Old Sep 05, 2012, 10:59 PM
compuatic is online now
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Antenna tracking using RSSI vs GPS location
I am planning on building a diy arduino based antenna tracker. Can someone go over the advantages of tracking using rssi vs gps? Rssi seems like a simpler path and the algorithm should not be more complicated either.
compuatic is online now Find More Posts by compuatic
Old Sep 06, 2012, 11:47 AM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
help
Old Sep 06, 2012, 01:07 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
have you looked at IBCrazy's antenna tracker? he used RSSI....
http://www.rcgroups.com/forums/showthread.php?t=1337608
aaronredbaron is offline Find More Posts by aaronredbaron
Old Sep 06, 2012, 01:09 PM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
And heres GPS style, arduino based
http://www.rcgroups.com/forums/showt...ntenna+tracker
mrfliboy is offline Find More Posts by mrfliboy
Old Sep 06, 2012, 02:04 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Rssi only needs a couple of vrxs to work. Gps needs to be either data transmitted over audio channel, included in video(VBI) or direct. I've done a direct system using an Arduino to decode and a pair of 2.4ghz Xbee's.
Martin Y is offline Find More Posts by Martin Y
Old Sep 06, 2012, 03:31 PM
slowjett is offline
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
RSSI tracking can be a problem. If someone else fires up something in your freq range your tracker will focus on it instead of your plane.
slowjett is offline Find More Posts by slowjett
Old Sep 06, 2012, 04:01 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Guys, thanks for the links and info but i'm not asking for implementation help or how to. i'm trying to figure out why one path would be better than the other.
slowjett, if someone interfers with the frequency then the vtx will go out of whack too which is a bigger problem. the tracker loosing it would be a second order effect.
Old Sep 06, 2012, 04:22 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Very few people use tracking, and fewer still have likely tried both so
not many can answer from personal experience.
One advantage to GPS based is you only need one antenna and it
can run off a pan&tilt mount, while all the RSSI based ones I know of
use 2 or 3 antennas for pan only with no tilt. Turning 2-3 antennas may
be practical at 5.8 and 2.4 Ghz, but not so much with big 1.2-1.3Ghz
and 900Mhz high gain antennas.
Not being able to track straight up may or may not be an issue for you.
It is relevant what happens when someone else's signal
swamps yours. RSSI based will always turn to face the strongest
signal, and then when they switch off it may not find your plane's signal
again. With GPS, it'll likely just stop actively tracking while the GPS
signal is gone, but resume as soon as the interference goes away.
That said, I was recently flying with a popular GPS based tracker and
when I flew into some static (behind trees and structures), the tracker just
gave up and spun around to north which meant I lost A/V signal completely
and potentially permanently.
Only way to recover was to physically spin the tripod head back around
till it picked up the signal, and then as tracker turned itself, had to turn
the tripod back again. Very annoying. Seems like a softare bug to me
as I'd have expected it to just freeze where ever it lost the signal
and wait for it to come back. Any other behavior almost guarantees
eventual loss of the plane.
BTW, in case it's not obvious why an RSSI tracker uses 3 antennas,
if you try to use 2 antennas, you typically aim both out a bit to each side,
and then try to keep the RSSI balanced, but that means pointing both
antennas a little off center all the time (never flying the center of the beam
of either antenna).
Only way way to avoid that is to use 3 antennas. 2 dedicated to tracking,
1 more in the center for the A/V signal.
ian
Daemon is offline Find More Posts by Daemon
Old Sep 14, 2012, 05:04 PM
rbcodell is offline
Find More Posts by rbcodell
United States, UT, Sandy
Joined Nov 2010
Coincindentally, I just built one, and posted it in the FPV forum. Here is the link. I would love to cooperate on improving it. I just flew with it the first time to day and was generally satisfied with a few small problems.
Dick
rbcodell is offline Find More Posts by rbcodell
rbcodell is offline
Joined Nov 2010
Dick
http://www.rcgroups.com/forums/showt...hlight=arduino
Old Mar 24, 2014, 10:35 PM
quadcopter007fpv is offline
Find More Posts by quadcopter007fpv
quadcopter007fpv's Avatar
United States, CA, Riverside
Joined Feb 2012
here is the one i use ,rssi based
http://www.rcgroups.com/forums/showthread.php?t=2024405
quadcopter007fpv is offline Find More Posts by quadcopter007fpv
Discussion Anyone use a different GPS on their Immersion tracking antenna? tekrunner FPV Equipment 38 May 13, 2015 04:05 AM
Discussion GPS vs. RF Tracking healthyfatboy FPV Talk 4 Sep 28, 2011 08:04 AM
Discussion antenna tracking with rssi voltage atari7202 FPV Talk 8 Feb 05, 2011 12:33 PM
Discussion Diversity antenna vs. Tracking rsowder FPV Talk 13 Feb 14, 2010 01:43 PM
Discussion Using a GPS / GSM based tracker for downed plane locating air UAV - Unmanned Aerial Vehicles 1 Oct 02, 2007 05:32 AM
