Old Sep 06, 2012, 10:15 PM
benybee is offline
Find More Posts by benybee
Indonesia, Lampung, Sukarame
Joined Dec 2009
Originally Posted by TheFernMan View Post
Extra..?? Your doubt about what?
i just confuse what to choose
HK one or CRIUS on rctimer
benybee is offline Find More Posts by benybee
Old Sep 07, 2012, 03:34 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Go for Crius AIO Pro. It's fantastic. Great sensors, can run multiwii AND megapirate. Get that + the CN-06 V2 GPS. You won't be disappointed.
WiseDuck is offline Find More Posts by WiseDuck
Old Sep 07, 2012, 03:35 AM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
I also faced the same dilemma, but ended up pulling the trigger on the HK one. I'm looking to use it as a fixed wing autopilot, so not so worried about the barometer resolution.
If I can't get ardupilot to work properly, the GPS module is a pretty good one and I'll use it on my CL-OSD upgraded G-OSD II.
lobstermash is offline Find More Posts by lobstermash
Old Sep 07, 2012, 03:55 AM
arkcom is offline
Find More Posts by arkcom
Northwest Arkansas
Joined Sep 2008
ArduplaneNG is made specifically for the Crius AIO Pro. That would be the easiest solution.
http://code.google.com/p/ardupilotdev/downloads/list
arkcom is offline Find More Posts by arkcom
Old Sep 07, 2012, 04:02 AM
Joined Jul 2012
So, a little more research (after I've already ordered it...) and it seems that for waypoint nav this needs a CRIUS I2c-GPS NAV board. So only a $10 saving on the Crius AIO + GPS combo and no support. And HK have already printed my order. Oh well.
Old Sep 07, 2012, 09:42 AM
setkroy is offline
Find More Posts by setkroy
Joined Sep 2012
And where there is at MultiWii Pro Flight Controller detailed instructions for installation and configuration?
setkroy is offline Find More Posts by setkroy
Old Sep 07, 2012, 10:11 AM
TheFernMan is online now
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Start a chat with them and return it! People say to order it from rctimer but dx.com has the CRIUS AIO Pro for $57 dollars
Try chatting with them if they haven't shipped it!
TheFernMan is online now Find More Posts by TheFernMan
Old Sep 07, 2012, 10:18 AM
TheFernMan's Avatar
Joined Jul 2012
Well this "Top Version MWC MEGA 2560 9DOF Flight Control Board Care Free + Self Return -X Mode" board is basically the same thing and it has three manual pdf link in the description called:
Mega 1
Mega 2
Mega 3
Other than that, its MultiWii software and support is from them. there threads here for MultiWii or as people start getting them, maybe this thread can be a support thread for this board.
Good Luck!
Old Sep 07, 2012, 12:40 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
weak baro.....
jy0933 is offline Find More Posts by jy0933
Old Sep 07, 2012, 12:53 PM
TheFernMan's Avatar
Joined Jul 2012
Originally Posted by jy0933 View Post
weak baro.....
yes lol you've said that already
baro is still the weakest sensor
that baro is not going to be anywhere close to useful (+/- 1m out door)
AIO has pretty decent +/-20cm i believe
still a valid point nonetheless
But with the appearance of these boards and others with better sensors, its driving down the cost of the more expensive boards like the DIYMulticopter MultiWii Mega Board. It used to be ~$160 plus the GPS module. Now its $92+$33=$125
They even change some of the description to include "Compatible with MegaPirate"
Old Sep 07, 2012, 12:59 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
the reason i stressed on the weak baro... just cuz... at the same price... you can get better sensor.. (AIO)... then why bother...
speaking of "high end"(kind of) we are looking at good alt hold, rth/rtl, loiter... and if baro is weak...it will cause unstable flight when alt hold is on and great power consumption(depend on pid somehow)
Old Sep 07, 2012, 01:03 PM
TheFernMan's Avatar
Joined Jul 2012
From your knowledge, could someone add sonar to that HK Multiwii board?
Might add some accuracy...
Old Sep 07, 2012, 01:05 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
sonar only work for close ground condition.. and yes.. any mega2560 board has enough serial port to connect sonar
and also mpng supports sonar
by saying close ground... i guess 5meter is the accurate limit
Old Sep 07, 2012, 02:22 PM
TheFernMan's Avatar
Joined Jul 2012
Doesn't MultiWii support sonar?
Old Sep 07, 2012, 03:43 PM
Joined Jul 2012
Once they print an order you're stuck with it unless there's a warranty issue. I'm going to just work with it and see what it can do. I reckon with its incredible price there'll be some passionate programmers out there that make it do waypoint stuff.
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
