Need help with custom frame design? I can help with 3D prototyping
Hey guys and gals, I recently got into multi-rotor stuff for 2 main reasons :
- planes were taking up way too much room in my apartment (boxes of bits and pieces as) - lack of car and inability to access a flying field on my own I do 3D for a living, these days it's mostly developing/scripting, technical resolutions and lighting/rendering, but on top of that in early career I had 3-4 years of experience as a 3d modeler , where I did nothing but modeling/digital sculpting. Now if I'm not using 3D for work, I use it for everything else - prototyping, various volume/area calculations, physics simulation etc. I'm a fast modeler and for purpose of prototyping models don't have to be all that detailed and in most cases I dont even need to think about proper topology and other nuances, so I'd be more than happy to share my skill and help out anyone who might need it. Mini portfolio - http://tinyurl.com/c4yuxdt As I already mentioned I live in an apt building, and building stuff is quite challenging sometimes, lack of heavy machinery, a garage and a back yard is killing me, but I found ways to work around this (such as putting a chair in bathtub in drillign/cutting wood on it to avoid saw dust from spreading all over the place ) Lack of CNC, laser cutter or any precision tools suggested that I should be using plywood and wooden dowels as main build materials. They're cheap, easy to work with and could be painted, sanded, shaped just about any way you want. Here is my current workflow - I quickly design a frame in 3D, making sure that everything will fit, sometimes even animate arms and wires if I need the frame to be foldable - make sure all parts are 2D and could be made from flat sheets - export vector for each plate or "level" - print parts on paper - cut them out and trace on plywood - using $6 coping saw I cut out the shapes - drill holes in them - aseemble - and finally enjoy. My main goal is to make a simple frame, that protects flight controller and and the battery and manages wires well. currently I'm on my third version of the quad, still using same electronics (kk2.0 rctimer2830 1300kv + 8x4) I will add pictures of my designs in next post. If you'd like to suggest something or request files (Max, AI, STL, DFX, CAD etc) or even request custom design - feel free to post here ![]() I can make an easy to follow PDF with all parts and measurements that you could print, trace, and start cutting. Just to make it clear, I'm not selling my services, I'm offering free of charge help if anyone needs it. RCG community has shared a lot of knowledge, so why not share back? On top of that, together we could perfect a few designs for different weight classes and sizes If anyone has a laser or a CNC and wants 100% custrom design (could be full 3d, doesn't have to be flat 2D) let me know, I'd be more than happy to make something rather complex in exchange for a cnc cut pieces. |
v 1.5
Here is v1.5
Same electronics but shorter arms (400mm size) and lighter frame,600g without the battery. Still need to secure all wires with zip-ties and improve battery mount (maybe re-do top plate again). As well as shortening power leads from ecs.
Joined Sep 2012
Your work is very inspiring! My current project is very similar to yours. I even chose the same colors as your first mini quadcopter (orange and black). Here's a link to my progress.
http://www.rcgroups.com/forums/showthread.php?t=1730793 |
had first major crash yesterday
So far I have ~5hrs of combined flight time experience with multirotors (although 4-6hrs on phoenixRc simulator before I tried the real thing helped tremendously, can't recommend it enough) when it comes to planes I'm somewhat of a ballsy pilot, and old habits carried over onto quads as well. I hate hovering and slowly going back and forth. Yaw + pitch/roll it's what it's all about for me. I was doing some 8 shape patters and circles around the park and at some point went a little too high above my head and behind my back. Lost track of pitch/roll and over compensated, crashed into biggest tree around, ~size of 5 story building, it tumbled down through branches and fell on the ground. 2 broken props, broken arm, and 4 broken zipties. Pleasantly surprised that everything worked out so well and easily replaceable elements snapped first and there is no damage to motor shafts or KK. Currently I'm working on a folding quad (somewhat of an H-frame) that will have 750kv motors spining 10x4.5 props, fpv gear and 4000mah lipo. |
| Thread Tools | |
| Discussion Need help with designing | FlyBoysRc | Foamies (Scratchbuilt) | 19 | Jul 27, 2012 12:56 PM |
| Discussion who can design a folding spider quad frame? | imdone | Multirotor Talk | 3 | Mar 14, 2012 03:41 AM |
| New Product Custom frames and frame design | rp181 | Multirotor Talk | 24 | Sep 23, 2010 03:49 PM |
| Question Need some help with design decisions for a custom AP plane | Littlebear | The Builders Workshop | 15 | Aug 02, 2008 10:10 PM |
