Old Sep 05, 2012, 10:53 PM
Rightfly is offline
Find More Posts by Rightfly
I use EXPO and Senior Rates
Rightfly's Avatar
United States, MI, Custer
Joined Jan 2010
Motor Question - Probably a dumb one!
If I have a motor that I only know the Kv and voltage rating. Is it safe to compare another motor which you have all the data and it's stator is within 2 mm in diameter but maybe 30 to 40% longer as having more power capabilities?
My logic says yes. But since I have only been fooling around with this stuff for a couple years I wanted to get reassurance from the more expert electric flyers.
Thnaks.
Rightfly is offline Find More Posts by Rightfly
Old Sep 05, 2012, 10:59 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Generally, bigger motors will be able to handle more current (and thus power at a given voltage) assuming the Kv values are the same and efficiencies are in the same ballpark (efficiency is determined by PRICE, not what the manufacturer's data tells you ).
Note that the Kv value itself doesn't tell you a whole lot, and most "voltage ratings" are useless numbers.
There are a whole lot of variables involved here.
Piece is online now Find More Posts by Piece
Old Sep 06, 2012, 04:12 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If it's longer and it weighs more it probably has a correspondingly greater power capacity. The other parameters don't really matter very much as far as power rating goes.
200W is still 200W whether it's (approximately) 3S/18A @ 3000Kv or 2S/27A @ 1000Kv. Just different size props that's all .
Steve
slipstick is offline Find More Posts by slipstick
Old Sep 06, 2012, 12:36 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
As far as Kv, if you have a drill (prferably a drill press) a tach and an AC volt meter, you can figure out the Kv. Hook the motor to the drill and run it at a constant speed. Use the tach to get the speed and the volt meter to read the voltages from the three phases. There's a formula to calculating the Kv from the RPM and voltage generated, but Ken Meyers has developed a spread sheet to do the math. Here's a link to Ken's instructions with the spread sheet <http://www.theampeer.org/Kv/kv.html>.
Ken also has a rule of thumb for input power limits for outrunner motors based on weight. A good estimate is between 1.5 watts/gram and 3 watts/gram.
Those two sets of numbers, the Kv and the input power range, should get you n the ball park with any outrunner motor.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Couple of probably dumb newbie questions. Treetop Scale Boats 23 Jan 05, 2009 12:35 AM
Question Okay, probably a dumb noob question, but... SEC Radios 17 Jan 17, 2006 04:59 PM
Probably dumb question CC-25 Epoxy Cup Castle Creations 2 Dec 14, 2004 05:22 PM
Probably a dumb question... ctdahle Electric Plane Talk 4 Jul 07, 2004 02:09 PM
Probably a dumb battery charging question... Dennis Fenrick Power Systems 4 Jun 20, 2001 06:53 PM
