at one of the festivals please!
Old Nov 15, 2012, 05:21 PM
Hamburglar's Avatar
Joined Jul 2008
Yes I bumped the camber up a little.
Flies good and is easy to build. It's basically just a thin RG-14 with a more triangular TE (RG-14 has some undercamber).
Discussion New 101mm composite L39 ARF for $150? mandoman Electric Ducted Fan Jet Talk 7 Jun 22, 2012 03:44 PM
Sold Fat Shark base goggles, low use. $190 shipped Blucross FPV Equipment (FS/W) 12 Jun 03, 2012 07:08 PM
Discussion fat shark predator lipo gives a low voltage warning on charger genrlst Batteries and Chargers 3 May 23, 2012 02:18 PM
Question high kV or low kV for plane with fat fuse? paulatgis Power Systems 5 Sep 14, 2010 10:40 PM
Fat Free Taco - Low Carb Taco? Tram Sport Planes 161 Aug 18, 2004 04:16 PM
