Old Sep 05, 2012, 02:56 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Question
Speed 400 pylon racer wing composite construction- Complete!
so i've got a little speed 400 pylon racer that i've got a power system for that should take it pretty close to 150-160mph with the correct prop.
The wing specs are:
3 3/4" root chord
2 3/4" tip chord
32" span
The wing cores are Dow Blue-foam that get a layer of 2"x24" Uni-carbon (probably 3/4-1oz) on the top and bottom, and then a 4" wide strip of glass along the wing core joint. This is all sheeted in 1/32" balsa.
I plan to vacuum bag this all to the cores and then use painted mylars to bag the cores with the paint scheme.
My question is, since this was originally designed for a brushed speed 400 motor (maybe 100-120mph), Would it be beneficial to put some lightweight spread tow Carbon fabric for the outer surface finish instead of 3/4oz glass?
I'm expecting the weight to be around 16-20oz hopefully closer to 16 than 20 though.
thanks,
Thomas
invertmast is offline Find More Posts by invertmast
Old Sep 06, 2012, 05:48 AM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
Add some rowing in a groove on top and bottom to act as a spar... A 25g/dm + 80g/dm at 45 degree is plenty for layup. No need for wood.
SpeedMaster is offline Find More Posts by SpeedMaster
Old Sep 22, 2012, 10:36 PM
Joined Mar 2004
Well...
I just followed the directions included with the kit to build the thing..BUT I vacuum bagged the uni-carbon, glass wing core joiner and 1/32" balsa sheet to the wing. Then I got some mylar and some spread tow 1k carbon from a guy in here and waxed, painted and vacuum bagged the carbon to the wing and stab. This was my first try every doing this, and I think for any "simple" wings for now on, i'm going to be doing this more often, its AWESOME!
Old Sep 22, 2012, 10:50 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Long live the Skat. Great job on it!
Troy is offline Find More Posts by Troy
Old Sep 24, 2012, 03:09 AM
UAS Test Pilot
Norway
Joined Jul 2003
Very nice!!!
Old Sep 24, 2012, 12:47 PM
jbarnhardt is offline
Find More Posts by jbarnhardt
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
Thomas, that looks great! Very nice job with the Samurai fabric.
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old Sep 24, 2012, 12:48 PM
Joined Mar 2004
Thanks everyone! Thanks for the fabric john, this stuff is awesome! I had allot of guys at the field as my if i had the molds and how much for one, unfortunately no molds
Sold VIP 27” Speed 400 pylon racer ajeepham Aircraft - Electric - Airplanes (FS/W) 6 May 17, 2012 06:19 PM
Wanted speed 400 pylon racer or ace simple 400 val1756 Aircraft - Electric - Airplanes (FS/W) 4 Dec 10, 2007 11:17 AM
For Sale F/S Sprint Speed 400 class pylon racer JimT Aircraft - Electric - Airplanes (FS/W) 1 Nov 10, 2005 01:23 PM
F/S Matney Model's Vixen Speed 400 pylon racer kit bgriggs Aircraft - Electric - Airplanes (FS/W) 2 Aug 30, 2004 07:17 PM
Wing Incidence For a Speed 400 Pylon Racer? W Cole High Performance 6 Dec 02, 2002 11:16 AM
