Yes, that is how I have been doing it. Wipe it on, and right back off BEFORE it dries. In my case, I wipe it off within 10~15 seconds or it will streak on me. I make sure there are no streaks before letting it set for the 10 minutes. If there is any streak that remain after the wipe down, I wipe the spot with the FMS or 770NC (whichever I am currently applying) and buff it right off. You don't want a dull spot to remain, or it will not come out easily after it dries for the 10 minutes.
Scott Smith NMPRA District 7 VP SEMPRA President |
Joined Dec 2005
New plugs and new moulds are always much riskier than seasoned moulds, They are prone to outgassing, porosity, lack of complete cure etc. If there's any stage of mouldmaking to take great care with it's new moulds! Don't give up! It's not an easy thing to learn, but the payback in personal gratification is well worth it! |
I was really bummed today... a Scratcho stab and fin that I laid up yesterday and PU filled this morning ... broke the moulds open and the paint had stuck very badly and the parts were stuffed.
But once again, it's my own fault probably, from cutting corners. These are quite well seasoned used moulds that were used with wax maybe 5 times, and with Frekote also probably 5 times. Nothing has ever stuck up in these moulds. I was using the same paint and the same epoxy resin as previously. Yesterday, before using them, I gave the moulds a rubover with Farecla G3 polish to clean off some slight roughness building up. After that I gave them 4 good wipes with Frekote 700NC. I guess the polish took off the sealed micro surface and I should have done the Frekote sealer treatment again. Do you guys agree? But ... I am feeling rather chuffed ... I have worked out a quick fix! I thought darn, I'm not gonna spend many hours chipping away and damaging the moulds like last time. I remembered the guy mentioning using paint stripper and I probably would have tried it but I don't have any and the shops are closed. I tried wetting the paint with paint thinners and although it remained stuck hard, I thought it was maybe a bit easier to chip/ scrape off. So I flooded the mould surface with thinners, laid a patch of paper towel over that to soak up some of the thinners, then laid a sheet of laminating film over that and put the other half of the mould on top, to press the plastic flat and keep it all shut tight. Ten minutes later, I was able to shave the paint off quite easily with a paint scraper knife, without damaging the mould. So good! This is an annoying glitch but on the plus side I have to say it's not taking me too long to paint, lay up, vac bag, and PU fill the tails. So it's not a huge deal. Just an hour or so of depression and wanting to quit building, instead of days. |
If you ever polish a mold you will strip off any release and sealer. When reapplying a semi-permanent system you want reapply the whole system......this would include the sealer.
I would be concerned that you are getting a "slight roughness build-up" on the mold surface. This shouldn't be happening. If you are getting bits stuck to the mold surface then the mold will get increasing reactive until it sticks. |
| Thread Tools | |
| Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. | AvB | Composites Fabrication | 233 | May 20, 2013 07:36 PM |
| Build Log New F1 project building plug and moulds | F1 madness | Racing Boats - Internal Combustion | 0 | Aug 19, 2012 01:45 PM |
| Discussion Decriminalize Drugs, Cut Drug Use In Half | Real Ira | Life, The Universe, and Politics | 51 | Jul 23, 2012 05:56 PM |
| Discussion Moulded wing layup advice | josh18 | Composites Fabrication | 25 | May 10, 2012 03:35 AM |
| Discussion What type of silicone is used for the silicone plugs used in moulding fuselages? | Tony D. | Composites Fabrication | 14 | Nov 19, 2006 02:04 PM |
