Old Sep 16, 2013, 03:00 PM
JoanC is offline
Find More Posts by JoanC
Joined Dec 2001
I'm afraid I will not maiden it this weekend. I was making the final tests today with the retracts and my front retract stopped working. I have disassembled it and it seems an electronic problem as the motor only works in one direction. Let's see how long it takes to have it repaired.
JoanC
JoanC is offline Find More Posts by JoanC
Old Sep 17, 2013, 07:42 PM
tommywatson is offline
Find More Posts by tommywatson
Sydney Australia
Joined Sep 2003
1.7m Viper Building instructions
I have been give a 1.7m Jet Tang Viper to build for a friend. I have figured most things that need to be done, but I still have a few questions.
1 Tailpipe, I assume the roll of Mylar is for the tailpipe, Am I correct. I have a StuMax 120mm fan and it fits the intake adaptor OK, I was just wondering about the tailpipe. I was going to use aluminium tape to hold it together and to the fan.
2 Tail Servos, I can see how they are mounted. Can I assume that the internal blocks for the horns are in the correct position in the elevators?.
I was going to use Hitec 5245MG servos, Any comments
3 Tail mounting. Do I just have some small screws into the tail spar to hold the tailplane halves on to the spar. If they were glued on you could never replace the servos. Ok, I know that is a dumb question. Same for the wings? .
Is there a build instruction anywhere on line?
Tom Watson
Sydney Australia
tommywatson is offline Find More Posts by tommywatson
Old Sep 19, 2013, 07:15 AM
icicles is offline
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
Tom Watson
Sydney Australia
Hi Tom,
I just use normal cello tape inside and out on my thrust tube. Aluminium tape on the tube to the fan is okay. I also use clear cello tape from inside the tube to the outside of the fuse. As an extra safety.
Yes the wooden blocks are inside.. Sorry i don't use Hitech. I am using Futaba bls153 7kg torque.
I'd bolt the stabs on with the hardware included. Especially if you want to get a servo out. Do the wing differently, put a threaded stud in the wing t nut. Then use a large nut in the fuse.
Dig up the baby Jet T eng 90mm thread, it is basically the same build just bigger. Also you will find a manual there which is good enough for the big Viperjet. I'd go off Billy D information regarding c of g etc. He's definitely done plenty of flying with his turbine one. He's the man.
Hope this helps. Sorry for this, done it all through my phone
Chris
icicles is offline Find More Posts by icicles
Old Sep 19, 2013, 11:00 AM
Sydney Australia
Joined Sep 2003
Hi Chris,
Thanks, I have started to look through the 90mm build thread and it is all starting to make sense. I will start soon on the build and I am sure I will have more questions. I have built a few composite model in the past and I just wanted to make sure I don't make too many mistakes.
Regards
Tom Watson
Sydney Australia
Old Sep 19, 2013, 08:53 PM
lashmett75 is online now
Find More Posts by lashmett75
Not a Drone pilot
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
FYI...Tam is working on new ducting for the Viper. Mine is the ginnie pig. But with the updated ducting this will allow a much large fuel tank to be place between the 2 ducts.
He also has completed the same turbine conversion ducting on the Triple XXX.
I will try and get some pics next week when I swing by the shop.
James
lashmett75 is online now Find More Posts by lashmett75
Old Sep 23, 2013, 07:42 PM
Z06kal is offline
Find More Posts by Z06kal
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
What's everyone using for a rudder/elevator servos? All using JR DS3421?
Z06kal is offline Find More Posts by Z06kal
Old Sep 23, 2013, 08:34 PM
icicles is offline
icicles's Avatar
Joined Jul 2006
Futaba brushless bls153 for me
Chris
Old Sep 24, 2013, 12:51 PM
JoanC is offline
Joined Dec 2001
Hitec HS-7245MH for me
JoanC
Old Sep 24, 2013, 01:12 PM
Z06kal is offline
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
JoanC
Did those fit okay? 16.8mm seems wider or as wide as the stabilizer?
Old Sep 24, 2013, 03:50 PM
pavlis is offline
Find More Posts by pavlis
Joined Feb 2013
there is one big MINUS on this jet.. and the customers who are building it as turbine have this concern.. there is no hatch to see the turbine when it starts.. RARE but not impossible to happen is when a fire may start by the turbine and you need use your fire extinguisher
what happens then .. how do you have access to the turbine?
JTM needs to modify this part
pavlis is offline Find More Posts by pavlis
Old Sep 24, 2013, 04:07 PM
Z06kal is offline
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
You can see some over the top of the intake ducts with the canopy hatch off. You could also modify the bottom hatch with spring loaded pins or some other quick access retainer so you can start it with the bottom hatch open and keep a mirror under there if you wanted to see it further. Also let's not forget that this is an EDF model...
Old Sep 24, 2013, 04:15 PM
pavlis is offline
Joined Feb 2013
Originally Posted by Z06kal View Post
You can see some over the top of the intake ducts with the canopy hatch off. You could also modify the bottom hatch with spring loaded pins so you can start it with the bottom hatch open and keep a mirror under there if you wanted to see it further. Also let's not forget that this is an EDF model...
I agree.. but due to the fact that most are building it as turbine it should have a second version with a hatch.. The XXX does have.
I asked JTM if they could do a v2 with a hatch..
I'm currently in the talks to start a webshop with them. no intention to bash in BillyD thread bytheway. nothing is official yet and I'mi nthe other side of the Globe in Cyprus.
Billy is a great guy and been listening and answering questions from me and everyone else. to give you an idea how far away I am from my idea Im still not sure what servos I should use on flaps and ailerons
I'm building one of my own Paf Sting Evo and I'm using JTM retracts. got some good reviews on the latest versions.
Old Sep 24, 2013, 04:27 PM
Z06kal is offline
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
The nice thing is that there is plenty of room in the wing for any standard size servo so the sky is the limit. You could put a 480 oz/inch servo in there if you wanted.
Old Sep 24, 2013, 04:44 PM
pavlis is offline
Joined Feb 2013
the ailerons don't need that much power.. so any size servo above 4-5kgs would be more than adequate. the elvators and rudder are getting stressed a lot and the flaps also ..
so that's good to know. standard size servos you got tons of options.
thanks for the answer.
Old Sep 24, 2013, 06:38 PM
icicles is offline
icicles's Avatar
Joined Jul 2006
I went with an 11kg servo for the flaps, it's a very tight squeeze. Set it up for 70 degrees, but can just about get 90 degrees lol. That should be like chucking a brick out the back.
It's a shame there doesn't appear to be more EDF's of this model. It's a very nice kit. And there are a huge amount of combinations available
Chris
New Product JTM 90mm Viperjet by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 1959 Jun 29, 2016 11:21 PM
New Product JTM "THE SPORT JET XXX" by UsaRcJets and Billy D BILLYDSRC Electric Ducted Fan Jet Talk 1711 Dec 12, 2015 10:22 PM
For Sale 12 CH DIAMOND VIPER F/A-18F Super Hornet RC EDF Jet ARF by BlitzRCWorks mike76 Aircraft - Electric - Jets (FS/W) 2 Feb 15, 2015 01:10 AM
Discussion Turbine Viper Jet by Skymaster RoyAceWings Jet Turbines 2 Jun 10, 2012 09:58 PM
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 06:58 PM
