Old Sep 05, 2012, 09:46 PM
Joined Dec 2010
Waterproof LED's stop working when waterproofing removed. Why???????
Hi, I am trying to wire up some yellow waterproof LED's from HobbyKing, but when I remove the waterproof covering they cease working. I hooked up a strip of three and slowly peeled back the waterproofing. The second I get it off the 1st LED, the whole set of 3 stops working. I bought the waterproof set because it was in stock when the others weren't, but I really don't want the waterproofing on it. Any idea what's going on and/or how to fix the lights I have already removed the waterproofing from?
Here are the exact lights I'm talking about: http://www.hobbyking.com/hobbyking/s...dProduct=14289
panther3001 is offline Find More Posts by panther3001
Old Sep 05, 2012, 11:19 PM
United States, CA, El Dorado Hills
Joined Jan 2011
Sounds like some of the copper got pulled off. Why did you remove the waterproof covering? Weight? I don't think there is an easy fix unless it is the copper, then you have to solder a jumper to fix the break, not worth it...
peatmoss is offline Find More Posts by peatmoss
Old Sep 06, 2012, 06:43 AM
Joined Dec 2010
Upon further inspection, and after ruining 12 LED's in total now, it appears that as I remove the waterproof covering, the little tiny plastic "lens" thing covering the LED head is also pulled off, thereby disabling that LED, and immediately causing an open circuit to the other 2 LED's in the 3 LED strand. Then they all turn off. Once the lens is removed, or even jarred loose, pushing it back in seems to be to no avail.
I removed the covering for weight yes, but primarily for mounting purposes. With the covering off I can actually put the LED strip face-down and easily embed the LED's themselves inside the foam sheet---causing the plane to have a soft glow from the inside out. That's my desired effect, so I really do need the waterproofing off to accomplish this.
If nobody knows how to fix these LED's I'll stop ruining them, put them off to the side, and pull this effect off using a different color of non-waterproofed LED's I have. Then, I'll put another order in HobbyKing sometime and just get a strand of non-waterproofed yellow to replace my waterproofed one. Looks like I may have to leave the waterproofing on these, and use them as-is if I don't want to ruin them.
Old Sep 06, 2012, 06:47 AM
Joined Dec 2010
I also tried refilling the LED "lens" with Epoxy, hot glue, and white silicone bathroom tub sealant. None of them made the light strand work again....
Old Sep 06, 2012, 07:26 PM
Joined Aug 2012
The "lens" of an LED usually contains the wires to the actual chip.
Not sure why anyone would buy LEDs from HobbyKing or any other RC outfit, unless they are fitted to plug right into your receiver. LEDs are cheap and widely available.
Mouser and Digi Key are two outfits that will sell you quality LEDs. The only problem with buying LEDs from either of those outfits is that they both carry hundreds of models with all sorts of specifications and packages.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Sep 06, 2012, 07:48 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
You answer your own question
Precisely why buying from HK or another rc vendor makes it so easy. These strips are easy to modify to fit any particular application. They can be short, long, bent, chained together, different colors, color changing, and easily install with any connector the modeler chooses to use. IMO RC retailers are a much better option for people that want a simple plug n play solution.
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Sep 06, 2012, 09:10 PM
Joined Aug 2012
If you're buying parts and modifying them, it's no longer plug-and-play. Then, you might want more choices. My only point here is, there are other options.
Old Sep 07, 2012, 12:18 AM
Dont blame me I dint vte 4 him
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Matt these are self adhesive strips that are extremely bright and very easy to hook up. They are the "arf" of nightflying, except they are better, brighter, and easier than any previous way of lighting up an airplane. The flying wing pictured below has 480 leds and will light up the ground from 50-60 feet up. The video is harrymc's plane but should give you an idea of how well they work in flight
Harry's & TIm's Night Radians.wmv (1 min 19 sec)
David Hogue is offline Find More Posts by David Hogue
Old Sep 07, 2012, 07:29 AM
Joined Dec 2010
Here is a picture of the Delta Wing I was wiring lights into. It has only 27 LED's on it, with ALL of them except 3 on the front top (just behind the motor) shining from *inside* the foam. The leading edge lights you see in this picture (sorry, poor quality shot using my brick phone) are actually shining through from the *bottom* of the plane, passing through 3/8" of foam, a layer of spray paint, and 3 layers of paper. The green tail lights are also shining from inside the foam, as the light strips are face-down. I have yet to fly this plane at night, as I just finished it last night after midnight, but it flies awesome in the day, and goes somewhere around 70-80 mph I believe with it's 300 W 2200 kv motor and a 3-Cell 1300 mah Lipo. It has only a 26" wingspan and weighs ~ 0.8 lb.
PS. this is my first night-flier ever, so I hope it works well!
Lastly, I'd like to note that these 27 LED's, *with* shipping, (let me repeat: ***WITH SHIPPING***) from HobbyKing, cost me <$5.
Old Sep 07, 2012, 06:53 PM
Joined Aug 2012
I have to say that those look pretty slick.
I need some electronic parts for other things; I'll try to remember to look at the LED selections at the same time to see how the price stacks up. I'll probably go the "hard" route.
Discussion Do I need worry about inducted voltages when adding LED's to ESC battery? Deadstick 8409 Power Systems 3 Sep 08, 2012 09:15 PM
Discussion Some UM's dont work with Champ's TX, why? bm2thirsty Beginner Training Area (Aircraft-Electric) 15 May 12, 2012 08:42 AM
Question Reduced brightness when running led through brushed esc - why? xraydoc Night Flying 3 Aug 30, 2010 04:29 AM
Help! The LED on a few on my controllers stops working after I do a firmware update. gonzales Castle Creations 2 Feb 14, 2010 01:30 PM
Esc stop working suddenly. Why? peetrd Kontronik 7 May 10, 2004 01:38 PM
