Old Sep 06, 2012, 04:35 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
What am I doing wrong... first LiFe battery
Imax B6 charger, LiFePo4 tx battery, HK-010 watt meter/analyzer.
Charger has no specific setting for LiFe. Set to "auto" and it detected 3S. Charged to "full" @ 1.5A. No problem. Hooked up to HK-010 (which *does* have specific LiFe setting) to confirm full charge, its yelling at me and blinking "high voltage". Checked with a meter... charged to 11.95.
What's wrong? The charger or the analyzer?
- Steven
s_mack is offline Find More Posts by s_mack
Old Sep 06, 2012, 04:46 PM
s_mack is offline
Registered Loser
Joined Jun 2010
Nevermind... found a great answer:
Setting a 4-button charger to charge LiFePO4 or A123 batteries (2 min 12 sec)
Stupid how it works, but whatever.
The charger says right on it LiPo/LiFe so I figured I was safe. Hope I didn't turf my battery.
Old Sep 06, 2012, 09:29 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
If you charged to full on Lipo setting you over charged it by a lot and it is definitely damaged. Somewhat surprised you didn't cause a fire. I would not trust it in my tx without a lot of testing first.
The method this charger uses for selecting lipo/life/lilo is quite common actually.
grimbeaver is offline Find More Posts by grimbeaver
Old Sep 06, 2012, 09:48 PM
s_mack is offline
Registered Loser
Joined Jun 2010
Common, perhaps... but no less stupid.
Of course, I should have been more sure before doing it, obviously. So I'm just as stupid.
In any case, as I read up more on it... I think you're wrong on a couple points. a) its not "definitely damaged". 11.95/3 = 3.98V per cell. LiFePO4 "have a maximum operating voltage of around 4.1 to 4.2 volts" (source). However, other sources (wikipedia) state 3.6V as the max, so really I don't know. It appears to be "fine" right now. It quickly self-discharged to 9.98V and has been there ever since. Not at all puffy, etc.
As for being suprised it didn't cause a fire... that's kinda the point of LiFe vs LiPo. From the same source: "Overcharging and overdischarging LiFePO4 cells will damage them, but generally without the explosive side effects." From another source: "Overcharging and overheating [lithium] can cause fire and explosions. The exception to this is the LiFePO4 battery."
Thanks for your input.
- Steven
Old Sep 06, 2012, 10:58 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Your battery may be perfectly fine.
Some have habitually 'overcharged' A123 Systems LiFePO4 cells on lipoly setting for 100's of cycles and never suffered any measurable cell degradation.
Whether the prismatic cells of the type that you purchased are tolerant of such abuse is unknown. Please do report back on how your pack performs. My guess is that no harm has been done.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 07, 2012, 02:34 PM
United States, MN
Joined Feb 2011
I'll give you that. I prefer the iCharger method where it's simply another item on the main screen you can select just like amps and cell count.
Old Sep 08, 2012, 10:05 AM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
If your resting voltage is 9.98 then the pack is still not full. Even though you had a termination voltage setting that was too high , it didn't "hang" there long enough anyways. I only have 1 of these LiFe packs , but it sure appears to have a sharp knee at BOTH ends of the voltage graph.
Now where did I put my 10.8 sized voltage cramp?
gulio is offline Find More Posts by gulio
Help! Kyosho F-16: what am I doing wrong? zippogeek Foamy EDFs 4 Jun 09, 2012 05:49 PM
Discussion outdoor 3D flying - what am I doing wrong? sfluck 3D Flying 15 May 26, 2012 03:38 PM
Discussion Version 4.0 What am I doing wrong? Hopefully Fixed! AeroVideoUS Hoverfly Technologies 58 Apr 29, 2012 12:03 PM
Discussion What am I doing wrong while assembling this RTF sahil80 Beginner Training Area (Aircraft-Electric) 23 Apr 14, 2012 05:08 AM
NMH Batteries: what am I doing wrong. rcav8r2 Parkflyers 2 Mar 12, 2002 03:26 PM
