Old Sep 05, 2012, 07:08 PM
RayR is offline
Find More Posts by RayR
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
AC Blast Cat for Q Offshore
Bill asked me over on OSE whether I would do a build thread on this boat. So here it is.
This is an AC Models Blast Cat. It is 40 inches long. I hope to run it in Q Offshore, though the boat may be too heavy to do so, we shall see. It weighs 7.4 lbs empty, so should finish around 12 lbs. If it doesn't work for Q I will repower on 10S.
This hull is noted to be exceptonally stable, but not the fastest boat on the pond. It has won many trophies because in finishes every heat. The old quote comes to mind " In order to finish first, first you must finish!"
RayR is offline Find More Posts by RayR
Old Sep 06, 2012, 04:46 AM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
You're right Ray. The 1527 does look a little on the small side in there. This hull looks more like 2028 material. (since you have one already).
I have a set of WRP 5" rail mounts for a 1527 if you need them. I'd be willing to let you use them for free, and if you decide to keep the 1527 in it, sell them to you later on.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Sep 06, 2012, 06:02 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Thanks for the offer Bill. A set of WRP mounts are already on the way.
Old Sep 06, 2012, 07:18 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I think a 40" hull is just too much for that power system. Something in the 34-36" range would probably work a lot better with that motor on 6s2p.
wparsons is offline Find More Posts by wparsons
Old Sep 06, 2012, 07:54 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I ran a 1527/1.5Y on 10s in my 47" Promise Hobby mono originally. (that's what the 5" mounts are from). It worked pretty good (faster than the replacement Lep 5692) until the day I over propped it and let the magic smoke out of the motor. Burned 2 of the 3 esc connector wires right out of it.
Old Sep 06, 2012, 03:13 PM
Raydee is offline
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
I always wanted to try a Blast Cat but back in the gas days it was one of the slower cats out. With FE power that might change but I think that the 1527 is going to run very hot in that hull considering the fact that it is a wet running boat to begin with. I still like the look of that hull though.
Raydee is offline Find More Posts by Raydee
Old Sep 06, 2012, 04:20 PM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
The reason I purchased it is it's one of the few big boats that meet the 40" length limit for Q. In open cat I would much rather have the new full canopy R42.
I am also considering a 2215/1Y for power on 6S.
Old Sep 07, 2012, 05:17 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
You might even want to try one of the "proteus" motors that KB is selling. The shorter can in delta configuration is 1280 kv and a lot less expensive than the Neu. http://www.rcgroups.com/forums/showthread.php?t=1725984
Old Sep 07, 2012, 07:04 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
This would be my choice for a Q cat:
http://www.offshoreelectrics.com/pro...rod=Aero-sc-40
Maybe not the lighter "electric" layup, but the 36" hull for sure.
Old Sep 07, 2012, 07:44 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Hey Ray, one 2215 left at clearance price!! $399 and they have ONE 1440kv left which is a perfect kv for 6s in my opinion. If its a tad lowish to you just run an x452/3 - x455/3.
http://www.offshoreelectrics.com/pro...eu-2215&cat=23
scorpion1 is offline Find More Posts by scorpion1
Old Sep 14, 2012, 03:29 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
This looks a little more appropriate.
Old Sep 14, 2012, 05:07 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'll second that thought.
Old Sep 18, 2012, 04:06 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Starting the mockup phase. I'll move the motor back and forth to get the best weight distribution.
The "butch's block" will not be used, it is however the best tool I have found for setting motor angle with minimal stuffing tube bend, and makes a perfect hole when used as a drill guide.
Old Sep 20, 2012, 07:11 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Will this be making a debut at Ackerman this Sunday Ray?
Old Sep 20, 2012, 02:27 PM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Unfortunately, it won't be done in time for Sunday.
Help! Joysway offshore cat light... syog100 Micro and Sub-Micro Boats 6 Nov 24, 2012 11:07 AM
Discussion joysway offshore lite cat syog100 Micro and Sub-Micro Boats 2 Aug 27, 2012 03:35 PM
For Sale AC Blast Cat Hull with some hardware h20guy Boats (FS/W) 0 Jul 27, 2012 07:54 AM
For Sale Aeromarine Offshore Cat 50" With Clutch, Pump, Zenoah G23, nice. $400 huminski Boats (FS/W) 0 Feb 28, 2012 02:13 PM
Build Log Sprint Cat 40 for Q Offshore bill34207 Racing Boats - Electric 64 Oct 25, 2011 06:38 PM
