Old Sep 23, 2012, 10:51 AM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
Hi all, I'm making the leap to a MW board from kk3 v3 and KK2, can I ask a favour? Could someone give me a hint to the connecting of the GPS. I don't want to let any magic smoke out
And also confirm that I am right in saying the GPS plugs into the 4 pins front and centre of the board?
I've been able to (with a lot of help from a MW user), to get my Talon Tri on a quite windy day, up and flying quite well. Will put it through a fine tune before further comment but all in all, looking good
Regards
WO
WitnessOnly is offline Find More Posts by WitnessOnly
Old Sep 23, 2012, 01:58 PM
marvin081 is offline
Find More Posts by marvin081
marvin081's Avatar
United States, TX, Laredo
Joined Dec 2011
@witnessonly
The way I have it connected is from left to right looking at the board with the arrow facing up is blue, green, yellow and black. And yes it goes on the middle of the board where the header pins are at.
Just un comment the define in the config.h for the Gps serial 2 and the baudrate. Also look for your magnetic magnetic declination and input it on the config.h you can get it at http://magnetic-declination.com/ and convert it to degrees.decimals here http://www.satsig.net/degrees-minutes-seconds-calculator.htm
Hope this help.
marvin081 is offline Find More Posts by marvin081
Old Sep 23, 2012, 03:21 PM
Glycol79 is offline
Find More Posts by Glycol79
Sweden, Skåne County, Jonstorp
Joined Sep 2012
No sensor data!
Hello
My first Multiwii board and my first post here
I got the board installed in a working quad, replaced the Naza. Just to test it out on a known good flying platform. I can upload the sketch, calibrate esc. But no sensor data in Wingui or Multiwiiconfig. Just flat lines and I2C error just jumps around. Tried calibrating acc and mag, no diff. In Wingui i can see RX data change on all channels, so communication with the board works. Did i get a bad board?
Also does anybody know what led2, led3 and led4 is for?
Glycol79 is offline Find More Posts by Glycol79
Old Sep 23, 2012, 04:19 PM
marvin081's Avatar
Joined Dec 2011
Hello did you uncoment the board type on the config.h?
Old Sep 23, 2012, 05:19 PM
Glycol79 is offline
Joined Sep 2012
Yes, the FFimuV2, got the gps working to. Shows my location on the map in WinGui. Also tried to uncomment the sensorns and left the FFimuV2 commented. No luck. If i arm and start the motors there is no rpm change when I´m tilting the copter.
Old Sep 23, 2012, 06:10 PM
knobby1 is offline
Find More Posts by knobby1
Australia, NSW, Bradbury
Joined Dec 2007
Originally Posted by marvin081 View Post
@witnessonly
Just un comment the define in the config.h for the Gps serial 2 and the baudrate. Also look for your magnetic magnetic declination and input it on the config.h you can get it at http://magnetic-declination.com/ and convert it to degrees.decimals here http://www.satsig.net/degrees-minute...calculator.htm
Hope this help.
Hey Witness,
Marvin is spot on with his info above, exactly the same as I have mine setup!!
Cheers,
Smithy.
knobby1 is offline Find More Posts by knobby1
Old Sep 23, 2012, 08:37 PM
Joined Jan 2010
Marvin and Smithy thanks so much, looking forward to setting it up now cheers
WO
Old Sep 23, 2012, 08:39 PM
marvin081's Avatar
Joined Dec 2011
No problem. Let us know how everything turns out.
Old Sep 23, 2012, 08:43 PM
marvin081's Avatar
Joined Dec 2011
@Glycol79
Does the Gui shows that the sensors are working? When u move the frame does the sensor data changes?
Old Sep 24, 2012, 12:17 AM
Glycol79 is offline
Joined Sep 2012
@Marvin
Nothing happens in the Gui when I´m moving the frame. Its only the i2c error count that changes. The indicators for activated sensors is green.
Old Sep 24, 2012, 08:43 AM
RotoGoat is offline
Find More Posts by RotoGoat
Disturbed, but in a good way.
RotoGoat's Avatar
Gold Coast, Australia
Joined Nov 2009
Originally Posted by RotoGoat View Post
I have my board up and running on my X quad, but dont seem to be able to get the GPS going. I have already defined serial 2 and baudrate to 115200 but the gps just sits there and I get nothing on the configGUI.
Can anyone help me out?
Aha! Got it going. I was playing around flashing the gps with different firmware and hey presto. Up and running 10hz 115200 baudrate! YAY.
RotoGoat is offline Find More Posts by RotoGoat
Old Sep 24, 2012, 09:23 AM
zagifly is offline
Find More Posts by zagifly
United Kingdom, England, Hailsham
Joined Aug 2007
Got this board set up and working perfectly in the GUI with 8 satellites on the bench in the workshop, now for the question, with my rabbit controller i can't arm the quad until it has 5 sattelites, how do I know this board has enough satellites before I take off. Going to use this on an FPV platform and I would hate to switch return to home and the quad just disappears over the horizon.
Dave H
zagifly is offline Find More Posts by zagifly
Old Sep 24, 2012, 11:59 AM
Tim2 is offline
Find More Posts by Tim2
Tim2's Avatar
Devon, Alberta
Joined Apr 2003
Which firmware did you end up using?
Tim
Tim2 is offline Find More Posts by Tim2
Old Sep 24, 2012, 12:22 PM
zagifly is offline
Joined Aug 2007
Answered my own question by studying the config h page, the red led marked 1 on the board starts flashing when the GPS has picked up 5 satellites.
Hope this helps!!!!!!!!!
Dave H
Old Sep 24, 2012, 12:26 PM
PierHenri62 is offline
Find More Posts by PierHenri62
Joined May 2010
Damned! Where do you see how to set it to10Hertz???
I'm turning foolish with that GPS!
Thanks for an answer, please.
Pierre
PierHenri62 is offline Find More Posts by PierHenri62
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 02:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 04:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 05:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 04:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 11:29 PM
