Old Dec 04, 2012, 05:51 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Tip was use Multiwii dev version has auto configs your gps to the correct setting.
Description:
Description:
Description:
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 04, 2012, 05:52 PM
R.T.K.F is offline
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
Gold star and an elephant stamp majik01 for your post.
R.T.K.F is offline Find More Posts by R.T.K.F
Old Dec 04, 2012, 11:38 PM
majik01 is offline
Find More Posts by majik01
Joined May 2010
Fern ... if you use dev 1240 to configure the MKT3329 and go back to 2.1 - does the GPS unit retain the correct config setting i.e. 115200 baud rate / 10 Hz? If that is the case, I can use dev to set the GPS and upload 2.1 to fly instead of using the Mediatek tool to configure.
majik01 is offline Find More Posts by majik01
Old Dec 04, 2012, 11:39 PM
majik01 is offline
Joined May 2010
Double post
Old Dec 05, 2012, 03:18 AM
TheFernMan's Avatar
Joined Jul 2012
That's what I did
MultiwiiGUI doesn't work with dev 1240
Old Dec 05, 2012, 03:42 AM
PierHenri62 is offline
Find More Posts by PierHenri62
Joined May 2010
Hi there!
To enable GPS, what line must i alter, please?
(i've bought two HK multiwii pro: they work as a charm and easy to config, but i am not able to make that gps work)
Some help, please!!
PierHenri62 is offline Find More Posts by PierHenri62
Old Dec 05, 2012, 07:43 AM
majik01 is offline
Joined May 2010
Originally Posted by PierHenri62 View Post
Hi there!
Some help, please!!
Seems Part n is coming earlier than expected ....
a) GPS has to be enabled in config.h (see posted file in the HK or the link in Post #254) as below.
GPS
#define GPS_SERIAL 2 (Would be Serial 2 for the HK board)
#define GPS_BAUD 115200 // Your GPS’ Baud (for MKT3329 is 115200)
GPS connection to Serial 2 would be Tx to Rx, Rx to Tx, 5v to 5v, Grd to Grd. No that's not a typo.
b) Connect to WinGui 2.1 and on the realtime tab, the GPS lights need to blink red/green.
If GPS light is not active, your GPS unit needs to be configured. Two ways:
a) See Post#126 and follow the procedure on pdf imbedded in the MTK-firmware-tools-for-2.1.zip file found in the link to the Google code page to get the green donut (GPS working ....).
b) FernMan suggests using MWC dev 1240 configured for GPS (see posts above and below) and upload that then go back to MWC 2.1. Seems the dev sketch configures the GPS unit for proper baud/refresh rate. You can go back to MWC 2.1 or play around in dev ... but that is not a stable release ... you have been warned.
Old Dec 05, 2012, 08:06 AM
TheFernMan's Avatar
Joined Jul 2012
From jabram MPNG thread for the HK MEga MultWii board. You can use the new multiwii dev version. its dev 1240
when you're done, you can go back down to Multiwii 2.1 and enable gps under the config.h tab in arduino. uncomment by removing the //
Go ahead and give his thread a read, very informative
Originally Posted by jabram View Post
Easiest way to set up the supplied MTK GPS for correct baud rate etc is to first run Multiwii_dev_r1143 which has a routine which tries to guess the current GPS baud rate then sets and stores 115200 along with other settings, to use it edit the source to enable it to AUTOMATICALLY setup the GPS
in Multiwii_dev_r1143 config.h make these settings
http://code.google.com/p/multiwii/do...3.zip&can=2&q=
Compile and upload that to the HK Mega board, make sure your GPS is connected so the GPS is in fact setup.
#define FFIMUv2 // second version of 9DOF+baro board from Jussi, with HMC5883 <- confirmed by Alex
#define GPS_SERIAL 2 // should be 2 for flyduino v2. It's the serial port number on arduino MEGA
#define INIT_MTK_GPS // initialize MTK GPS for using selected speed, 5Hz update rate and GGA & RMC sentence
Old Dec 05, 2012, 10:03 AM
Joined May 2010
@Majik01:
i don't see the first line "define gps" (- the first you said) Can please tell me where i can find it? For the rest, that's all right.
Old Dec 05, 2012, 12:06 PM
majik01 is offline
Joined May 2010
@Majik01:
Did you get your GPS to work? You are 100% correct ... that line does not exist in MWC 2.1 ... and the earlier post edited accordingly.
Old Dec 05, 2012, 12:16 PM
Joined May 2010
I'll try tomorrow in the morning and keep you informed of my...progress.
For now, i leave, it is time toeat and go to sleep. In fact, i let my(great) age think at my place, lol!
Let you a feedbakc soon.
Thanks for all;
Pierre
Old Dec 06, 2012, 12:24 AM
pinoydad is offline
Find More Posts by pinoydad
Joined Jan 2009
majik got the basic setup figured out now moving on to gps enable ..thanks mucho you the man
pinoydad is offline Find More Posts by pinoydad
Old Dec 06, 2012, 12:58 AM
DOE is offline
DOE
Find More Posts by DOE
DOE
DOE's Avatar
United States, CA, Edwards AFB
Joined Feb 2012
I have done everything that the how to said to do. However my board will not take the sketch. This is a screen shot of what is happening to me.
DOE is offline Find More Posts by DOE
Old Dec 06, 2012, 02:40 AM
pinoydad is offline
Joined Jan 2009
red led blinks continuosly on the board ..is that normal ..wasn't doing that few hours ago untill i i corrected wrong wire connection on gps
Old Dec 06, 2012, 05:59 AM
TheFernMan's Avatar
Joined Jul 2012
Are you sure you're on the right com port?
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
