Old Sep 05, 2012, 11:22 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Build Log
12" Isis G2 UltraLight
I already have a newer version designed, but I have this sitting down so I decided I should build it for our upcoming fly-in (Nov 4 - ERAU Daytona). Now I am wondering what electronics I should use. I have two .675g servos and an AP02 (actually four of them). However I do not want brushless, for simplicity, and because brushed is lighter and nearly as powerful. I was thinking of a geared 6mm. What should I use for control, servo or actuator?
Description: Name: ImageUploadedByTapatalk1346862118.292195.jpg
Description: Name: ImageUploadedByTapatalk1346862156.383514.jpg
Description:
boredom.is.me is offline Find More Posts by boredom.is.me
Old Sep 05, 2012, 02:31 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
blah blah blah.
edit:
you still have the ap-02?
whats the thrust on those, anyways?
i say actuators, mostly cuz its not done any more and in a modern 3D style plane it would set you apart from teh crowd. servos might be more precise, tho.
nemoskull is offline Find More Posts by nemoskull
Old Sep 05, 2012, 02:57 PM
Joined Nov 2007
Yep I still have all four. If I'm correct, I believe they do about 20g, but I have no presentable data of this. That is just what I got from what some have said.
I like the actuator idea, but since my first RC experience, with Plantraco, I've been scared to use acts. Still not over that fear...
As far as weight is concerned the servos are the lighter option, but there is a bit of fiddling that I'm not up to at the moment...
I am considering servos for the aile and elev and a .4g actuator for rudder.
Old Sep 05, 2012, 03:10 PM
Joined Nov 2007
AP02 Thrust Data
Prop - Current - Thrust
2.5x0.8 - 0.9A - 19g
3x2 - 1.8A - 27g
from micronradiocontrol.co.uk
Considering that I would still need an esc, this would be a heavy option at about 3g for the propulsion. On top of that, it would be an amp hog at constant full.
Old Sep 05, 2012, 04:33 PM
Joined Nov 2007
I swear by Foam Tac, but I am wondering if I should use foam safe CA instead.
I removed two lower ribs and one upper rib. They aren't necessary at this size.
Description:
Old Sep 05, 2012, 05:05 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Amazing!
What's your planed AUW?
Free
Free is offline Find More Posts by Free
Old Sep 05, 2012, 05:11 PM
Joined Nov 2007
I honestly have no idea. Would you say the airframe seems a bit heavy? I'll be shooting for 12g.
I'll be using 2um mylar and .5mm carbon control rods and fuse braces.
Description:
Old Sep 05, 2012, 06:26 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
are you using a deltang receiver?
minimicrorc is offline Find More Posts by minimicrorc
Old Sep 05, 2012, 07:08 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
If you come out at a 12gr AUW a 6mm GB should work fine. Get the J3Cub motor/GB, your new found 101mm CF prop and run them with a Hyperion 70mah battery. I would also stick with the servos.
TODD
I R Irv is online now Find More Posts by I R Irv
Old Sep 05, 2012, 07:46 PM
Joined Nov 2007
Most likely
TODD
I was considering a custom 4:1 or 5.3:1 gearbox with the same Cub motor. Does anyone know the Cub's ratio? The Cub had some bad prop shaft issues too.
I'll keep the LZ .675g on aile and elev. But that still leaves rudder. I can't afford the newer .48g bearingless version so I might just go with a MicroAct. The thing is that I doubt the Micro act has the torque needed for proper rudder control.
Oh and the 70mah might indeed be a better option, but at the cost of an extra .5g which.
Old Sep 05, 2012, 09:03 PM
Joined Nov 2007
I ordered the Mylar, made/assembled the aileron bell crank, and cut a slot for the aileron servo.
Now I'm wondering if I should locate the aileron related control hardware on top of the wing or under it. I remember running into space issues with my larger one, but I really do not think that will be as much of an issue now since I don't have an esc either...just rambling. I'm really just thinking about the final apparence.
Description: Name: ImageUploadedByTapatalk1346896212.000334.jpg
Description:
Old Sep 05, 2012, 10:15 PM
nemoskull's Avatar
Joined Sep 2009
on top the wing would run less risk of damage in case of a bad landing or crash.
Old Sep 05, 2012, 10:22 PM
I R Irv's Avatar
Joined Nov 2008
I'm pretty sure the Cub GB is 4:1 just like the Ember. That's why I suggested the CF prop, with a prop savor you'll never break the shaft especially if you screw the savor past the end of the threads.
TODD
Old Sep 05, 2012, 10:56 PM
Joined Nov 2007
Top mount it is.
TODD
Good to know. I'ld like to try a bearing-less gearbox. There is less resistance with smaller shafts. I'll also use a carbon rod for the shaft. A didel 9t and a 36t .3mod is the choice. I'll get the prop saver too.
Old Sep 05, 2012, 11:35 PM
nemoskull's Avatar
Joined Sep 2009
the 6mm motor in the HK gearbox is(was?) a 3.3 ohm model. back when i was running DD 6mm planes, the HK motor was noticablely more powerfull than the didle 4.5 ohm.
where do you get you gears from, BIM?
edit: now you got me all wanting to make small planes again!
Build Log Isis 3: A Custom DLG Project Keenan smith Hand Launch 20 Feb 10, 2013 05:45 PM
New Product Isis II Keenan smith Hand Launch 96 Jul 11, 2012 11:36 AM
Build Log Isis G2: Ultralight 3D boredom.is.me Scratchbuilt Indoor and Micro Models 14 Apr 05, 2012 12:23 AM
Build Log Isis - the Lico Look Alike: Maiden Success! boredom.is.me Scratchbuilt Indoor and Micro Models 140 Jan 15, 2012 04:57 AM
