Old Dec 08, 2013, 12:37 PM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
Ok... I belive my module was at that stae at some point during the struggle I had. I have attached it again. Just remove the training.txt. And I think you need to perform a initialization cycle.
Open source is still free but far from plug an play :-)
hakank is offline Find More Posts by hakank
Old Dec 08, 2013, 12:40 PM
hakank is offline
Sweden (┼kersberga)
Joined Nov 2004
Originally Posted by springer_bob View Post
Update...
I went back to the config file and changed the GPS_BAUD to 57600, reinitialized and now I am getting packets.
Thank you for your help, now back to what I was originally trying to do, set my PIDs
Bob
NP. Good to hear you got it spinning again. :-)
Old Dec 08, 2013, 12:41 PM
TheQuestor is offline
Find More Posts by TheQuestor
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
Thanks, but my unzip utility will not open your file....
I went back to V2.2 and tried the settings you sent earlier. The GPS Icon(satellite) is now green but no update packets are being displayed on the red led in the upper right corner of the GPS display.
Gotta love open source code
Bob
do you have the MTK3329?
woops you posted it was working as I was posting this lol
TheQuestor is offline Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Dec 08, 2013, 12:42 PM
springer_bob is offline
Find More Posts by springer_bob
springer_bob's Avatar
Joined Nov 2013
Yes, it's the MTK3329
springer_bob is offline Find More Posts by springer_bob
Old Dec 09, 2013, 09:10 AM
u2fletch is offline
Find More Posts by u2fletch
Joined Jan 2005
MTK3329 GPS Help
GPS connection was driving me nuts until I downloaded this GPS viewer utility
http://www.gtop-tech.com/en/page/download-01.html
Get the latest GPS viewer.
I have Arduino boards at home, but you can use any controller board with an FTDI interface to connect your GPS using the TX/RX lines to the interface.
It is easy to scroll through and see which baud rate the GPS is sending data.
From the GPS utility you can then specify what data refresh rate to use, specific data types to return, and baud rate. This is assuming that your GPS has some kind of a battery backup to save settings.
If it does not, then boot up the GPS and see what settings it defaults to, then set the code within Multiwii to match.
In NMEA mode, Multiwii only needs RMC and GGA data from the GPS. Anything else is not needed so you can uncheck those options from the utility.
u2fletch is offline Find More Posts by u2fletch
Old Dec 10, 2013, 03:34 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Nice link ... normally all you need is just a plain and simple serial console ... and this allows to check the GPS serial speed and protocol ...
The HK provided GPS in my case was arriving ready at 115k and NMEA ... using NMEA vs Binary ... lot of useless discussion .. fact is that ATmega2560 boards has enough power for handle NMEA without problem
e_lm_70 is offline Find More Posts by e_lm_70
Old Dec 10, 2013, 03:59 AM
TheQuestor's Avatar
Joined Mar 2013
For a quad maybe :P I still prefer to not have to convert. Just an unnecessary extra step.
Also the multiwii guys say 115200 is horrible for GPS because of the error rate.
This is from the config.h
"// avoid using 115200 baud because with 16MHz arduino the 115200 baudrate have more than 2% speed error (57600 have 0.8% error)"
now 2% doesn't sound like much but when you have hundreds of dollars in the air just waiting to fall out of it I'd prefer to keep it to 0.8% instead of 2% In fact I keep my ublox @ 38400
Old Dec 10, 2013, 04:28 AM
e_lm_70 is offline
Austria
Joined Jan 2004
LOL ... 2% is theory ...
In practice NMEA has a error check , so if something got wrong it is discarded
At 10hz ... even if 1 position is lost every second .. who cares ...
This error % on serial has a tricky mean ... you need to read in deep the specs of ATmega for get the full meaning ... and you will realize that it really is nothing
Anyhow ... you ublox works at 5hz at best .. the stock MTK GPS is 10hz, so ... 38400 would be hard to be used at 10Hz
I did not bother to check much mine .. it arrived already at 10Hz NMEA and 115k ... so .. I did not bother to change anything ... but ... yes in other GPS I like to keep NMEA, use only the 2 needed messages (this will save over 50% of serial signals) .. and use even 9600 bps ... in this way I can even run FrSky telemetry over the same serial port .. but this I do on 328 chip .. on a 2560 ... does not really mater much ... I have serial port in excess of my needs
Old Dec 10, 2013, 07:12 AM
Sp1k3 is offline
Find More Posts by Sp1k3
Joined Mar 2011
hey guys,
Where do I connect the serial bluetooth device on this board?
http://www.hobbyking.com/hobbyking/s...mpatible_.html
I was just wondering, as I have it, and am not sure where to hook it up and then if I need to configure something in Arduino?
Sp1k3 is offline Find More Posts by Sp1k3
Old Dec 10, 2013, 08:06 AM
Sp1k3 is offline
Joined Mar 2011
No, nothing need to be removed.
This board has already a i2c port.
The MS5611 has a different port then all the other i2c elements in the board, so it works fine in parallel.
In theory the old 085 baro could be still used for read some data, and eventually used as back up or safety ... but it will need some extra code.
What I did was just to disable (by code) the 085, and enable the MS5611
Since it is an extra module, I did cover it up, and place upside down ... so perfect for avoid direct sun light and some propeller wash or wind
As you may see on my video on elm70 youtube channel ... my alt hold fly is solid for me with this board.
I also have no reason to complain about GPS quality
Sorry for the ingorance, but I know how to enable the MS5611 barometer:
/* I2C barometer */
//#define BMP085
#define MS561101BA
but how do I disable the BMP085 on the board?
Old Dec 10, 2013, 08:12 AM
e_lm_70 is offline
Austria
Joined Jan 2004
/* I2C barometer */
//#define BMP085
#define MS561101BA
// in front of define BMP085
This is how you disable by code.
Clearly, from HW point of view, the BMP085 it is still there, still is in stand by, but since it has a i2c address not used by any other part of the code, it will not be used by multiwii , nor it will arm any functionality
Old Dec 10, 2013, 01:24 PM
TheQuestor's Avatar
Joined Mar 2013
hey guys,
it is connected to your I2C port and no sketch updates needed.
Old Dec 10, 2013, 02:29 PM
e_lm_70 is offline
Austria
Joined Jan 2004
i2c
Bluetooth goes over one of the serial port .. normally serial 0
Old Dec 10, 2013, 02:55 PM
TheQuestor's Avatar
Joined Mar 2013
i2c
On my Multiwii Pro boards I have always connected it to the i2c ports.
er I guess it's com 0 my bad.
Old Dec 10, 2013, 03:50 PM
Sp1k3 is offline
Joined Mar 2011
great thanks guys!
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
