Old Sep 06, 2012, 01:08 PM
Capt. Quirk is offline
Find More Posts by Capt. Quirk
Riverside Calif.
Joined Apr 2008
Build Log
Test Bench Data Aquisition System for R/C Gas, Glow, and BLDC Motors
I have started building a data acquisition system for my test bench, and much of
the basic components I already have experience with. But I have purchased negative
pressure sensors that I have not used before, and I will need some help with.
I have a number of goals for this project, and the first and foremost goal is that anybody
that wants to build one too, should build one. I will provide as much support as I can, and
I sincerely hope others can contribute to that effort.
I will be using the Parallax Propeller for the project, and initially I will be downloading and
modifying existing "Spin" & "PASM" code from the Parallax Object Exchange. Later I will
start writing my own code, and then convert it to C++.
I have two reasons for using the Propeller, the first is: This is my normal choice for projects,
and is what I am use to using. Second, I am anxiously awaiting the Propeller II, and it's
capabilities for controlling multiple bldc motors at one time, increased video, and human
input capabilities. All these tasks are important for my future projects.
My goals for the system are:
1) easy for anybody else to complete.
2) Start with Basic inputs-outputs: rpm, cht, servo, display.
3) Add Throttle position, rpm acceleration - deceleration rate, ignition timing.
4) Data logging to an SD card.
5) Add multiple pressure sensors.
6) Inertia Dynomometer capability.
7) Make a smaller unit for flight testing
8) Expand capabilities to include bldc motors.
A separate but related project is to make an oval circuit (wind tunnel) for testing engines
and motors at flight rpms and loads.
Bill M.
Capt. Quirk is offline Find More Posts by Capt. Quirk
Old Sep 07, 2012, 07:42 PM
brw0513_2 is offline
Find More Posts by brw0513_2
Joined Dec 2006
Bill,
A big thanks to you for sharing your work.
Have you considered using an EagleTree V4 logger for logging and display duties? It is very configurable.
brw0513_2 is offline Find More Posts by brw0513_2
Old Sep 08, 2012, 04:59 PM
Riverside Calif.
Joined Apr 2008
I have used Eagle Tree before, and it has nice software.
But this project is designed to let people pick and choose what parts they want to use.
For example, maybe some one wants a bare bone tachometer, so they don't need to
use their old optical tach. if a user wants to do some simple dyno testing. Testing propellers
on really hot and humid days can be documented using up to date air density readings. Or perhaps
they are only interested in BLDC motors, but want exact thrust measurements. Anything is
possible.
I will make it as easy as possible to copy the project. But I will only be using Parallax
products like the Propeller and Basic Stamps. The best features of the Propeller:
1) There is no need for interrupts
2) It is like programming up to 8 Basic Stamps to work independently and parallel
at the same time.
Bill M.
Old Sep 08, 2012, 08:46 PM
Joined Dec 2006
OK Bill. Watching with interest.
And happy to help in any way I can.
Old Sep 09, 2012, 12:12 PM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
A little starting idea ???
http://www.elektor.com/magazines/200...1.875648.lynkx
http://www.elektor.com/magazines/200...2.925298.lynkx
Alain
Acetronics is offline Find More Posts by Acetronics
Old Sep 10, 2012, 09:44 PM
Nav_Aids is offline
Find More Posts by Nav_Aids
Nav_Aids's Avatar
Canada, MB, Winnipeg
Joined Nov 2011
Subscribed
Ray
Nav_Aids is offline Find More Posts by Nav_Aids
Old Sep 22, 2012, 08:41 PM
RotoGoat is offline
Find More Posts by RotoGoat
Disturbed, but in a good way.
RotoGoat's Avatar
Gold Coast, Australia
Joined Nov 2009
Try looking up DATAQ starter kit. Cheap and easy
RotoGoat is offline Find More Posts by RotoGoat
Old Nov 07, 2012, 02:52 AM
foxcopy is offline
Find More Posts by foxcopy
Joined Jul 2012
Diy DYNO
http://sci-spot.com/Mechanical/dyno.htm
foxcopy is offline Find More Posts by foxcopy
Data Motor Data - test bench data for several hundred brushless motors. Dr Kiwi Power Systems 863 Sep 25, 2016 03:04 AM
Question TF8000 Bench Test Data? eJets Electric Ducted Fan Jet Talk 7 Mar 22, 2010 05:31 PM
Mini-HowTo Data Aquisition/Camera Hardware on the cheap reuven_segal FPV Talk 2 Aug 23, 2009 06:38 AM
Tests & Bench data from RAZOR motors ?? bmaaa Power Systems 0 Aug 30, 2005 05:36 PM
Power Supply for Power System Bench Testing AstroNut Power Systems 20 Nov 25, 2004 10:32 PM
