Old Dec 06, 2012, 09:33 PM
majik01 is offline
Find More Posts by majik01
Joined May 2010
Originally Posted by sirbow2 View Post
lol sorry. he just asked for help so i figured that was easier. in his orig post he didnt say anything about finding a preset so i gave him the individual.
Sirb*.... I hope you don't mind if I ask ... what kind of multirotor frame do you fly?
majik01 is offline Find More Posts by majik01
Old Dec 06, 2012, 10:32 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
First post updated on MultiWii on HK MultiWii Mega Board WITH MTK 3329 GPS
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 06, 2012, 10:54 PM
oddcopter is offline
Find More Posts by oddcopter
Quadcopter Addict
Joined Nov 2011
Originally Posted by TheFernMan View Post
Hey, thanks FernMan, I did all the things you mentioned and it all looks good in the GCS. Quad X is there and the GPS appears to work. I will see if I can get it flying now! About all I did other than what you mentioned was add my declination.
oddcopter is offline Find More Posts by oddcopter
Old Dec 06, 2012, 11:10 PM
TheFernMan's Avatar
Joined Jul 2012
awesome! ill also have to add that to the first post.Thanks!
Old Dec 06, 2012, 11:22 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
looks great, keep up the good work..
jabram is offline Find More Posts by jabram
Old Dec 07, 2012, 01:24 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
you challenge my experience haha
http://dduino.blogspot.com/2012/04/q...build-log.html
sirbow2 is offline Find More Posts by sirbow2
Old Dec 07, 2012, 01:52 AM
jabram is offline
Joined Jul 2012
yes you have to reupload to do those things.
for the IMU section, un comment these:
• ITG3205 Triple Axis Gyro
• BMA180 Accelerometer
• BMP085 Barometer
• HMC5883L Magnetometer
if youre going into MWC you better learn hte config file, as i said in the gchat. i will skype or something and show you. way easier that way.
Ok, I give in, I am impressed by use of fancy terms just like the next guy.
I have no clue what you mean, I am not really keen on cryptic guessing games.
Could you please explain exactly what you mean by all that in plain English which I may be able to comprehend..
Old Dec 07, 2012, 03:37 AM
ParamiLL is offline
Find More Posts by ParamiLL
R/C ruined me, But i have fun!
Denmark, Nordjylland, Nørresundby
Joined Jan 2012
Para ... did you upload a new sketch or did you use what was pre-loaded on the board? What I noticed with the pre-loaded board is that the FC freezes when you tilt it beyond a certain angle which is what you are describing .... so I would suggest uploading a new sketch. Not that hard and the board IS stable .... specially if you balance your props and use simonK flashed ESC's.
Yes i have done that several times. Could it be the PID settings too high or the ESC's calibrated wrong?
Regards,
Martin.
ParamiLL is offline Find More Posts by ParamiLL
Old Dec 07, 2012, 11:57 AM
pinoydad is offline
Find More Posts by pinoydad
Joined Jan 2009
Pinoy ... Post #262 has a short how-to for the GPS and two methods to configure the GPS using the MKT tool and the MWC dev release in case your GPS is not properly configured..
bit frustrated when i try to flash gps w/ the mtk. followed every thing on the pdf instructions but comes out "fail" w/ a funky red "x"..lol i want the doughnut!..what could i be doing wrong ..btw at wingui looks good still and red dot flashes ..and on the map still seems working although it seems wondering around few feet based on the size of my roof on the map..
pinoydad is offline Find More Posts by pinoydad
Old Dec 07, 2012, 12:34 PM
majik01 is offline
Joined May 2010
My apologies - not challenging at all - just asking a simple question.
Thanks for sharing the link. Nice blog .. lots of good information and very informative. Where were you when I needed you? I began this phase of the RC hobby many moons ago swimming through the hard core Mutliwii threads trying to figure out what people were talking about....
Now to my point. My high standing landing gears arrive the other day. I have my two axis gimbal ready to go. I know how to enable cam stab in config.h / Aux switching. However, not much out info out there for "tilting" a stabilized gimbal to look "down or up". Do you know how "camera tilt" is activated in cam stab mode? In the board, I can assign a channel to an analog pot for that function and free up a channel just for that purpose.
EDIT ----
I may have found the answer to my question. In config.h under Cam Stab, there are lines that enable mixing to the gimbal servos via Aux3 and Aux4 and that allows the gimbal servos to be moved while being stabilized. If my hunch is correct, I could have my quad FPV set up for HD videos pretty soon.
Old Dec 07, 2012, 12:39 PM
majik01 is offline
Joined May 2010
Pinoy .. you should congratulate yourself !!! if you can see your roof on the WinGUI "map" your GPS is already working. BUT did you input the magnetic declination into config.h? Very important to get that in or your quad will fly crazy circles and could crash. The tutorial is on the EOSBandi GPS write up. You have to reload the sketch - but you know that already.
Old Dec 07, 2012, 12:44 PM
majik01 is offline
Joined May 2010
Great job TheFernMan ... yo the MAN !
Old Dec 07, 2012, 12:57 PM
majik01 is offline
Joined May 2010
Regards,
Martin.
Silly question but have to ask anyway. Did you calibrate your ESC's with the same programming? You may have different ESC/motor calibrations and the board is trying to compensate. You can sometimes tell if the ECS beeps when you power on do not happen at the same time ...
Old Dec 07, 2012, 02:35 PM
Quadcopter Addict
Joined Nov 2011
Yeah, Fernman, that first page looks great!
Well, either I am getting better at this or multiwii has really improved over the last year, or both! I did a maiden and it flew great with no PID adjustments. I need to figure out what to do in addition to enabling the baro to get altitude hold to work and then try the GPS, but over all I was really impressed with how it flew.
Old Dec 07, 2012, 04:28 PM
Quadcopter Addict
Joined Nov 2011
So this BMP085 Barometer is not the best from what I have read. Any PID setting or tips on getting it dialed in for alt hold?
Edit: I have it holding pretty well now, if I get the throttle in just the right spot. However, I think I like flying it better with the baro off. It is not as jumpy and stays more level in flight.
HT-450 Frame with SK3 2826-1130kv Motors 8 inch props
Pitch and Roll PIDs - 9.1/.045/23
Alt PID - 2/.02/7
Oh, and I covered the baro with a piece of foam rubber.
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
