Old Sep 05, 2012, 03:09 PM
LoopingFred is offline
Find More Posts by LoopingFred
Vini, Vidi, Scalies
LoopingFred's Avatar
Ireland, Dublin, Dun Laoghaire-Rathdown
Joined Oct 2003
LaserCut Software
Hi there,
Is there any Lasercut software users here? (for laser cutting machine)
I would like to know, hen you import dxf files, how do you prepare the files?
In my case, files are generated with Turbocad (v17), then transfered to Autocad, where I re-do all the polylines (because when I save from Turbocad in dxf, all is lost! (unless I am missing something ) )) and finally, saved in dxf, but Autocad2000.
All good and working like this, but I am pretty sure that can be improved, so as the cutting quality as I think the splines are still seen as dot to dot.
Sorry if I am not clear enough, simple problem, but pretty hard to explain clearly, but hopefully, someone will know what I am talking about!
Fred
LoopingFred is offline Find More Posts by LoopingFred
Old Sep 11, 2012, 12:10 PM
limeybob is offline
Find More Posts by limeybob
United States, TX, Rockwall
Joined Jun 2007
Originally Posted by LoopingFred View Post
Hi there,
Fred
Lasercut, is that a brand of machine?
My epilog has a Autocad driver, splines are no problem.
limeybob
limeybob is offline Find More Posts by limeybob
Old Sep 11, 2012, 12:59 PM
RCROBBY is offline
Find More Posts by RCROBBY
Laser Cutter Guy
United States, PA, Greensburg
Joined Oct 2009
I use lasercut. It reads dxfs fine. all my cad work is done in AutoCad. if you are getting choppy Plines then look into how many segments you have on a pline. the higher the number of segments, the smoother the line will be and also the output in the laser.
Why are you using 2 cad programs??? why not just use AutoCad, that would be much more efficent IMO.
What version of lasercut are you using?
what laser do you have?
what version of ACAD are you using?
RCROBBY is offline Find More Posts by RCROBBY
Old Sep 21, 2012, 09:15 PM
worldraft is offline
Find More Posts by worldraft
worldraft's Avatar
Canada, ON, L'Orignal
Joined Sep 2006
Laser cutter Engraver
I got my laser a couple of months ago and so far it's working good. I'm using Acad 2010. There are things I don'y know yet but it's coming along pretty good. I have a question however. One of the project that I have is to make a PCB but to do this I need to do one past, engraving the paint I don't want then putting the PCB in acid. Once the acid has done it's job, I need to put it back on the machine to cut all the holes in the PCB. The laser has to track in the very same step as the first pass or the hole won't be in the right place. Any suggestion?
Jean
worldraft is offline Find More Posts by worldraft
Old Sep 21, 2012, 10:44 PM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Jean
Hi Jean,
I have done things similar to this. What I do is make up a fixture to make sure I put the sheet in the exact same spot on the laser table. Make sure you do not move home before you complete your project.
Jim
eliworm is offline Find More Posts by eliworm
Old Sep 22, 2012, 09:05 PM
worldraft's Avatar
Joined Sep 2006
Thanks Jim
I was hopping there was a better way because my laser does not come back to the exact same place if I shut down the machine an continue the next day. It's a fraction of a mm but that's enough to ruin the job.
Old Sep 29, 2012, 08:10 PM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
to worldcraft
I use a plasma cutter at work that doesn't keep a good "home point" from day to day. for jobs that need to be done in stages like yours I cut a Jig fixture with (or for) the original part. Then later I cut another jig when further work needs to be done.
hope this helps, Alex
A Monell is offline Find More Posts by A Monell
Discussion Free Plans for Lasercut Frames / mounts? heinduplessis Multirotor Talk 3 Jun 30, 2012 12:26 PM
Do you need to make adjustments to CAD for lasercut kits austinflyer Modeling Science 10 Feb 04, 2004 09:45 AM
TurboCad and lasercutting? chlee The Builders Workshop 7 Dec 15, 2003 07:56 PM
Yippee! lasercut Gentle Lady chlee Thermal 4 Feb 06, 2003 12:21 AM
Lasercut Componets for F-14 Twin? heli3d Electric Ducted Fan Jet Talk 2 Jan 31, 2003 10:45 AM
